06-09-2018, 02:32 PM | #23 | |
Rep 170
The build of the speakers is very good when you physically handle them and look at the connections etc. They sound much more rich and have a depth to the tone similar to all of my SQ systems I've installed over the years. They do not fatigue the listener like the harshness of the stock H/K. It is pretty obvious that they could use more power and a cleaner audio source but they are a very good improvement over the stock speakers. |
06-09-2018, 03:02 PM | #24 |
Rep 7,484
I know but with a technic harness you can piggy back and it sounds even better. It is great as it is don't get me wrong. A fantastic idea and upgrade path but those speakers are capable of way more on an aftermarket amp.
06-09-2018, 03:47 PM | #25 |
25cent millionaire
252
Rep 1,220
Drives: 2020 m4 comp vert
all the midbass drivers mentioned are good midbass drivers. if you want adequate bass, add a dedicated sub and amp in the trunk,,, now to get decent extension out of a driver, you will have remove the plastic housing under the seat, remove the back seat heater vent, and fiberglass a new enclosure, at our shop we due this a lot and gives us great results, the boxes are around .25 ft sealed, and now most shallow 8s and some 6.5 work very very, well. so far the gb 6 has given us outstanding results, also the peerless 830946 is by far the best output to dollar value for this box period..
06-09-2018, 04:18 PM | #26 |
Rep 170
I agree, the low end is really missing, even with the Bavsound Ghost subs. So far they have not given me more lower end like they claim. I DEFINITELY notice more output from the lower mid range and notice "tighter" response than stock.
I have been looking at MusicarNW's add a sub, or full bass upgrade, but it is very expensive. I'll probably go talk to them since they are local to me in PDX. I didn't think adding an aftermarket amp to the full range speakers was as simple as just using the Technic harness though (adding a sub amp is). If it is that simple, why aren't people talking about it? |
06-09-2018, 05:25 PM | #27 |
Rep 16,088
Why, when there's no objective evidence available that it would be worth it? IMO there's only two reasons for there being no engineering data available. One is that the seller doesn't have it, the other it that they don't want you to see it.
06-09-2018, 05:39 PM | #28 | |
Rep 170
Instead of assuming that the speakers aren't any better because you haven't seen the data sheets, I would encourage you to listen to them yourself. I think you would be pleasantly surprised and would feel that the price and ease of install makes them worth it. Last edited by Larry77; 06-10-2018 at 10:34 PM.. |
06-09-2018, 05:41 PM | #29 | |
Rep 170
06-09-2018, 09:13 PM | #30 | |
Rep 16,088
I was bored today, so I pulled and tested my hi-fi woofers. They're not the least bit deficient, very well suited for the available space. Whoever it is who spec'd these knows what he's doing. Fs 51 Hz Qes 1.00 Qms 3.02 Qts 0.75 Vas 18.4L Re 2.4 Ohms Le 0.22 mH Sd 200 sq cm Sensitivity 86dB/w (1.5v) I also tested them in the car, which gave a Qtc of 1.0. That extrapolates to a enclosure volume of 0.6 cu ft. Now anyone who knows how to use WinISD or Bass Box Pro or any of the other various speaker modeling software programs can see what the stock woofers are capable of. Don't forget to account for cabin gain. Last edited by Billfitz; 06-09-2018 at 10:12 PM.. |
Onizukachan1088.00 |
06-10-2018, 12:51 AM | #31 |
Rep 170
So your stance is that these companies are creating speakers that are not superior to the stock speakers and are ripping all of us off by telling us a line of BS and our ears are hearing it because we want them to? You yourself do not have any actual objective data to prove your own point because you haven't even tested the aftermarket options yourself, interestin
06-10-2018, 01:22 AM | #32 | ||
Rep 10,473
In fact, I’ve seen Billfitz post a bunch of BS where he claims to have tested stuff but then when asked how he tested (knowing those of us could see through his BS, reverts to calling people trolls). But in this case, I actually agree with him. 1) You claim to be a hospital administrator. I shudder to think what would happen if you did treatments, operations or distributed drugs not approved after tons of testing and FDA approval. There is a reason your hospital would give sugar pills to hypochondriacs. 2) The High tinny sound you describe could be at the new speakers cannot reproduce the top octave. Perhaps as your are HA, get your Audiologist to test your hearing and post pics of the results here to prove your hearing is not damaged on the high end. 3) Speaking of high end...as in speakers, Audiphile speakers prove that weight or construction has very little to do with the quality of sound. 