02-11-2013, 02:25 PM | #23 |
Rep 89
Researching this myself: 19" vs 20" aftermarket. My OEM 18" are 26" diameter and the 20" options were 26.3" front and rear 26.2". Not sure how much room there is to play, but I was using those numbers as the max height in my research.
First and foremost I feel the car needs WIDER treads all around. So far the issue I'm seeing with the 20" is if you go wider than 255's in the rear then your looking at a 25 series tire it seems. I had the 295/25-20 Nitto Invo recommended which is 25.79" diameter. Whereas with 19" there are plenty of 26" diameter tires wider than 255's. There's even 295/30-19 options that are 26" (Michelin & Bridgestone). Keep in mind I'm looking at mainly 'Max Performance' summer treads. |
05-23-2013, 09:37 PM | #25 | |
Rep 89
imo; You just have to get the right offset. I've got 275/30-20's in the rear with ZERO issues, and they're sitting on 20x10's. 100% custom made Forgeline rims. 245/30-20's in the front on 20x9's.
2012 F30 BMW 335i
8sp; Red; Sport, 20x9f; 20x10r (wearing 245/275's) Bronze Forgeline DE3C's, M-PPK, Challenge HFC-DP. Winter Setup: 18x8 Black Enkei's with Blizzaks! |
07-18-2013, 02:23 PM | #26 | |
Rep 1,136
sent from bimmerpost Android app
07-18-2013, 02:43 PM | #27 |
Rep 89
No idea. I called up Forgeline and they did the rest. They'd already made 20x9's all around for an F30 and knew there was a little more room they could tweak out I guess.
Btw, here's a pic:
2012 F30 BMW 335i
07-27-2013, 01:17 AM | #28 |
Rep 1,136
I'll be getting some new wheels soon: 20x8.5, ET 35 front and 20x10, ET 40 rear. I am on sportline and want to know if I can run 225 or 245/35/20 front and 255/35/20 rear. Will that setup work for me?
07-28-2013, 10:50 AM | #29 |
Rep 88
08-05-2013, 08:24 AM | #30 |
Rep 89
Thanks....
F: 20x9 on 245/30 R: 20x10 on 275/30 Forgline DE3C's wearing Hankook Ventus V12 Evo's. I think I could have squeezed in the 285's in the rear actually. Once you start looking for staggered tires, you don't have a ton of choices. I think I had like 4.
2012 F30 BMW 335i
02-01-2015, 09:33 PM | #31 |
Rep 17
I have the ANSWER!
I wanted to know this a while back and couldnt find the right answer so here is what I think is the closest.
I currently have a F32 435 I have 20 x 11 wheels with a 35 offset in the rear: tires 285/30 20 x 9.5 in the front :tires are 245/30 all nitto invo I had an e92 before with rolled fenders and I rubbed fairly consistently on the sidewall but with no damage to vehicle and very little noticeable wear to the sidewall of the tire. I just switched over to the f32 and I went over all of the big dips i feared before on my e92 and no problems at all. I hope this info helped......btw does anyone know the TRUE tope speed of the f32 435.....everything I can find only tells me the 155.....I want to know the real number, I cannot find it ANYWHERE. |
02-01-2015, 09:47 PM | #32 |
Rep 105
Drives: 2015 335 xDrive M Perf Ed -LSB
06-11-2016, 05:01 PM | #34 |
Rep 585
Drives: Mercedes AMG C63S
275/30/19 This what I'm running with.
Porsche 991.2 Carrera S
Mercedes AMG C63S (W205) BMW F80 M3 BMW F30 335i M Performance Edition BMW E92 335is BMW E92 328i Lancer Evolution X MR |
12-15-2017, 10:03 PM | #36 | |
Rep 34
12-26-2017, 09:20 PM | #38 |
Rep 621
Any insight would be greatly appreciated
Car in question 2014 EBII 335xi I wanna run M5 wheels 19x9 et32 19x10 et34 how is this achievable without ruining the AWD system. Thanks in advance |
10-05-2018, 08:19 PM | #43 | ||
Rep 50
BMW, just a pleasure to drive it everyday depending on the car you?re driving from BMW?
