01-02-2013, 12:52 AM | #1695 |
Rep 40,788
01-02-2013, 12:59 AM | #1696 | |
Rep 747
Are there any issues with coding a car with NBT and 48.1?
BMW iX M60, Storm Bay with XPEL Stealth PPF, Exterior Line Titan Bronze, 1EW 22" 1023 Wheels, Amido Leather, Comfort Package, Interior Camera, Clear&Bold, Sun Protection Glazing, B&W Diamond Sound, Folding Towbar, Rear Axle Steering.
01-02-2013, 01:01 AM | #1697 | |
Rep 747
Thanks for your contributions on here - so very useful and informative!
01-02-2013, 01:09 AM | #1698 | |
Rep 40,788
The issue isn't the head Unit or any other hardware, rather it always a matter of what ISTA/P version was last used to program the car versus what PSdZData you have for E-Sys. So long as your PSdZData version is equal to or higher than the ISTA/P version on the car, there are no issues. You can have car with older hardware, but newer software, so a car with CIC and 48.2 on it will have problems using 48.1 PSdZData, whereas a car with NBT and 48.1 on it won't.
01-02-2013, 01:11 AM | #1699 |
Rep 40,788
When I have it, I'll open up a new thread listing the CAFD changes, so all will know.
01-02-2013, 01:16 AM | #1700 | |
Rep 747
Is the version used on the car visible when I connect using E-Sys?
01-02-2013, 01:18 AM | #1701 | |
Rep 490
You will know they are incompatible when it can't read completely, missing CAFD files when you try to code, so no harm will be done (yet) since you can't even read, let alone code.. |
01-02-2013, 01:18 AM | #1702 |
Rep 490
01-02-2013, 01:21 AM | #1703 | ||
Rep 145
Drives: F30 320ed
I don't have 606 nav only 6nh Bluetooth. |
01-02-2013, 01:26 AM | #1704 | |
Rep 40,788
ISTA/P 2.48.0 F010-12-11-501 ISTA/P 2.48.1 F010-12-11-502 ISTA/P 2.48.2 F010-12-11-503 When you get your car, you can read your I-Step (Integration Level), and you will see something like F010-12-11-503, which can be cross referenced to the ISTA/P version. However, sometimes its not so easy to pinpoint the exact ISTA/P version, because the I-Step can be the same for multiple version of ISTA/P. As an example: ISTA/P 2.47.5 F010-12-07-533 ISTA/P 2.47.6 F010-12-07-533 ISTA/P 2.47.7 F010-12-07-533 So your car has I-Step F010-12-07-533, but was it programmed with 47.5, 47.6, or 47.7? You can't know for sure without actually seeing the ISTA/P Measures Plan report. I used F10 I-Steps here, but for all 6 listed, the F30 I-Step matched the F10, albeit beginning with F020 instead of F010.
01-02-2013, 01:33 AM | #1705 | |
Rep 747
01-02-2013, 01:38 AM | #1706 | |
Rep 40,788
You can see that too in E-Sys. It will show your Current, Last, and Factory Original I-Steps.
01-02-2013, 01:39 AM | #1707 | |
Rep 40,788
I thought 606 Nav was always CIC-MID and that HU-CHAMP was used primarily in Mini's only, but it seems that is not the case.
01-02-2013, 03:26 AM | #1708 |
Rep 1,544
01-02-2013, 03:28 AM | #1709 |
Rep 1,544
01-02-2013, 03:30 AM | #1710 |
Rep 1,544
I think the CHAMP2 headunit for 606 have basic BT already built-in (like the L7 Entry w/6NH), so for 6NH there's no need for a castrated combox to do the BT work.
01-02-2013, 03:36 AM | #1711 | |
Rep 145
Drives: F30 320ed
Is the 606 HU the same as the 6NH HU? Assuming I could get the update discs and FSC? Also how do you add option codes? Sorry for all the Qs. |
01-02-2013, 04:17 AM | #1712 |
Rep 204
Removed country controller (Hong Kong) from the VO. Office is now working, album art surprisingly activated on my non-nav. However, Chinese characters (songs or messages) no longer showing in the English interface. Went to settings, noticed my other default languages (Trad. and Simp. Chinese) are still there. Changed the menu language to Trad. Chinese and all songs and messages are displayed properly. Question is how can I see Chinese characters again if I use English as language?
01-02-2013, 05:28 AM | #1713 |
Rep 40,788
To Modify FA:
01-02-2013, 06:13 AM | #1714 | |
Rep 490
lucky you! my car has to be left alone for half a day before the bluetooth option for Office & "Show Pictures" decided to show up. Tried with both iPhone 4S and Blackberry Bold 9900, though i could view email & sms from both phone, these messages only comes from the primary phone (I typically use iPhone as the main phone & BB as additional phone). Gut feels BB works better with Office, at the email address etc are laid out properly, whereas IOS always show unknown sender, with the sender name follows... I don't know if it's normal, when we receive new message (text/email), there isn't any notification or gong or whatsoever, the message just sit in the message box, and have to manually trigger it to read. And it only playback the message, does not support replies While VO coding, I piggy back it with 6AL (BMW Live) and 6UH (Traffic Info). BMW Live works flawlessly, but the traffic doesn't seem so (when I check the FDL code, the option to make it work in Singapore was still not active - no biggy, just turn em on manually again) |
01-02-2013, 09:27 AM | #1715 | |
Rep 1,544
L7 ENTRY itself doesn't have any nav hardware built-in. |
01-02-2013, 09:31 AM | #1716 | ||
Rep 1,544
See this post: Quote:
