BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > WeissLicht Spektrum LED turn signals
      09-22-2014, 10:37 AM   #67
capt_slow
capt_slow's Avatar
Drives: 2017 F31 328d
Originally Posted by Steve33 View Post
Just to add on to this, I needed a Torx T25 bit, same with you?
Yep. On certain F30 builds, there are two T25 bolts right where the warning triangle should be. However, on 2015s I've seen them replaced with plastic rivets.
You also need to detach the glow-in-the-dark emergency trunk release from the steel cable in order to completely remove the trunk-lid liner.
      09-22-2014, 01:42 PM   #68
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Just double checking.
I might just remove the emergency release, when I lock people in my trunk I don't want them to be able to get out
      09-23-2014, 08:40 PM   #69
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Alright, do y'all want to see blinker or brake lights?
      09-26-2014, 08:01 PM   #70
richie_s
Drives: 335i x drive M sport (F30)
Originally Posted by betlion View Post
jdmtoy.com have a similar led signal for $35/pair
error free, plug n play
colors available in amber, white, blue and red
Really? Sounds too good to be true...
      09-26-2014, 08:02 PM   #71
richie_s
Both!
      09-27-2014, 09:20 AM   #72
bmw_fascinated
bmw_fascinated's Avatar
Drives: F22 228i
@ capt_slow
I would be very interested in the beam pattern behind the car and on the ground. Is the light distribution comparable with stock bulbs?
      09-27-2014, 12:57 PM   #73
Steve33
Steve33's Avatar
Drives: 2018 SQ5
Originally Posted by bmw_fascinated View Post
@ capt_slow
I'd say so (assuming you're referring to the reverse LED's)
      10-02-2014, 11:16 PM   #74
capt_slow
capt_slow's Avatar
My red LEDs just shipped yesterday!
      11-07-2014, 05:22 PM   #75
Yuqi
Drives: 14 335i Xdrive
I want to replace the OEM rear turn signal and brake bulbs. Do you know if WTS302RRY and WTSZZA8R2 are the same thing?
      01-10-2015, 06:32 PM   #76
wingnutsglory
Drives: F30 335i 6MT
I've been looking for the best reverse LED upgrade and had almost purchased some Weisslichts this afternoon when I thought about the flickering issue. Does anyone know if the system checks the reverse lamps with the same regularity as the turn signals? I don't mind the light show at startup but I'd prefer not to flash drivers behind me at night, and I'm totally unfamiliar with coding.
Thanks!
      01-10-2015, 07:20 PM   #77
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Thanks!
Believe the warm check interval is 3 minutes, regardless of use -- that is same for reverse as turn signals. Unfortunately, as has been discussed above, there is no way that the flicker due to the system warm checks can be eliminated without coding, which is really quite straight forward three items for each bulb.
Al
Retired: 2014 328i
BMW CCA
      01-22-2015, 02:50 PM   #78
maikel
Drives: 2015 435i GC M Power
ijdmtoy LEDs errors
20-005 CAN-bus Error Free 18-SMD-5050 PY24W 5200s LED Bulbs For Audi BMW Mercedes, etc Front Turn Signal Lights
[Color:Xenon White]
I purchased these and they do in fact throw up errors. Working with them now to try and return/replace. It's too bad because they actually look great especially light up at night. The color is just a hue off factory.
Also purchased these before which have the wrong base even though part # is the same... py24w.
http://www.khoalty.com/bmw-e90-e92-l...-led-bulb.html
You can't close the cover cap with these bulbs on a 15' 435gc but Khoalty thinks they should work and won't give a refund.
      02-02-2015, 06:24 PM   #79
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
Video of LED brake lights (WeissLicht).
      03-14-2015, 01:10 PM   #80
RSnic
RSnic's Avatar
Originally Posted by AnhQuan420 View Post
Need help....
I ordered 3 pairs of WeissLicht for front, rear turn signal and reverse indicator bulbs. Anyone can help me for coding?
Can I use this for all turn signal and reverse indicator?
"Of course, there are the three items to code for each light so there is no periodic flickering due to bulb checking:
XXX_X_KALTUEBERWACHUNG -> nicht_aktiv
XXX_X_WARMUEBERWACHUNG -> nicht_aktiv
XXX_X_IS_LED -> aktiv "
Thank you very much for any help!
