BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > AC smell: I may have found an easier way to the evap coil
      05-16-2019, 02:52 PM   #23
IraHayes
Drives: 328i
Originally Posted by jkwhar View Post
Update: So to kick off the AC season, I went ahead and did this again, except I used klima this time. It worked a bit but still have the odor. My guess is, it doesn't reach the whole evaporator at the top. So back to the drawing board on this.
Also, I think the reason my first try worked was b/c it was masking the odor with a scent (Wasn't klima).
Jkwhar, maybe try this. Read from post 17 in this thread.
https://f30.bimmerpost.com/forums/sh...ghlight=mildew
      07-02-2019, 08:15 PM   #24
agad
agad's Avatar
Drives: 18' F32 435d M-Sport Plus
The only thing that would get rid of the smell is the Air Con Bomb spray. Buy a spray can and place it under the passenger foot well, close all windows, select the air recycle button on the climate control so air is sucked only from inside the cabin, turn the ac on and put the fan on max and then release the spray can lock on the nozzle. Get out of the car and leave it running for 15 minutes, then get inside and open all windows and leave the ac running on max for another 10 mins. Park the car overnight, start the ac the next day and enjoy the fresh smell!
I’ve used this method many times before and works a treat eveytime! I’d also advise to fit a brand new cabin filter straight after the treatment.
Cheers
      07-02-2019, 09:17 PM   #25
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The procedure I explained in Post #11 gets rid of the smell.
      07-23-2019, 03:15 PM   #26
jkwhar
Drives: F30 328i Xdrive | F15 x35i
Alright, after all this, it ended up being the filter. Replaced the filter, no smell. I'm on week 5 or so and its been hot and humid here. I did get a filter that doesn't contain activated charcoal to see if thats the culprit but its gonna be awhile before I report back on that.
I'd say guys, if it smells, just replace the filter and watch it go away.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      07-23-2019, 04:54 PM   #27
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
[ laughing ] ... jkwhar, you beat me to it. I was going to ask the question "Before you all take apart your dash and AC units, have you replaced the cabin filter yet?"
      08-06-2019, 11:16 AM   #28
saratkiran
Drives: 2015 328xi
air filter is fine in my case. Dealer is asking 70$ to clean the leaves or what ever .. is it worth it ?
      08-18-2019, 08:38 AM   #29
evdok
evdok's Avatar
Drives: 330D M/SPORT xDRIVE INDIVIDUAL
Bought some air-conditioning foam cleaner, Managed to get the tube around the bend and hopefully sprayed the evaporator also inserted the tube in all vents inside cabin, Will report back in due course if it works.
Happy Motoring
Evdok
      08-19-2019, 11:52 AM   #30
craeg
Drives: 2011 335i convertible
You can also use a portable garden pressure sprayer with the nozzle bent into a hook.
You remove the air filter and insert the nozzle into the air inlet behind the air filter. The hook will "go around the corner" and empty out on the top of the evap. The fluid will drain through and out the AC outlet under the car. I have done this several times in my car - unfortunately.
evdok822.50
      06-18-2021, 05:40 PM   #31
dadaabmw
dadaabmw's Avatar
Drives: BMW 650i, BMW M3, BMW X3
I came across this post while searching for a possible solution. My wife’s F30 had a weird smell whenever I would turn the AC on. So I thought it might be the cabin air filter. Today, I changed it. However, when I opened the area of the passenger footwell to access the filter, I noticed a yellow ring on the foamy-pad. I also noticed some yellow liquid on the blower motor right where the parts sticker is. Any help would be greatly appreciated. I have uploaded the picture here:
View post on imgur.com
      06-18-2021, 09:45 PM   #32
Billfitz
Billfitz's Avatar
The yellow liquid could be electrolyte that leaked from a capacitor that's used on the motor power supply. I can't say for sure, but it's one possibility. I'd have it looked at.
      07-05-2023, 03:40 PM   #33
hpopmds
Drives: F31
Can you just explain me if the engine should be running when we are injecting the foam?
Is thers any risks (short circuit)?
      07-05-2023, 05:03 PM   #34
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
This is how dealers clean the EVAP coil
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      03-01-2024, 03:09 AM   #35
ilovebmwx3
Drives: BMW X3 35i
F25 AC smell as well
Any chance the imgur picks from 2018 can be hosted again? I'm trying to do this to my X3, but I don't know where the AC drain hole is. Would be great if I could see the original images again. @jkwhar
      03-01-2024, 07:16 AM   #36
Billfitz
Billfitz's Avatar
I doubt many F30 owners will know where the X3 drain is, unless they happen to own an X3 as well. The best way to find it is to run the AC on a humid day, then trace where the water under the car is coming from.
      03-04-2024, 12:33 PM   #37
jkwhar
I tried reuploading but somethings failing. Might need to create a new account. I'll work on this a little later.
