02-27-2014, 12:56 PM | #377 | |
Addicted to Speed.
711
Rep 2,375
Rich,
What is the timeline for availability of these struts? Quote:
2017 991.2s
2015 F15 35i 2017 Macan gts |
02-27-2014, 01:11 PM | #378 |
451
Rep 4,592
02-27-2014, 01:40 PM | #379 |
Rep 166
02-28-2014, 09:03 PM | #380 |
Addicted to Speed.
711
Rep 2,375
thanks looking forward!
2017 991.2s
03-02-2014, 05:06 PM | #381 | |
Rep 53
Bmw 335d x drive
Dan. |
03-02-2014, 08:50 PM | #382 |
Rep 132
Drives: '13 328i xdrive
What spacers would be best if using the standard 17" wheels? Still 12/15? I don't want any rubbing with hard driving..
It’s rude to steal Cadillatic converters.
2011 135i DCT, 2011 128i 6MT, 2014 435i FBO, 2006 Z4 3.0Si 6MT, 2003 330ci 5MT, 1985 325E 5MT |
03-06-2014, 05:59 AM | #383 |
Rep 157
Any update? Group buy? I have the HRs sitting in the basement would love to install shocks at the same time.
03-09-2014, 11:15 PM | #384 |
Rep 1,718
Installed the H&R Sports about two hours after I picked up the car from the dealership, so I can't really comment on the difference in the "before and after", however I can give a short review on how the car rides so far. The pic below is how the car looked just after getting the springs installed and I then swapped the 20" 405s out for some 18" with Dunlop 4D winters so I've been running on those and I assume the ride will be a bit harsher once the 20's are back on for summer.
I also don't drive the car in anything but sport/sport+ mode...in fact I am going to have it coded so that it starts up in Sport+ mode. So again can't comment on the Comfort mode ride. Coming from a C350, so I've had enough "comfort" over the last 4 years, lol. Ok so all that said...the ride is stiff enough, but I still feel some body roll on on/off ramps. I will also say that the car does start to feel "bouncey" on roads with extended unevenness or undulating pavement. Luckily I don't drive on many roads like this, so I don't experience it that often. As for clearance, someone in this thread said it...if you've driven a lowered car before than you just know how to drive one (I.e. Railroad tracks, speed bumps, driveways, etc.) - I had a WRX a few cars ago also lowered on H&Rs. Never had an issue with the stock shocks. I have only bottomed out the shocks once when I hit a pothole I didn't see (filled with water). And I haven't scraped the front lip yet. I feel like the suspension could still be improved so I'm thinking of swapping them out for a set of KWs come summer. Just waiting to see a few more reviews on them from guys with xDrive and DHP. Anyway here's a shot of the car...it does look better than stock height for sure. |
03-10-2014, 09:41 PM | #385 |
Rep 1,023
Drives: 2019 440xi Gran Coupe
Bouncey is not what I wanted to hear. It's the worst when its bouncey due to spring upgrades. Had that on my previous car and would not want to have that same feeling on a beemer.
03-10-2014, 09:53 PM | #386 |
Rep 282
03-21-2014, 10:11 AM | #387 |
451
Rep 4,592
Bilstein USA is playing coy with the release date. They said the German version would be out in August, how soon it makes it to the US after that, I couldn't say.
08-06-2014, 09:37 AM | #389 |
451
Rep 4,592
08-20-2014, 10:36 PM | #390 |
Addicted to Speed.
711
Rep 2,375
thanks!
2017 991.2s
08-24-2014, 04:45 PM | #391 |
Rep 1,023
Sway Bars
Front/Rear Diameter Adjustable Note Part Number Sug. Retail Front 28mm Yes Adj. 2 hole 70878-6 $459.00 Each Rear 20mm No 71878 $349.00 Each |
09-02-2014, 06:09 PM | #392 |
Rep 437
FYI, I also work in the car parts biz and they are telling me mid Nov. Pretty firm date this time
2022 BRG G80 xDrive
2005 SGM M3 |
02-13-2015, 03:40 PM | #393 |
Rep 5,316
Drives: G80 M3 6MT
So what's the deal with these? Are they too bouncy? What does that realistically mean?
I see TONS of these for sale used, why are so many people ditching them?
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
02-15-2015, 04:59 PM | #394 |
Rep 80
02-15-2015, 06:50 PM | #395 | |
Rep 1,490
My recommendation if you can, get a BC coil or KW coil set. Or pair these with bilstein shocks. You'll be much happier with the comfort. If not go with Dinan + bump stops. The ride height/spring rate will be much better for the terrible roads in New York than these
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
02-27-2015, 02:38 AM | #396 |
Rep 74
I had the H&R sport springs installed on my '14 435i xDrive not long after purchase. The resulting ride height put the xDrive where I think a sport coupe "should be," while retaining the winter driving advantages of all-wheel-drive. There is about 1" of wheel gap front & rear. Regarding ride, in my opinion the stock dampers are too soft for the springs. Both compression and rebound happen a bit too quickly on bigger rolling frost heaves and bumps. It's not horrible, but I personally would like more damping to eliminate the quick "bounce back" after bigger compressions. Some sharper bumps immediately produce a "thud" - possibly a product of the progressive spring rate with the light damping of the stock struts.
Recently I hit a monster pothole - a product of the very strange freezing/raining/thawing cycles we're having here this winter. It was horrible and I put a slight flat spot on both driver-side winter wheels (tire beads are okay) and broke the lower tab on the front strut, causing the strut to slide in the lower pinch bolt/clamp and dropping the ride height about 3/4" on the driver front. I'm wondering if I would have sustained such damage had I been running the taller & softer stock springs. My guess is I would have, as it was an exceptionally bad pothole. I'm deciding now whether to replace the stock struts and shocks with Bilstein B8s, which are supposed to be 20% stiffer than stock hence, theoretically better suited to the H&R springs; or, go back to the stock springs with an OEM replacement strut.
2014 435i xDrive MSport / Black Sapphire Metallic / Black Dakota Leather / MPPK / 6MT / 19" / M Sport Brakes / DINAN Springs / Bilstein B8 / Technology Package / Premium Package / Cold Weather Package / Driver Assist / HK Sound
