07-31-2013, 10:42 PM | #442 | |
Rep 4,323
08-01-2013, 01:56 PM | #444 |
Rep 1,716
cause hes on M perf susp ... lookin sic btw
where are u in SD? im doin euro delivery and debating on adding that suspension when the car ships back.
Formerly addicted to e46fanatics
Formerly addicted to e90post |
08-01-2013, 08:14 PM | #446 |
Rep 1,044
I just took the plunge just ordered the m Perf suspension kit with the sway bars from Tischer.
Labor has been negotiated to $1000. Really hope this $3000 upgrade is going to be worth it |
08-01-2013, 10:34 PM | #447 |
Rep 1,044
So now my question is what could I possibly do with the base suspension that I'll be getting back after the M-Perf suspension goes in? Is there any possibility of selling the suspenion? I could probably just keep it for a few years and use it then to replace the M-perf suspension (when it goes bad), but then can you store a suspension in the garage for so long?
08-02-2013, 06:29 AM | #449 | |
Rep 4,323
08-02-2013, 04:25 PM | #451 |
Rep 1,093
Don't you want to keep them in case something goes wrong with the suspension years later and you might want a cheap repair?
Or are the parts really big enough to need a garage? (I'm still waiting waiting waiting to do mine ). |
08-02-2013, 11:29 PM | #453 | |
Rep 7,047
For the type of non track driving I do the sport suspension in my 03 325i was much better sorted than the M adaptive sport suspension in my 335i Msport. I was hoping for at least the same level of suspension performance as BMW did 10yrs ago, not a lower level, which is what we got. Even the lack luster sport suspension in my 09 135i was better sorted and suited for the car than this one in my 335i Msport. Aaaargh! So for me I can't see spending that much to get the "proper" suspension for an Msport. Ahhh...there. I'm over it and feel better now. Last edited by RPM90; 08-02-2013 at 11:45 PM.. |
08-02-2013, 11:42 PM | #454 | |
Rep 7,047
There is something like a 110-115lb weight difference between equally equipped 328i and 335i. Again, most of it is up front due to the larger engine up front. Then, that weight is half on each side. So having the same springs for each model isn't that odd at all as the weight difference is pretty small especially since the M Perf spring rate is a good bit higher. The dampers, it seems, is where BMW tuned for the slight weight difference. More weight greater effect on the spring so it needs a different damping calibration. I wish BMW would have spent more time and effort and tuning of the OEM sport/Msport suspension to better compensate for the weight difference between 328i and 335i. The 328i does have a better handling feel as the OEM suspension tune seems better on that variant. |
08-03-2013, 12:09 AM | #455 | |
Rep 7,047
The springs and dampers will make a HUGE difference in handling. Sway bars are a 'fine tuning' component. They tie the left and right suspensions so that the car stays flatter in the turns. But still, most of the weight transfer is being handling by the springs, which you are already greatly improving over what you now have. And the dampers then control the springs compression and rebound, and you're improving those as well. The vast majority of sway control is already being improved by those components. If you have access to try an F30 with the sport springs and M adaptive dampers, go drive it and you can prove this to yourself. I have M adaptive dampers in my 335i Msport, and it has the large sways stock. Setting the dampers to normal/comfort mode there is a good bit of sway in turns and quite a bit in transitional left to right movements, like lane changes or swerving to avoid something. When I set the dampers to sport mode the sway motion is markedly improved, and that's with the same sway bars changing nothing, as they are not active nor adaptive. If you're going to track your car, then it might be worth the investment. But if it's just for spirited street driving I'd invest in better tires and let your new M Perf suspension do it's job. You already have sways on your 3, they are just a bit thinner than the upgrades. The cost to swap they are giving you is HUGE, and frankly I think too much. If you've already committed, then my comment is moot. Enjoy you're new setup, I'm sure you will. |
08-03-2013, 04:29 AM | #456 |
Rep 357
RPM, that's great advice. However, I already went through with the full upgrade. I was able to negotiate a much more reasonable labor rate and on parts, so it's all good (they tend to perk up when you say you'll have it done at another dealership, lol) I'm loving it!
08-03-2013, 05:14 AM | #457 |
Rep 398
I love the ride of the msport with the m performance suspension. Body roll virtually eliminated. Much more road feel. Tracks like its on rails. Should have been made this way from the beginning. Comfy/Cush it's not.
08-03-2013, 09:05 AM | #458 | |
Rep 4,323
When the LSD comes out, I'm sure i'll be doing the same thing...
08-03-2013, 11:44 AM | #459 |
Rep 398
What's this LSD talk shiv? U hearing anything forthcoming?
08-03-2013, 11:44 AM | #460 |
Rep 4
Springs part numbers for 335i RWD 6MT
All,
I have gone through all 21 pages of this thread with interest as I am also looking at this option for my F30. Despite the increasing clarity over part numbers etc. I still see discrepancies that confuse me. I have a 2012 335i RWD Sportline (from Canada, without Option 704 Sport Suspension) with a 6 speed manual tranny. According to two references here, my front and rear spring part numbers should be: 31336860629 and 33536860620 respectively. 1) Post from jamesems on 11-20-2012, 8:02pm: OK, so you'd need different springs. The part numbers you'd need for the front springs is 31336860629 x 2, for manual transmission, 31336860630 x 2, for automatic transmission, and for the rear springs (for both auto and manual trans) is 33536860620 x 2. The springs are $92.40 each.2) Post from ronin951 on 03-02-2013, 10:31pm: I looked up the spring codes and they are as follows:However, when I logged on BMW's electronics parts catalog with my VIN, and looked up the Spring Table with the M Performance Suspension kit, the numbers I got are: Front Coil Spring: 31336860630 Rear Coil Spring: 33536860621 QUESTIONS: - Does any know what the correct part numbers for the springs are?? - Are there any 335i RWD 6MT owners with this setup and what part numbers are you using?? Thank you. |
08-04-2013, 05:24 AM | #461 |
Rep 478
Awesome thread its really got me on the fence between aftermarket suspension vs OEM but so far looks like I just have to go M Performance route:
Pros: -You keep your warranty 5 years -Resale don't have to take it off if you want to trade it back in -Designed and tuned to the f30 Cons: -Not as low (for asthetic purposes) -non height adjustable I was set on either KW v2 or Bilstein PSS10 ...either one with install would have been 2k-2500k. M Perf. route looks to be around 3k based the info people in this thread have contributed. Thanks to all that posted their thoughts, labor quotes. |
08-04-2013, 11:18 PM | #462 |
Rep 398
pros outway it. Too low blows. Sucks scraping your front end on driveways or hunting around for a way out of a place because they driveway is to steep. This is lower but not so low that you run into many problems around town. And its designed specifically for this car. Come check mine out in person to get a feel for the height.
