BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Idiots guide to coding EBT
      02-20-2018, 02:49 PM   #1013
Mottok
Drives: F30 335d Xdrive
Anyone?
      02-20-2018, 03:04 PM   #1014
teaston
teaston's Avatar
Drives: 335d M Sport Plus
Originally Posted by Mottok View Post
Originally Posted by teaston View Post
I thought we were talking about the head unit?
Sorry, I haven't done any coding before so probably getting confused. What I'm doing is following shawnsheridan's 2 steps below. Now I thought the first step was done by following the "How to change FA in F-series car.pdf" guide (like we were talking about above). And THEN you do step 2 and VO code head unit. So I thought there were two separate steps to restore, I'm wrong eh?
Step 1. Change FA from 6NH to 6NS:
E-Sys - How to change FA in F-series car.pdf
Step 2. VO Code Head Unit and standalone Combox (CMB_MEDIA) if present:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on Head Unit ECU (e.g. HU_NBT, HU_CIC, HU_CHAMP, HU_ENTRY, HU_ENTRYNAV, etc.) (the ECU itself not the underlying CAFD) => Select CODE (Not Code FDL).
You don't need to undo step 1 to restore it, when you connect to the car in future the FA will be same as factory, as you haven't done the steps to write the modified FA to the car.
Current: LCI F30 335d M Sport Plus in BSM/CR
      02-20-2018, 03:10 PM   #1015
Jhnblckwood
Drives: F30 2014 320i xdrive
Retrofitted nbt into f30 all went great, nbt came with 6nh was able to stream music but wanted office for txts but since I coded 6ns the USB connects n disconnect rappidly. I kno this is a problem with some iPhone cables but it was working fine before I coded 6ns, should I disable snap in adapter or?? Anyone else face this problem? Everything was working fine before I coded 6ns so it shouldn't b the cable correct?
      02-20-2018, 03:59 PM   #1016
Mottok
Ok, so I understand:
1. When I do “Right-click FA and calculate FP again Then save the new FA."
This is just saving a new FA to the laptop, not anywhere in the car?
2. When doing the VO code to the head unit, this is applying the above FA to the head units ECU?
God I hope that’s right! Many thanks, very much appreciated.
      02-20-2018, 04:03 PM   #1017
teaston
teaston's Avatar
Yep that's the one!
Derrymilk162.00
      02-20-2018, 04:43 PM   #1018
Mottok
Yep that's the one!
Woohoo at last! Thanks a bunch for that
teaston6422.50
      02-20-2018, 05:00 PM   #1019
Mottok
While i’m Asking lots of questions, will this add office to the idrive? Ta
      02-20-2018, 05:05 PM   #1020
teaston
teaston's Avatar
While iím Asking lots of questions, will this add office to the idrive? Ta
Yes, for what itís worth.
      02-20-2018, 05:11 PM   #1021
Mottok
Haha, well itís a start, thanks.
      02-20-2018, 05:17 PM   #1022
teaston
teaston's Avatar
I have my phone on a dash mount which is much better for getting emails and texts!
      02-20-2018, 05:33 PM   #1023
Mottok
Anything else in entrynav that would be worth unlocking or is that pretty much it?
      02-20-2018, 06:11 PM   #1024
Jhnblckwood
Any idea why this would happen?
      02-20-2018, 06:16 PM   #1025
teaston
teaston's Avatar
If the car doesn't have any options then there's not a lot, if think the only two other essentials for mine are mirrors fold on unlock and active cruise control starts on closest distance.
I also disable drivers seatbelt warning, just for when I'm driving round supermarket car parks etc.
      02-20-2018, 07:39 PM   #1026
Jhnblckwood
So weird I tried a different USB chord n now it's fine, sooooo strange smh
      02-23-2018, 10:25 AM   #1027
Mottok
Probably a really stupid question and defo a newbie one but anyone know why when doing coding to fit the ProNav screen (only) on an HU_ENTRYNAV head unit it talks about "HU_NBT" and not "HU_ENTRYNAV"?
Also - if anyone has an easy guide for this it would be great if you could post a link (piecing together stuff from Interweb is a bit tedious at the moment).
Thanks.
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
      02-23-2018, 10:28 AM   #1028
teaston
teaston's Avatar
Thanks.
NBT is pro media hu, Entrynav is Business media hu
      02-23-2018, 10:47 AM   #1029
Mottok
So it's not that I use HU_ENTRYNAV because I have an HU_ENTRYNAV head unit, it's that I use HU_NBT because it's a ProNav screen and needs HU_NBT to enable it's use?
Thanks.
      02-23-2018, 10:51 AM   #1030
teaston
teaston's Avatar
Thanks.
You don't have HU_NBT on your car so just substitute it with HU_ENTRYNAV
      02-23-2018, 10:58 AM   #1031
Mottok
That's what I thought, it's just that I was looking at the thread below where he is coding for ENTRANAV but writes HU_NBT instead, that;s why I was confused.
Thanks.
http://f30.bimmerpost.com/forums/sho....php?t=1257854
      02-24-2018, 11:16 PM   #1032
Douggie
Drives: BMW X1, 5
Originally Posted by shawnsheridan View Post
Original FA is stored in car VCM. Select "Read FA", and you get FA from car, as opposed to loading a custom FA from PC.
There is no FA to restore because you have not written any modified FA to car. If you want to restore ECU Coding though, which has been modified, then Read original FA from car, and VO Code ECU.
Hi Shawn, so there is really no need to write a modified FA to the car? I wonder why most of the VO coding instructions still tell people to use the VCM to write the modified FA to the car? What are the advantages/disadvantages if any? Thanks
      02-24-2018, 11:38 PM   #1033
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Write modified FA to car if hardware and build date support option, and Dealer ISTA will not have programming issue with it. Car without EBT from factory lacks hardware (secondary microphone) so EBT option written to car can be a problem for ISTA.
      02-25-2018, 01:41 AM   #1034
Douggie
Drives: BMW X1, 5
I'm having issues with adding 6NS to my f48. I used VCM to write FA to car (like most tutorials). I ended up with a corrupted CAFD (CAFD_FFFFFFFF_255_255_255) when I code HU_ENTRYNAV. Could it be because I did the VCM step?
