03-26-2023, 09:33 PM | #1 |
Rep 15
No PDC, backup camera retrofit help
2013 3 series with CIC_High, no PDC
TRSVC # 66 53 9 393 953 Camera # 66 53 9 240 351 REM # 61 35 9 374 507 I mounted backup camera, full REM (F4A) and trsvc. I routed the wires correctly, triple checked. 12v , gnd, KcanH, KcanL. I have CIC so I ran the wires from TRSVC to HU as follows, (TRSVC)Pin 2 to (HU)pin 18 (TRSVC)Pin 3 to (HU)pin 28 (TRSVC)Pin 4 to (HU)pin 27 I added 3AG to vo, then vo coded trsvc, rem, and hu_cic with esys Cleared faults, started car, put it in reverse, and nothing. No video, no warnings, no codes. i also changed the pin positions to that of NBT at the quadlock and i got an error "reversing camera malfunction" the code in ista said like no camera output - open circuit. so i believe the REM and TRSVC is working. maybe i got a bad backup camera from ebay.? Anything else I need to do? Scratchin my head here. I appreciate any help. Thanks Last edited by tubeofglu; 03-26-2023 at 11:53 PM.. Reason: added part numbers |
03-28-2023, 12:19 AM | #3 |
Rep 15
Update:
I used another scanner I had, and verified VO , and coded everything again Now I have code CA9428 no message (function PDC, 0x377) receiver TRSVC, transmitter PMA Probably because I don’t have PDC |
03-28-2023, 05:40 AM | #4 |
Rep 539
That would make sense. I can't find any hard proof of it but I was always under the impression that to have reversing camera you needed at least rear PDC fitted and that the only workaround is to get an MMI box for it. Retrofitting rear PDC doesn't look like it's such a painful job to do if you did decide to go that route.
ReMiii4021.50 |
03-28-2023, 05:10 PM | #5 | |
Rep 15
But I was following this thread exactly : https://f30.bimmerpost.com/forums/sh....php?t=1444907 Other commenters in that thread experienced successful results. |
03-29-2023, 10:51 AM | #7 |
Rep 539
The image on that thread does seem to show an error icon towards the rear of the car image. I wonder if that person also added 507 to VO (for rear PDC) and coded REM and HU with it even without the sensors being installed. Or if it isn't an error icon I don't know what it is because I've never seen it before.
I assume the car will throw up parking distance control error messages though. Unfortunately that thread doesn't mention whether or not this is working with no errors. |
03-29-2023, 11:30 PM | #8 | ||
Rep 15
03-31-2023, 01:42 AM | #9 | |
Rep 15
and i dont think backup cam will turn on when trunk is open.. or can it? update: the F4C from ebay had an internal fault for trunk open. installed F4A back and recoded; no trunk open warning. but still no backup camera with 507 added. Last edited by tubeofglu; 03-31-2023 at 09:24 AM.. |
03-31-2023, 11:24 PM | #10 | |
Rep 15
starting to think dude in the other post maybe low key sells these retrofit harnesses, lol. |
