07-08-2014, 03:12 AM | #221 |
Rep 32,881
07-08-2014, 03:43 PM | #222 | |
Rep 12
....and that ladies and gents is that. Top work there Shawn, I have a mate who works at BMW and might ask him about sourcing a code but like most people who work there..he will probably have no clue. |
07-10-2014, 03:41 PM | #223 |
Rep 459
Another massive thanks to Teaston's and Shawnsheridan.
Got it up and running this evening. One little transient glitch to report in case it helps others. When idrive rebooted, office function was available. I deleted my Bluetooth pairing, then added it as a fresh connection. However initially, it only gave me the options for allowing phone and audio when configuring it in Bluetooth options section. I was a bit downcast at this point but I went in to the office menu and lo and behold my messages were all listed. I went back to Bluetooth configuration screen and the the options for office and 2nd phone functions were highlighted and already ticked! Strange. My phone is a blackberry Z10 UPDATE: this morning for some reason, the car still shows the emails, texts etc fine, but the bluetooth config screen has reverted back to how it was when I first did it. A phone issue I suspect, Office function is still working Last edited by evan15281; 07-11-2014 at 06:39 AM.. Reason: update |
07-10-2014, 06:52 PM | #224 |
Rep 19
Thanks
07-11-2014, 03:09 AM | #225 |
Rep 32,881
08-01-2014, 07:45 AM | #229 |
Rep 459
So new phone Samsung Galaxy S5 arrived this morning.
Streaming and SMS messages working fine but for some reason, now my emails not visible. Anyone got any thoughts / suggestions?? |
08-02-2014, 05:43 AM | #230 | |
Rep 32,881
According to the BMW bluetooth compatibility checker every office function won't work with the S5 even with pro nav and ebt! So looks like you're lucky to even get sms! Last edited by teaston; 08-02-2014 at 05:49 AM.. |
08-02-2014, 06:50 AM | #231 |
Rep 179
I've never found a way to do it. The whole office thing just seems to rushed and still needs loads of work, but there doesnt seem to be any updates!
09-21-2014, 10:24 AM | #232 | |
Rep 12
Hi, I need some help please!
I've just tried to code EBT on my new 4 series (came with Pro-Media and Connected Drive, so I switched the option to 6NL). I followed the steps in the first post in this thread, and the PDF guide that came with the ESys software (the "change FA with esys"). This all worked fine. I have coded 6NL to the car and when I read the options back it's definitely there. But, when I move onto the steps in teaston's first post - step 4 - there's a problem. I right click on HU_NBT and click Code, and the coding window comes up. However I get the following: Quote:
Please can someone help? Thank you |
09-21-2014, 10:28 AM | #233 |
Rep 40,771
You have a post 0713 build car. You should be using 6NS, not 6NL.
09-21-2014, 10:39 AM | #235 |
Rep 12
Actually I'M really confused, I've just looked at the iDrive and it doesn't have any of the options it had previously - connected drive has gone etc etc. Please can you advise?
09-21-2014, 10:45 AM | #236 |
Rep 40,771
Yes, do as I last instructed you. Change 6NL to 6NS and VO Code Head Unit.
09-21-2014, 12:29 PM | #237 |
Rep 1
Does anyone know if this would work on a 2012 BMW 328i with iDrive & pro nav? I have bluetooth phone but no bluetooth audio (music/podcasts/etc.).
I'd also really appreciate it if anyone can help me out and walk me through it. I've never done anything like this before. |
09-21-2014, 12:32 PM | #238 | |
Rep 40,771
See my post here: http://f30.bimmerpost.com/forums/sho...65&postcount=9
10-12-2014, 08:36 AM | #240 |
Rep 12
Well huge thanks to shawnsheridan for getting this working for me!
Quick question, under; In idrive go to 'telephone' => 'Bluetooth telephone' => highlight your phone => press option or click right => go down and select 'configure Bluetooth' What does the "Telephone 2" option mean? Do I tick this only for the other phone I want connected? (I need 2 phones on BT to make/receive calls) Thanks *edit* Actually I'm more confused, now both my phones have "phone 2" ticked! Is there an easy way to switch between them when I want to make a call on one or the other? Is there a voice command or shortcut I can add to my shortcut buttons for this? Thanks Last edited by Endeavour99; 10-12-2014 at 08:44 AM.. |
12-19-2014, 07:06 PM | #241 |
Rep 88
Confused.com
About 3 months ago I successfully coded EBT. I have a Feb 2014 F31 with prof nav and connected drive. It worked first time, option of BT audio and phone 1&2. Then I went into BMW site and noticed an update for software so flashed that with USB in car. Then... Bought an iPhone 6. I know only have BT audio and phone1! I changed back to 6NH from 6NS I had coded, then redid with a VO code to HU_NBT. Still only phone1 and BT audio. I have full voice, Siri & messages, but no phone2. Any ideas? Shawn? Teaston? Also I FDL coded loads, so easy and great fun. I put up the merry Christmas STARTUP_EMBLEM for my son, but I have only seen it after the HU restarted post-coding. When should I or how can I make it appear?? Cheers in advance and Merry Christmas!
F97 Brooklyn Grey X3M Comp /// In Transit...
"Rules are for the obedience of fools and for the guidance of wise men..." Douglas Bader |
12-20-2014, 03:21 AM | #242 |
Rep 1,152
rOckypilot,
For EBT, from memory I think you also need to flash the media box, for NBT it'll be called something 32 in the name Last edited by JonD; 12-20-2014 at 03:31 AM.. |