4) why is it a forum members obligation to buy and test products and report findings to you? The manufacturer/seller should supply the data. 5) technic harnesses are discussed in many threads here. You didn’t search. Why are they not discussed more? People, like you, believe the cheap route will cure all. 6) you did a horrible job of research. Musicar does not have a SubWoofer that will fit in your AH3 because of the car’s batteries. 7) Even if you could put a Musicar Sunpb in your AH3, if you had read the threads you would have found that people that put those (or any subs) in their vehicles usually end up uninstalling the Ghost “sub” woofers as they end up fighting a real sub woofer. If I call myself a Doctor, will OP let me perform medical procedures in his Hospital? Last edited by IK6SPEED; 06-10-2018 at 01:38 AM.. |
Soul_Glo13347.00 |
06-10-2018, 01:46 AM | #34 | |
Rep 170
#2) I was referring to the stock H/K speakers, not any "new speakers", I've heard a lot of quality systems that do not produce the fatiguing highs and empty mids that the H/K system gives us. When I built systems I always went for good quality "warm" sounding mids and highs. (ie Hybrid Audio) #3) I'm not asking him to test for me, I admiringly got a little frustrated by him asking me to send him speakers while he bragged about his wage and continuing to provide conjecture for his argument having not tested anything to compare to his stock speakers he tested. #4) I did read up on the Technic harness but I came away with maybe a misunderstanding that due to the wiring of the stock speakers you couldn't just direct swap an aftermarket amp to the door speakers etc with just the adaptor? #5) There was nothing saying that my Hybrid wouldn't work with their system, but now that you say that it does make sense since I don't have the space under the trunk that the non-hybrid version have--damn. I had emailed them to set up an appointment to go talk to them since they are local, I'll see what they have for ideas. #6) I'm happy to get rid of the Ghost subs if they are not good for the sound of my system, maybe I'll send them to other member for testing :-) Thanks for the info... |
06-10-2018, 01:49 AM | #35 |
Rep 170
You added one, I do understand that the quality of the sound of a speaker is not always about the construction of the speaker but it is usually a pretty good indicator of crap speakers when it's lacking.
06-10-2018, 08:08 AM | #36 | |||||
Rep 16,088
It took some searching, but I finally found a direct replacement woofer that provides specs, the Rockford-Fosgate T3. This compares it to the stock BMW driver in half-space (the standard for loudspeaker measurements) in the same BMW enclosure with the same input voltage. The BMW driver is louder and goes lower. If you were considering buying a pair of the T3 I just saved you $600. Last edited by Billfitz; 06-10-2018 at 11:10 AM.. |
06-10-2018, 08:03 PM | #37 |
Rep 170
I'll give the Ghost Subs a little more time to see if they go deeper but so far I've only noticed more mid bass in what seemed like, at least to my ears, a frequency that was missing.
After some more time I'll try switching back to the stock underseats to see if I like them better now that I have the Bavsound Stage 1's installed. I'm also going to go talk to MusicarNW to see what options they can come up with for me since I won't be able to directly install their "add a sub" system. I have 100 days to get my money back with Bavsound so I've got some time and won't be losing anything if I change my mind. I also asked Bavsound to send me a data sheet so we'll see if they do... I apologize for getting frustrated with the back and forth... Last edited by Larry77; 06-10-2018 at 09:11 PM.. |
06-10-2018, 09:24 PM | #38 | |
Rep 170
From Technic: "I do not support any HK upgrades other than adding a sub/up-powering the underseat woofers. Any other upgrade is much more complex than just adding another amp to the speakers because of the DIRAC processing/built-in EQ curve. The woofer outputs processing is manageable without the need of any external DSP." |
Soul_Glo13347.00 |
06-10-2018, 10:04 PM | #39 |
25cent millionaire
252
Rep 1,220
I have a 10 inch dvc sub in the back of the fish bowl car is a f30 its a shallow Dayton audio no usable space was used as we hall a lot of big stuff in this car.. also the ms-8 , fosgate pbr 300.4 and hertz hcp5d are behind the driver side trunk beauty panel.
06-10-2018, 10:25 PM | #40 | ||
Rep 7,484
06-10-2018, 10:40 PM | #41 |
Rep 170
So maybe I can mount the amp etc for my "add a sub" behind the driver side trunk panel instead of under the trunk like non-hybrid's, thanks!
06-10-2018, 10:45 PM | #42 |
25cent millionaire
252
Rep 1,220
it all fits..... lots of room. love the complete stealth look,
06-10-2018, 11:28 PM | #43 |
Rep 170
06-11-2018, 12:56 AM | #44 | |
Rep 7,484
