04-18-2015, 11:42 PM | #155 |
Rep 341
Yeah I think we need to figure really which way they are facing. I'm not sure what is the degree of the sensors so off they detect equally the same all around I guess it doesn't matter which way the plugs are facing.
04-19-2015, 01:13 AM | #156 | |
Rep 1,035
For the CA, did you figure out where those 5 wires go from the door handle harness to the FEM? I couldn't find them anywhere in ISTA/D to save my life... |
04-19-2015, 01:42 AM | #157 | |
Rep 341
As far as the wires I couldn't figure out where that extra 1 wire was going. All the schematics said 4 wire + ground. I do know where the 5 wires go and they match my current setup.. So I'm going by based on my options a new locking mechanism isn't needed. We will know when the wiring harness arrives. If it has 6 wires going to the door locking mechanism then I'm in trouble. Lol Last edited by f30GTR; 04-19-2015 at 02:18 AM.. |
04-19-2015, 02:27 AM | #158 |
Rep 1,397
i fixed my lag with sanding down and repainting again.
I asked my body shop how they painted it (not blaiming them just wondering) they said 1 coat of primer. 3 coats paint and 2 coats are clear. (ontop of the already black painted sensors I sanded down all the way past the original black paint. applied 2 coats paint and one clear coat with the touch up pen (sanded in between layers too keep things smooth). put it back on my car and BAM lag is gone |
04-19-2015, 10:37 AM | #159 | |
Rep 1,035
04-19-2015, 11:22 AM | #160 | |
Rep 176
I haven't got an email from Partsale but I guess it's coming... |
04-19-2015, 11:47 AM | #161 | |
Rep 341
I didn't use primer. As far as partsale they won't send you one unless you ask for status on your order. Last year it took 3 months to get my pdc cable but I was hoping I can get the back up camera little faster but right now I'm at 2 and half. We just have to wait. |
04-19-2015, 06:01 PM | #162 |
Rep 1,035
crap... 3 months? its been only a month for me before i got impatient and sent them a query. fortunately then, i decided not to wait till that PDC order arrived before ordering the camera retrofit cable kit - pulled the trigger on that order last Thursday. lets see if we both get it at the same time...
05-17-2015, 01:05 AM | #163 |
Rep 1,369
I've been reading this post with great interest as I too would like to retrofit PDC to my car. Some quick questions:
I see that f30GTR tried using the latest REM but was wondering if that's more hassle to deal with coding issues rather than waiting for a 700 to appear on Ebay? I'm still clueless on coding. I just got an ENET-to-OBD cable but now need a quick primer in how to code the car. There's a lot of stuff to go through. Can someone PM me a link to the best way to get started. I don't want to brick my car or disable half of it when I swap out the REM. BTW this a fantastic post. Thanks to all who have contributed. |
05-17-2015, 09:38 AM | #164 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
I was cluseless as well about a 1 1/2 yr ago, but thanks to this Forum and BimmerFest, my hands a re no longer sweaty. Here's a couple of threads to help you along: http://f30.bimmerpost.com/forums/sho...d.php?t=696777 http://www.bimmerfest.com/forums/sho...d.php?t=631884 http://www.bimmerfest.com/forums/sho...d.php?t=638188 Suggest you contact ShawnSheridan through either this forum or BimmerFest; please use the coding forum to do so. Shawn is truly one of the real gurus and a great knowledge source; he can also provide the needed program, E-Sys, and data to code with Hope that helps
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA |
05-18-2015, 11:59 AM | #165 | |
Rep 1,369
Now if I can just get that retrofit kit. How dumb is it that in North America you can order PDC for your car but not the wire that connects PDC to the car? What magic is required to get that cable out of the clutches of the dealer? So someone rear ends my PDC-equipped car and it takes a week to replace the bumper and a month to fix PDC? Will try again tomorrow with the dealer 'insider'. TIP: I guarantee that if there is hole or gap, no matter how small, a bolt or screw will fall into it. Just as a black hole can suck in light, small, impossible to reach gaps will grab one, and only one, critical screw or bolt. Of course that getting that bolt or screw back will ruin your afternoon and turn an easy job into total hell. The secret is to simply block all holes, gaps or other places screws can fall into with a rag or cloth. This has saved so much time it should be in every instruction manual. If anyone was successful at getting the cable let me know. I guess I need the mounts as well. Oh, and those BMW tie wraps. Maybe the Polish place has a kit. |
05-18-2015, 12:14 PM | #166 | |
Rep 1,035
THe mounts and the other smaller pieces can all be ordered state-side from various on-line sites. Don't understand why ordering the cable is such a bitch.. |
05-18-2015, 12:17 PM | #167 | |
Rep 1,369
Could it be manipulated to fit into the connector? http://www.ecstuning.com/ES2599466/ Last edited by casualDIYer; 05-18-2015 at 01:46 PM.. |
05-18-2015, 12:38 PM | #168 |
Rep 1,479
MennCars,
Here's something that may help. Just checked ECS Tuning and they had the following listed:
As I checked my records, in fact, I did like Roxxor and SquidlyBoy and ordered the above two items from PartsSal.EU -- and it took a little over 2 months to get to me.
