07-16-2016, 09:50 PM | #23 | |
Rep 291
I love his passion but am worried he might get goofy when the automatic is the only choice. Really though I like this guy! |
07-16-2016, 10:24 PM | #24 | |
Rep 151
I have the standard 205 that was causing the issue which seems like it is fixed in Sport with the MPPK, if not fixed it is vastly improved. |
07-17-2016, 02:48 AM | #25 |
Rep 1,592
I don't know. Looking at the 2016 340i xDrive options the only transmission related one is the manual.
Do they have an MPPK for the 2016 340i? When I look at the showbmwusa website it lists nothing when I pick the 340i |
07-17-2016, 10:24 AM | #26 |
Rep 151
Dan203 The MPPK for the 340i is not out yet from what I understand. Also they are now bundling the MPPK with an exhaust which will be the MPPSK (M Performance Power and Sound Kit). Which unfortunately will drive up the cost, I wonder if they felt there is less headroom to modify the programming on the 340 so decided they need a freer flowing exhust? Unless it is just more sound like the current MPE but that seems very silly.
To know what auto transmission you have you can go to www.bmwvin.com and see if you the have the 205 or the 2TB. It is possible that all 2016s and on may now have sport, I sure would hope so. If you have paddle shifters that is supposed is also a sign of the sport transmission. |
07-17-2016, 11:00 AM | #27 | |
Rep 1,342
https://www.getbmwparts.com/parts/in...&siteid=214672 |
07-17-2016, 11:10 AM | #28 | |
Rep 1,342
I've only used Sport+ a couple times (like when I first got the car), but will try it over the next few days at the usual stop signs where this problem shows up. |
07-17-2016, 12:01 PM | #29 | |
Rep 840
This is the auto pedal: https://www.getbmwparts.com/parts/in...&siteid=214672 |
07-17-2016, 12:55 PM | #30 | |
Rep 376
If I'm already on the move the lag is much less noticeable. However, I still feel a lag in throttle tip in when shifting gears in comfort mode. Makes it sometimes harder to time the shifts smoothly. I wonder if an ER charge pipe will help a little with this?
2014 BMW 328i, 6-speed Prem / Nav / Drivers Assist / Heated Seats / Lighting |
07-17-2016, 06:17 PM | #31 | |
Rep 1,056
07-18-2016, 12:41 PM | #33 |
Rep 16,054
07-18-2016, 03:18 PM | #34 |
Rep 1,056
I never had lag in Sport+ when launching from a stop.
07-18-2016, 03:49 PM | #35 |
Rep 3,211
Noticed this in my testdrive when I floored it in sport mode.. figured it was turbo lag
Are you guys saying the throttle even in Sport mode is programmed to ramp up gradually to pedaled level? |
07-18-2016, 04:04 PM | #36 |
Rep 180
you just have to be comfortable being a little deeper in the gas pedal. or stay in sport+ throttle mode and sport transmission mode.
do you get it in manual 1st in sport mode? |
07-18-2016, 04:10 PM | #37 |
Rep 61
Yes, I too notice this lag in comfort mode. Switch to sport or sport+. I also try manual on comfort mode.
But recollecting, I also had the lag in my 335i, in non sport mode. |
07-18-2016, 04:10 PM | #38 |
Rep 1,592
Sport+ is just Sport with traction control disabled right?
FYI: I drove my 135i for a few minutes today (haven't sold it yet) and I really miss the stick. It's not as fast as the 340i but the feel of a manual and knowing exactly when it's going to pull or shift is just better. Should have got the manual in the 340i. Oh well, live and learn I guess. Probably not getting another one for another 8 years so I'm sure I'll get use to the auto eventually. |
07-19-2016, 03:23 PM | #39 |
Rep 153
07-19-2016, 03:25 PM | #40 |
Rep 153
07-20-2016, 09:57 AM | #41 |
Rep 6,986
Maybe mine doesn't because I have the MPPK installed?
07-20-2016, 12:09 PM | #42 |
Rep 1,503
IMHO BMW throttle tip-in has been quirky and unnatural since they switched to throttle-by-wire with the E46. Going from my E36 to my E46, there was a noticeable lag on tip-in. Unless you were used to it, you'd hit the gas like normal, there'd be a pause, then a jerk as the car jumped forward because by the time the throttle sensor caught up you were a full second into initial gas pedal travel. With the old cable gas pedals, you get gas the instant you start pressing so that first second is actually a linear buildup as the pedal moves from zero to 1s, rather than just starting at 1s.
It's improved significantly in the F30, but still there to a small degree IMHO. My solution is simply to ease into the throttle initially, slower than I would with my old E36. It's just that initial .25 to .5s of tip-in where I ease in slowly, then once the electronics have caught up and the car starts rolling you can proceed as normal. Kind of like working a twitchy clutch with short engagement zone, you just move a little more slowly at the engagement point. The other thing that might be happening is the car starting in 2nd gear if you're in comfort mode. You hit the throttle aggressively enough when starting off that it decides to downshift, so you get a pause then a jerk as the car suddenly takes off. You can probably eliminate this as a possibility by manually starting in 1st or sport mode. |
07-20-2016, 12:17 PM | #43 |
Rep 16,054
Lag isn't caused by electronics. When you hit 'submit reply' consider how long it takes your post to make it's way to the forum server, get archived, and then make its way back to your computer and appear on your screen. The distance from your gas pedal sensor to the throttle servo is considerably shorter. Lag may exist, but it's not due to the elimination of a mechanical linkage.
07-20-2016, 12:27 PM | #44 |
Rep 1,592
Exactly. The lag over a closed network like that is probably less then 1ms. Since this problem changes depending on which mode you have the car in, or whether you have the MPPK installed, it appears to be programming. Not sure if it's intentional or not, but I suspect it's probably intentional and meant to save a few MPG for regulation purposes.
