BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Tire Size Help
      08-14-2017, 10:58 AM   #1
Sayzar
Drives: 2016 435i GC M-sport
Tire Size Help
Hi
Need help on tire size, current I'm running 225/40 for the front & 255/35 for the rear on a set of 19" BBS CI-R 19x8.5 -19x9.5 . I would like to go with something a little bit more meaty. I am lowered pretty low on coil over what size tire would work without any rubbing issues, as of not i have no issues at all and I'm also running 10mm spacers for the front.
thanks
20481822_1899967473596216_2692342486205988864_n by , on Flickr
IMG_4456 by , on Flick
      08-14-2017, 11:19 AM   #2
Sumptuous Hummus
Drives: 328i
Originally Posted by Sayzar View Post
Hi
thanks
235 front 265 rear
      08-14-2017, 11:20 AM   #3
Sayzar
Originally Posted by Sumptuous Hummus View Post
235 front 265 rear
235 x ?
265 x ?
      08-14-2017, 11:38 AM   #4
Sumptuous Hummus
Drives: 328i
235 x ?
265 x ?
235/40
And 265/35 should be good I believe.
      08-14-2017, 11:51 AM   #5
Sayzar
235/40
thank you
      08-14-2017, 11:53 AM   #6
Zentan
Drives: 2014 // 335i // M-Sport // EB
Heard 265 is the widest you can go on the F30/F32s. Was hoping I can fit 275 but heard from people that it would rub. Nice wheels by the way! Looks like you're based in NJ - do you come out to any of the car meets in NY/NJ?
      08-14-2017, 01:31 PM   #7
Mouse
Drives: 2013F30 335i
Depends on the offset(backspacing) of the wheel but a lot of people(myself included) run 275/30r19's with no rubbing issues. My rear wheel has a +40 offset. I'm also on H&R Sports. As a matter of fact I ran 285/30's but it only rubbed slightly when going up driveways in an angle.
      08-14-2017, 02:57 PM   #8
Sayzar
I'm running front 19X8.5 offset 35 - Rear 19X9.5 offset 40 I'm on KW coil overs
thanks for the info
      08-14-2017, 03:08 PM   #9
Sayzar
Thank you for the info - yes I've been to some events in NY/NJ mostly NJ
just went to Mpact this pass weekend, nice turn out
IMG_6985 by Cesar Villarreal, on Flickr