AnhQuan420,
Sure; please try these to fill in for the XXX:
  • FRA_V for FRONT Turn signals in FEM
  • FRA_H for REAR Turn Signals in REM
  • RFS for REVERSE lights in REM
For the single _X_, it is either L for LEFT or R for RIGHT
So to code the right rear turn signal, go to REM:
  • FRA_H_R_KALTUEBERWACHNUNG from aktiv to nicht_aktiv
  • FRA_H_R_WARMUEBERWACHNUNG from aktiv to nicht_aktiv
  • FRA_H_R_IS_LED from nicht_aktiv to aktiv
That should do it
Al
Retired: 2014 328i
BMW CCA
      03-14-2015, 01:29 PM   #81
tboooe
tboooe's Avatar
925
Drives: F36 428i GC, E36 M3 - gone :(
Xin chao anhquan420
To be a bit more specific here is what you need to code:
Rear Turn Signal
REM / 3061 / FRA_H_L_KALTUEBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / FRA_H_L_WARMUERBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / FRA_H_L_IS_LED from nicht_aktiv to aktiv
REM / 3061 / FRA_H_R_KALTUEBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / FRA_H_R_WARMUERBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / FRA_H_R_IS_LED from nicht_aktiv to aktiv
Front Turn Signal
FEM_BODY / 3061 / FRA_V_L_KALTUEBERWACHUNG from aktiv to nicht_ aktiv
FEM_BODY / 3061 / FRA_V_L_WARMUERBERWACHUNG from aktiv to nicht_aktiv
FEM_BODY / 3061 / FRA_V_L_IS_LED from nicht_aktiv to aktiv
FEM_BODY / 3061 / FRA_V_R_KALTUEBERWACHUNG from aktiv to nicht_ aktiv
FEM_BODY / 3061 / FRA_V_R_WARMUERBERWACHUNG from aktiv to nicht_aktiv
FEM_BODY / 3061 / FRA_V_R_IS_LED from nicht_aktiv to aktiv
Reverse
REM / 3061 / RFS_L_KALTUEBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / RFS_L_WARMUERBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / RFS_L_IS_LED from nicht_aktiv to aktiv
REM / 3061 / RFS_R_KALTUEBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / RFS_R_WARMUERBERWACHUNG from aktiv to nicht_aktiv
REM / 3061 / RFS_R_IS_LED from nicht_aktiv to aktiv
My build thread
2015 428i GC - Alpine White - Coral Red - M Sport
      03-26-2015, 10:35 AM   #82
RSnic
RSnic's Avatar
Thank you so much RSnic and tboooe!
Can anyone confirm the reverse bulbs on F30 and on F32 are the same? Because I asked bimmian.com and stealthauto.com about this already. But they said Weisslicht Reverse LED bulbs can only use on F30.
Anyone install Weisslicht LED Reverse bulbs on F32?
Glad to have helped. I put LVL302VWY in my F30 reverse lights; suggest you ask Bimmian if that will work on your F32
HOPE THAT HELPS
Al
Retired: 2014 328i
BMW CCA
      03-26-2015, 12:11 PM   #83
tboooe
tboooe's Avatar
925
The reverse lights are different. For F32 look for PW24W. I bought these off ebay and they work fine:
http://www.ebay.com/itm/371271291551...%3AMEBIDX%3AIT
My build thread
      05-31-2018, 07:49 PM   #84
effthirty
effthirty's Avatar
Drives: 2014 F30 335xi
Question Coding F30 Flickering
Hey guys...newb here.
I just picked up a 2014 335xi and swapped all the incandescents with WeissLichts, front/rear turns, brake lights, reverse lights. They look pretty sweet so far, but I am getting the flickering mentioned previously.
The code was provided, and I have a usb to OBD cable, but what software is needed to code my ride from a Mac or PC?
- Learning Newb
      05-31-2018, 09:17 PM   #85
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
http://f30.bimmerpost.com/forums/sho...d.php?t=696777
      02-03-2019, 03:39 PM   #86
ivancho111
Drives: skoda superb
Hey, guys. I've been looking for the Weisslicht WTS302RAY Amber Turn Signals for F30, but it appears they're out of stock on every single website.
Moreover I live in Europe and can't find a reseller here.
Is there an alternative which is sold in Europe?
      02-03-2019, 04:39 PM   #87
Billfitz
Billfitz's Avatar
Look on your local Amazon.com. Search for Philips, Osram and iJDMTOY brand. There's nothing special about Weisslicht. They appear to be seriously over-priced re-labled Asian bulbs.
      02-04-2019, 04:17 AM   #88
ivancho111
Weisslicht are said to be error-free without using a Canbus adapter.
bulb, led, spektrum, weisslicht
