06-25-2021, 03:38 PM | #1 |
Rep 54
Hi,
I purchased a used 2015 335 last year, and discovered small bubbles forming on the side of the wheel well a month ago. I brought it up with my SA. SA told me to have a body shop next to the dealer inspect the paint. The body shop confirmed the car had never been painted before by using their paint meter and gave me an estimate to give the dealer. SA seems to be dodging my calls so I scheduled an appointment. I heard BMW NA is really stingy with these claims and denies them for not having yearly rust inspections (it does not mention this in the warranty booklet). Some also say BMW NA doesn't cover perforation/surface rust but some say BMW NA does. The warranty booklet doesn't mention anything about BMW not covering surface rust either. Has anyone ever successfully dealt with BMW NA and their corrosion warranty? Any tips? Thanks |
06-25-2021, 03:40 PM | #2 |
Rep 4,904
Not sure BMW deals with it, but with General Motors, it basically has to rust through the panel in order for them to address it.
So basically the "rust and corrosion warranty" is just a bunch of BS fluff that they never cover since NOBODY would let their car get to the point you can put a finger through the metal. |
SMFD218.50 |
06-25-2021, 09:49 PM | #3 |
Rep 16,141
Mt ex's Ford developed rust, bubbling the paint but not perforated, and they fixed it without any hassle. I don't know what the Ford warranty says, but mine says: BMW of North America, LLC (BMW NA) warrants this original vehicle against defects in materials or workmanship which will result in rust perforation of the vehicle body for a period of 12-years unlimited mileage. That would rule out surface rust being covered.
SMFD218.50 |
06-26-2021, 08:25 AM | #4 |
Rep 377
No experience in the US, but I had my Z4MC trunk lid repaired under the body/paint warranty when rust appeared underneath it when it was about 8 years old.
It definitely wasn't external perforation damage as it's protected by being closed most of the time, and it looks like it's caused by a design fault where moisture doesn't drain away properly and sits in a little 'well' that the lid sits in also. The repair obviously was only a short-term solution, as they've not fixed the cause, as it happened again 5 years later...now out of warranty |
SMFD218.50 |
06-26-2021, 12:26 PM | #5 |
Rep 4,904
Problem is rust is NASTY to get rid of. It literally is a cancer for metal, with the only real fix is to cut out the problematic portion and replace.
I've tried neutralizers, and other things, and like the post above, it just becomes a short term stop gap. |
SMFD218.50 |
06-27-2021, 10:50 AM | #7 |
Rep 4,904
Not sure how your fender is, but my GM pickup started doing that. I fixed the outside, it bubbled back. When I finally pulled out the taillights to look, it was rusting from the inside (wheel side) out. The truck was past warranty, so I couldn't claim it, but keep in mind that "surface bubbles" might actually be coming from the other side.
Just put that in back pocket to ask if you get any flack at the dealer. |
SMFD218.50 |
06-27-2021, 12:33 PM | #8 |
Rep 16,141
Surface bubbles are almost always the result of rust coming from the other side. That's why treating or painting it doesn't work. You have to remove the affected metal, do a proper repair, and then find out where the water is coming from and fix that.
SMFD218.50 |
06-27-2021, 01:02 PM | #9 | |
Rep 54
Thanks |
08-15-2021, 12:36 AM | #10 |
Rep 54
UPDATE:
So BMW NA approved my claim and the dealership I went to had a body shop that they're affiliated with just replace the quarter panel. Total cost of the job was around $3500. Also took almost a month and a half. New quarter panel looks great. The shop did leave some adhesive on my door and the carpet that goes behind the battery cover near the quarter panel/bumper was all ripped up and hanging and obviously in the wrong place, but I'm not gonna complain about all that stuff because it seems minor and I didn't have to pay anything. Overall pretty happy with the work and paint matching, orange peel, etc. Thanks for all your help! |
davidr3447.50 |
08-15-2021, 12:01 PM | #11 | |
Rep 259
Garage:
2020 F32 440i 6MT 2018 Mazda 3 6MT 2013 Mazda 3 6MT 2008 Honda Oddyssey |
08-15-2021, 12:05 PM | #12 | ||
Rep 54
08-15-2021, 04:58 PM | #14 |
Rep 6,313
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
What dealership did you use?
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
SMFD218.50 |
08-15-2021, 04:59 PM | #15 |
Rep 54
tturedraider5089.50 |
08-15-2021, 06:18 PM | #18 |
Rep 6,313
Glad to hear BMW stepped up for you!