Al
05-18-2015, 12:49 PM | #169 | |
Rep 1,035
Hey Rsnic - is this the same/compatible retrofit cables for the front PDCs - i.e. 66202338070? I haven't ordered mine yet (wasn't looking forward to waiting another 2 months). Sounds a little too good to be true (and the cost seems like its waay too good to be true at $31) |
05-18-2015, 12:53 PM | #170 | |
Rep 1,479
I don't think so -- that's why I ordered from non-US source and waited like you are doing now.
Al
05-18-2015, 10:37 PM | #171 | |
Rep 1,369
I've looked at these parts and there is a possibility they might work: 51120432250 - PDC Sensor mounts (Non-M) ~$30 61119293040 - PDC Repair cable ~$20 12527545858KT - Bushing pack of 10 ~$10 So roughly $50 but no rubber rings. Could be a problem. I'm guessing the sensors when sold new have them. I also wonder whether it's better to feed the wires through the existing grommet that has wires running through it or order the kit and cut a new hole in the sheet metal. My only concern is, once cut how do I ensure the cut surface is treated properly for corrosion? I'd like to avoid cutting sheet metal so as not to have a that problem. |
05-18-2015, 11:07 PM | #172 |
Rep 1,035
Yeah, I wasn't sure why Rsnic was quoting you cables for the front PDC's in the rear PDC retrofit thread. I only asked him about them since i'm looking for the front kit myself (for later).
And for the front PDC, he said the repair cable was not going to cut it as far as trying to do a retrofit goes. I gotta guess the repair cable for the rears isn't going to work either, so i'm doubly confused why he listed it. I think i paid a little over $100 for my rear PDC retrofit kit (66202339614). But at $20, maybe its worth the risk to see? Worst case is that you can sell if its not right. As far as the hole goes, Roxxor seemed to indicate in his OP that even though he used the existing hole, it was a PITA to get the grommet back into the hole (don't know if he eventually got it back on or not), and he didn't recommend it. I'm planning on cutting a new hole myself, but i live in a very dry arid desert environment where rust and corrosion is not an issue. Seems like you are going the budget route.. if you get the Ebay VataPro sensors, they come with the rubber rings. You may also want to get some BMW touch up paint to match the color if you care about that. |
05-19-2015, 07:19 AM | #173 | |
Rep 1,479
Sorry for the confusion; I mistakenly went back through all of the parts I ordered and shouldn't have listed front PDC cables; indeed, the eBay VataPro sensors come with plastic rings
Al
05-30-2015, 12:57 PM | #175 |
Rep 1,369
FYI: Latest REM (61359362394)
Just waiting for parts to come in with the REM being the first to arrive two days ago. It is a fully loaded REM with all pins. See photo. The part number is
61-35-9-362-394 (61359362394 for those searching on this instead of a dashed part #) If my sensors arrive with rings I'll see if I can use the repair kit to attach the sensors to the REM. If not, I'll need to grab the upgrade kit from somewhere. Will update as I proceed. As far as I know I should be able to add the new REM by injecting the CAF file using only Esys. Is it as easy as previously described by RSnic? Or should I get a hold of another tool? Last edited by casualDIYer; 05-30-2015 at 01:08 PM.. |
05-30-2015, 02:50 PM | #176 | |
Rep 1,479
I guess the REM you ordered is the "newest" part as the one I got (which is working fine) is 61359329700. The change out of the REMs was easy, but watch the little plastic latches (I inadvertently snapped one -- but so far no problems) -- if I recall a couple of bolts and connectors as per Roxxor's original instructions. Once you have swapped out REMs, hook up E-Sys to your car; here's what I did to inject CAFD into the new REM:
If you ordered your sensors from VataPro on eBay, they'll come with opaque white plastic rings. Hope that helps
Al
