BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > BMW Revises Recommended Oil Change Intervals to 10,000 Miles for 2014+ 3 and 4 Series
      07-08-2019, 04:46 PM   #23
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
Originally Posted by Chandra8 View Post
I think the back is m-sport but front is regular. If you look at the latest spy pictures, the headlights are different, and the side mirrors seems to have some kind of led lights too.
918kiss
WTF are you talking about?
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
      07-18-2019, 10:55 AM   #24
leejak
Drives: E92 M3, F12 6401ED, F32 428i
Hmmmm......my oil change interval is 8000 miles......that’s what I get when I reset after every change.....
      03-27-2021, 02:07 PM   #25
Primax
Portugal
Drives: BMW 420D F36 2015
And regarding transmission oil change?
      03-30-2021, 02:55 PM   #26
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
See attached. This is from ZF, note BMW says lifetime.
      03-31-2021, 06:19 PM   #27
Primax
Portugal
Thank you! I've already booked ZF for oil and filter change by "dialysis" method (they force new oil until it comes out clean).
I'm having now and then small hesitations in gear change (AUTO and in confort mode), at low rpm ~1400rpm, it may happen in all gears even 7th to 8th. Did the throttle pedal reset, besides only having yer 120k km, i hope that this oil change will fix it.
      06-19-2021, 03:10 PM   #28
Jeff_D
Drives: BMW 340iX
Does anyone know if 3rd party shops can have the right electronic equipment for the car to pick up the new oil change intervals? (or is this another dealer-only situation?)
Thanks
      06-19-2021, 07:17 PM   #29
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Thanks
Just about any trans shop has a fluid exchange machine which may have adapters for the ZF8HP.
However, per ZF the proper method is a simple pan drop and new fluid. The torque converter does not hold a lot of fluid.
So, no to the fluid exchange machine.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      06-19-2021, 07:48 PM   #30
auburnf30x
auburnf30x's Avatar
435
Drives: 2017 BMW 330i xDrive
Same for engine oil changes. Aside from the dipstick, it’s exactly the same method and tools as any other car on the road.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim
      06-19-2021, 10:57 PM   #31
edycol
Drives: 2011 328i xDrive
Thanks
Only thing that needs to be done is reset adaptations on transmission and transfer case after fluid change. Any shop with bit better OBD scanner can do it.
      06-20-2021, 05:52 AM   #32
Polo08816
Drives: 2014 335i M Sport
You don't actually need to do that. On a perfectly functioning ZF 8HP, it should not affect performance or operation.
      06-20-2021, 07:39 AM   #33
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
+1.
Unlike the ZF 6HP no reset required.
      06-20-2021, 11:56 AM   #34
edycol
You have to tell DME that fluid is changed. That is what resetting of adaptations does, for both transmission and TC.
      06-20-2021, 11:57 AM   #35
edycol
+1.
Ok, but TC absolutely has to be resetted. I personally would reset transmission too.
      06-20-2021, 12:57 PM   #36
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
I seem to remember that there's no option for it under ITSA for this particular transmission.
      09-13-2021, 01:58 AM   #37
dd999
Drives: BMW f31
Thank you !
      03-22-2022, 06:35 AM   #38
claderknz
New Zealand
Drives: BMW 320i M Station wagon
Great info - thanks
