06-23-2016, 01:00 PM | #45 |
Rep 20
I've been living with this issue since I got the car CPO'ed last year. Dealer acknowledges the clunk but says BMW won't change the steering rack because it doesn't affect anything else otherwise. Has anyone recently been able to get this fixed under warranty?
06-23-2016, 01:22 PM | #46 |
Rep 201
I did. I got my steering rack replaced with no questions asked. Try another, better reputable dealer, is my suggestion. SO far my noise is gone. Lets see what happens. I only have a couple hundred miles on the NEW rack.
2013 X3 2.8iX
2013 335i M-Sport RWD 2007 530i RWD 6-Speed manual BMWCCA MEMBER 397411 |
06-23-2016, 06:14 PM | #48 |
Rep 740
I have an appointment next wed for the same thunk sound when turning my steering side to side with the car off along with a hollow-ish sound going over bumps or rough roads. MY 4/13 328i sport line without DHP.
06-24-2016, 06:26 AM | #49 | |
Rep 71
07-06-2016, 12:53 PM | #50 |
Rep 20
07-11-2016, 04:08 PM | #53 |
Rep 740
Dealer states they could not replicate the noise. Even showed them the OP's screen shot but no go. And the wait for a tech to test drive with me was too long. I'm going to try a different dealer and see what they say in a few weeks.
07-13-2016, 04:11 PM | #54 |
Rep 20
Thanks, please keep me posted! I'm going to make an appointment with BMW Bayside soon as well.
07-27-2016, 03:49 PM | #55 |
Rep 541
I just got my car back from getting the rack replaced. Exact same noises as the OP. The clicking is still in the steering wheel when I turn side to side but the thunk isn't as noticeable. However, when going over bumps or uneven road, the noise is still the same on the left side. Something sounds loose and it is driving me nuts.
Now: 2012 F30 335i / 6MT / JB4 / ER Catless DP
Sold: 2010 Jeep GC SRT8 Sold: 2007 E90 335i / 6MT / JB4 / Vishnu Exhaust / VMR 710 19" / BMS DCI / HKS Blow Off Valve / Tinted Tails / Clutch Stop |
09-07-2016, 12:22 PM | #56 |
Rep 96
Has anybody had the steering rack replaced and had the noise go away only to come back a few months later? I wonder if there is a permanent solution?
09-13-2016, 06:27 AM | #57 |
Rep 943
Drives: 2012 328i Modern Line
Have you checked thrust arm bushings?
:wave:
09-15-2016, 11:08 PM | #59 |
Rep 96
09-16-2016, 07:55 AM | #60 |
Rep 943
I just looked at the videos on YouTube and the only ones I could find (no F series) were bushings that were completely failed. I'm getting ready to replace mine on my '12 328i F30. I notice a "clunk" when I'm coming to a stop from a slow speed, usually when I'm pulling out of my parking lot. When I took it to the dealer they put it up on a lift and you could see where the bushing was starting to crack and the wheel had significantly more play when shaking it than the other wheel which has a bushing without wear.
:wave:
09-19-2016, 09:59 PM | #62 | |
Rep 943
:wave:
03-28-2017, 01:25 AM | #63 | |
Rep 96
My old dealer replaced the left strut and left strut mount and claimed the noise was gone and it wasn't. Finally after the steering rack and outer tie rods were replaced it went away. No charge for any of this. My new dealer will charge $197 for diagnostics + replacement cost if it's not covered under CPO, and $50 deductible otherwise. I may go to get it done, would be better if they had a permanent solution. Also curious if this problem exists on later model years. |
03-28-2017, 05:28 AM | #64 | ||
Rep 943
:wave:
Pato808f302.00 |
03-28-2017, 11:56 PM | #65 | |
Rep 96
The clunk while stationary and turning the wheel seems like a different issue. |
05-14-2017, 09:47 PM | #66 | |
Rep 74
This is EXACTLY the question I want to know. (sorry about reviving an old thread... but seems to be exactly what I'm experiencing) My out of warranty F30 now has the same issue. I had it on a lift the other day and noticed a little bit of play in the front drivers wheel (right hand... NZ). Very very small, but enough to make a little noise (clunk) when I pull on the steering the same way the videos earlier in the threat indicate. THe steering rack replacement seems a little drastic doesn't it? Could this not just be the ball-joint that is attached to the tie rod? |
