BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 20" wheel options for 356m f32 xdrive
      08-16-2017, 02:21 PM   #1
Nbarrett
Drives: 2014 435xi
I have a 2014 435 xdrive I just bought 356m wheels w the following tires installed.
245/35-20 fronts
275/30-20 rears
I think the rolling diameter is 26.75" if I calculated correctly
What I'm wondering is if these are alright to run or not. I don't want to damage any drivetrain components if that's the case. And if I need to run different tires any recommendations would help.
Tirerack was recommending 225/35-20 front and 255/30-20 rear
      08-16-2017, 10:23 PM   #2
GCinFLA
245/35-20 fronts
275/30-20 rears
How many threads are you going to ask the same question in?
      08-16-2017, 10:42 PM   #3
Nbarrett
Drives: 2014 435xi
245/35-20 fronts
275/30-20 rears
Well see originally I asked about 437m and now I bought 356m. But I've asked around in a few threads. What's it to ya? I'm trying to get an answer without ruining my car beforehand. So I'll just keep firing Away.
      08-17-2017, 07:05 AM   #4
skw
Drives: 340i 6mt
The style of wheel wouldn't make a difference.
Boston CCA 383036
'17 340i 6MT, AW, LCL8, ZDA, ZDP, nav, adaptive suspension, MPPSK PCD 2/17
'16 MB GLE350 P1, illuminated star & running boards, pano roof
      08-17-2017, 07:38 AM   #5
Nbarrett
Drives: 2014 435xi
19" vs 20" wheels
      08-17-2017, 08:26 AM   #6
Walt White Coupe
Walt White Coupe's Avatar
24
Drives: 2013 650ix Coupe, 2016 Vette
What matters most is that the diameter of the front and rear tires are very close to the same.
      08-17-2017, 08:29 AM   #7
Nbarrett
Drives: 2014 435xi
rolling tire diameters are 26.75" front 26.49" rear.
Is this safe or unsafe
      08-17-2017, 09:38 AM   #8
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
thats way off for a xdrive. you need to be less than 1% difference
2013 EB/CR 335i xdrive | DHP | Coded | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      08-17-2017, 10:08 AM   #9
skw
Drives: 340i 6mt
19" vs 20" wheels
I just saw you mention the style of wheel which wouldn't matter. The diameter (19" vs 20") changes the tire size anyway, and regardless, you should be within 1% of the overall diameter of the factory setup. Seems you already know how to calculate this so you can size the tires accordingly.
Boston CCA 383036
      08-17-2017, 10:18 AM   #10
Nbarrett
Drives: 2014 435xi
19" vs 20" wheels
I just saw you mention the style of wheel which wouldn't matter. The diameter (19" vs 20") changes anyway, and regardless, you should be within 1% of the overall diameter of the factory setup. Seems you already know how to calculate this so you can size the tires accordingly.
I just did the final math again. Not sure what I did this morning. 26.75" front and 26.49" rear.
      08-18-2017, 09:18 AM   #11
wdeerfield
A family of bimmers
Those tires are pretty tall for the f30 platform. more than likely better for the f10. nevertheless they fall under 1% difference.
you could hypothetically run a 235/35/20 up front putting it at 26.48f, 26.49r.
      08-18-2017, 09:50 AM   #12
Nbarrett
Drives: 2014 435xi
Yes I just figured this out last night. Just trying to find a brand that i can match. I have bubbles on the front tires anyway so I'm going to swap them out asap.
235/35-20 front
275/30-20 rear
