08-28-2012, 02:03 PM | #1 |
Rep 1,201
Has anyone driven both F30's with VSS and without??
I've been looking through the forum, and it seems no one in the thread has driven both back to back...none of the dealerships in my area have the Variable Sport Steering option, so I wanted to see if anyone has driven both on here. I need help deciding whether to get the option or not
08-28-2012, 02:05 PM | #2 |
Rep 5,120
would like to know this as well
08-28-2012, 02:22 PM | #4 |
Rep 1,201
08-28-2012, 03:41 PM | #5 |
Rep 857
I really like the dhp Ride better in comfort. Not so sure if it's any firmer in sport. What I do find important is the ability to tighten the steering shocks without having the twitchy throttle. You can separately raise shift points on 8at with shift lever
Hope this helps. |
08-28-2012, 04:36 PM | #6 |
Rep 1,201
The bigger dilemma is the variable steering. Is it awkwardly too light when driving? I remember that was a fault of the old active steering, as it had no feel. But have you noticed the "variable" aspect of the steering?
08-28-2012, 04:55 PM | #7 | |
Rep 857
08-28-2012, 04:57 PM | #8 | |
Rep 193
08-28-2012, 05:22 PM | #9 |
Rep 1,201
haha, that's good to know, do you remember what was "much better" about it? Was it more direct? Tighter? Softer? etc...
08-28-2012, 05:26 PM | #10 |
Rep 193
It felt tighter and more responsive, at least based on my driving style. Wasn't a huge contrast in all respects, but I'm happy with how my car steers. I'd like it to be a little firmer in comfort mode at neighborhood speeds, but couldn't be happier with sport mode. Also love how it feels when driving more enthusiastically on curvy roads.
08-28-2012, 06:28 PM | #11 |
woof
84
Rep 1,233
From about 150 miles of VSS driving, I can tell you that it is vastly similar; and even improved upon while compared to the E9x M3.
I think that says a lot - It is very agile and quick; almost too quick at first because you aren't used to only having to turn the wheel 180° to go around an entire 90° turn. If you've ever driven an earlier evo, (7, 8), it feels similar to that. Which is new for BMW, but a welcome change IMO. When I test drove an F30 335 non VSS, it was as expected.. The turning ratios were consistent across the platform. This is actually a really simple thing to analyze. If you want the steer wheel to turn the wheels quicker through the first 90 degrees, get VSS. If you want the steering wheel to turn the wheels the exact same amount through it's entire range, don't get VSS.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue Last edited by gerbs; 08-28-2012 at 06:33 PM.. |
08-28-2012, 06:44 PM | #12 |
Rep 1,201
Thanks for the responses guys. I definitely do prefer quicker steering. But last question, does it feel as quick as e9x M3 steering? Cuz that's super quick too, but awesome
08-28-2012, 07:40 PM | #13 | |
woof
84
Rep 1,233
There is less road feel due to the electronic steering; but the swift, swooping action and the feedback is very similar.
2013 F13 ///M6 Sakhir Orange 2013 F30 335i Estoril Blue II 2008 E92 ///M3 Interlagos Blue 2007 E92 335i Montego Blue |
08-28-2012, 08:03 PM | #14 |
Rep 3,307
I'm only going on a test drive, but I can say with an Audi S5 I had, it was incredibly noticeable how much lighter it was at low speeds and I don't remember anywhere near the same in the F30 I test drove with VSS (a '12 335). I didn't mind how night and day it was in the S5, once you got up to speed it was kind of cool feeling it tighten up. But I don't recall the F30 being as "variable feeling..."
08-28-2012, 09:08 PM | #15 |
Rep 436
I do not think I would like this car as much without the VSS, makes the car feel the way I expected in Sport+, which is pretty much what I drive in 90% of the time.
2023 G80 ///M3x Comp. BSM on Black M Brakes
Gone: 2018 F80 ///M3 ZCP 6 MT, 2013 F30 335i 6MT M-Sport |
08-29-2012, 03:01 AM | #16 |
iX1 2022
35
Rep 333
VSS doesn't add anything but a difference in the mechanical gearing
But this has been told in this forum several times already:
VSS doesn't add anything but a difference in the mechanical gearing of the steering. The difference in feeling between different driving modes comes from Servotronic which is included in VSS but also available separately. |
08-29-2012, 03:05 AM | #17 |
Rep 1,197
And yet every single piece of factual information available on the VSS says it's only active AFTER 100 degrees of lock ...
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH |
08-29-2012, 06:13 AM | #18 |
Rep 61
Yeah, I thought that it was supposed to speed up the gearing closer to the extreme lock.
I'm sure it's excellent at daily driving and at the parking lot but at the same time I'm worried that it would make it confusing to add the instinctive amount of opposite lock. What do you guys think? caput |
08-29-2012, 11:42 AM | #19 |
Rep 7,047
VSS steering ratio is 14.5:1 vs standard at 15:1, IIRC.
VSS is slightly tighter up to to the first 100 degrees of steering wheel turn. Past 100 degrees the ratio becomes tighter, meaning, for every degree of steering wheel movement there is even more wheel/tire steering angle. |
