10-07-2012, 02:50 AM | #1 |
Rep 45
F30 air con comes on even with button off
Hi I just had my F30 software updated by uk dealer and since then the AC comes on every few times I start the car even with the AC button Is in the OFF position????? Has anyone had this fault? Thanks
10-07-2012, 03:12 AM | #2 |
Rep 291
My Z4, X5 both do it, i expect the F30 will do so also. I have heard but not sure about this explanation, that the air circulation comes on to match up your last temperature setting.
10-07-2012, 07:10 AM | #5 |
Rep 215
I was told that you should run your A/C at least once a month to keep the seals from drying out and leaking. Obviously this is less of an issue in a new car but it might be a built in feature.
2012 328i Base, Auto, Melbourne Red
10-07-2012, 07:23 AM | #6 |
Rep 1,197
Air conditioning is important for the car - it controls humidity as well as temperature and you should always have air-con switched to "on", even when you're heating the air. Air-con != cold air.
BMW spend millions developing clever climate control systems, to turn them off is just churlish
ZMS | ZNP | ZVI | 2VF | 2VL | 3AG | 494 | 6NS | 8TH |
10-07-2012, 07:55 AM | #7 | |
Rep 777
Drives: 2022 X3 M40i
10-07-2012, 10:06 AM | #8 |
Rep 710
I noticed mine was blowing ice cold when the indicator did not indicate (?) I was calling for cold. Windows all down on an 80-degree day and set the car to 60F so I'm not blowing hotter air into car. Noticed the icy-cold air. So I hit the "auto" button on and off and it stopped blowing cold. Kinda annoyed me. Will discuss when I bring the car in for service and reprogramming.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi |
10-07-2012, 09:13 PM | #9 |
Rep 137
It wasn't clear by reading this thread but is there a way to prevent the AC from coming on every time the car is turned on? Every time I start my car the AC comes on set to the temp that I last had it on. I'd rather the AC not come on upon startup.... is this possible?
10-07-2012, 09:49 PM | #10 | |
Just Copacetic!
177
Rep 616
10-08-2012, 09:10 AM | #11 |
Rep 137
I do this everytime I get into the car (meaning I press the left minimum airflow button until the system shuts off) but after getting to my destination and shutting down and locking the car, the next time I unlock it and start it up the fan comes back on. Is this normal?
10-16-2012, 05:01 AM | #12 | |
Rep 60
10-16-2012, 05:16 AM | #13 | |
Rep 3,307
10-16-2012, 03:50 PM | #14 |
Rep 45
If the air con button is off then the Aircon must never come on. This is the way I had all my BMWs 6 of them even the f30 in question. This fault appeared after the recent software upgrade
10-16-2012, 04:20 PM | #15 |
Rep 2,248
Hard to tell above if people are talking about the air conditioner (for which there is a separate "snowflake" button on US cars) or the whole system. The system defaults to "on". The a/c button defaults to last use; in my experience it may take a couple of cycles to "teach" the car (this is keyed to the specific key fob) to change the default. You can read about this in the friendly manual.
Of course, BMW includes a button to turn the a/c off, then someone acting in their name tells you you must never do that. Who you gonna believe, some goniff in a car dealership, or the button? I prefer to leave it on, as a dehumidifier in cooler temps, and of course you should run it periodically to keep the seals in the system from drying out or cracking, but the switch is there for a purpose. |
10-16-2012, 06:46 PM | #16 |
Rep 3,566
My F30's fan comes on at the lowest speed when I switch the car on. Good to have some sort of constant air flow change in the car. The full air conditioner does not come on. I still have to manually press the button for that.
Exactly the same setup in my E90. This was preset by the factory or dealer prior to delivery. Perfect setup for me.
10-17-2012, 01:21 AM | #17 |
Rep 45
I am talking about the snowflake. If you keep it off it should stay off like all normal BMWs that I had including this f30 before software update. After the software update even with snowflake never been lit(on) when you start car up sometimes the AC compressor comes on without AC light snowflake coming on and doesn't turn off unless I put the fan to off. Crazy
10-18-2012, 02:44 PM | #18 | |
Rep 241
10-19-2012, 09:55 AM | #19 |
Rep 38
This happens for me ever since I got my 328i back in june. Everytime I get in the car and turn on my engine, the ac comes on!! ( the snowflake turns on only if I had previously used it before I turned the car off) but the system always turns on. I was wondering if that is a problem with the computer or is that a standard feature. That never happened on my e90... If that's a standard feature... I don't think its useful..
06-05-2013, 04:45 PM | #22 |
Rep 2
I have a 2013 F30 320d ED and I'm experiencing the same.
With the A/C button off, the compressor still kicks in. I believe it's the mist/fog sensors that activate it. Off should mean off! I have emailed BMW, but they told me to take it into a dealer. |
