BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Anyone code a 2014 yet?
      08-29-2013, 01:38 PM   #1
Frank_NJ
///M Specialist
Frank_NJ's Avatar
Drives: E30 M3, E52 Z8, G83 M4Cx
Anyone code a 2014 yet? Trying to code video in motion with no luck.
2023 M340ix my Daily Driver
G83 M4CV, F80 M3 CS, E30 M3, Z8, other various BMW's
Ferrari F8
      08-29-2013, 01:41 PM   #2
F"irst"30
Drives: 2014 320ix Imperial Blue
Looking for codes to turn on Sat radio. Dealer wants $450.00 and is doing me a "favor." 2014 320i with Nav package
      08-29-2013, 02:17 PM   #3
steve@codemybimmer
steve@codemybimmer's Avatar
Hong Kong
663
Drives: 2020 G20 320i M Sport
I've coded a 2013 M5 and a 2013 528i both which have HU_NBT. I did notice that the handbrake thing was just called "Video_Handbrake" instead of what it used to say in German. You also have to change the min km and max km values to FF just like any other car with HU_CIC.
      08-29-2013, 04:15 PM   #4
HFW003
HFW003's Avatar
Australia
5683
Drives: 2024 M340i xdrive
I've also coded a 2013 with the NBT, mine, with no problems.
      08-29-2013, 05:05 PM   #5
PabloK
PabloK's Avatar
Drives: F30
As soon as my 14 comes I'm getting her coded.... A local buddy here on the forums will help me out.
      08-29-2013, 07:23 PM   #6
shawnsheridan
shawnsheridan's Avatar
I have sent you a source for 6F Sat radio FSC Code.
You will need to modify your VO to change 693_PREPARATION_SATELLITE_TUNER to 655_SATELLITE_TUNER, then Import and Activate the 6F Sat Radio FSC Code, and then VO Code the Head Unit (CIC or NBT).
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      08-29-2013, 07:47 PM   #7
F"irst"30
Thanks
Thanks for the info
      08-29-2013, 10:15 PM   #8
vithy
Drives: 2016 F30 328xi
Shawn, Would you be able to send me your source for FSC Code please. I have a Entry-HU has 693 on it.
Thanks
      09-02-2013, 06:12 PM   #9
Frank_NJ
///M Specialist
Frank_NJ's Avatar
Fixed it using 50.3 Daten files.
Ferrari F8
      09-02-2013, 06:34 PM   #10
carzaddict
Drives: 2015 Cadillac Escalade ESV
can you please send this to me as well, greatly appreciate it
      09-02-2013, 06:57 PM   #11
shawnsheridan
What SP-Daten version were you using before, and there were no updates to Exx Chassis in 50.3, so the 50.3 SP-Daten is the same as 50.2.
      09-02-2013, 06:59 PM   #12
shawnsheridan
Thanks
PM's sent.
      09-03-2013, 10:30 AM   #13
JesseS
Drives: BMW 3/15 DA-2
I have coded a 2014 F30 and successfully disabled all the speedlocks in the HU_NBT module.
What problem are you having?
      09-06-2013, 09:05 AM   #14
anthonydemont
Drives: 2013 335i sedan mineral gray
Can you send this to me 2? Thanks
2013 f30 335 msport, mineral gray, jb4 stage 2 map 7,straight 100 octane,er chargepipe,er catless dp, meth, quadtip muffler delete, 19'' Vmr 810 custom powdercoated enlaes cf front lip and side skirts added
      09-07-2013, 10:03 AM   #15
cliffdude
Drives: BMW F31 320d Eff. 07/2013
What are the hardware requierments for sat radio? I have a 2013 F30 with touch idrive and navigation pro. I am hopeing to code in internet bmw live or connected drive and BMW office for SMS functions.
      09-07-2013, 02:19 PM   #16
shawnsheridan
For CIC / NBT Head Units in North America, the SDARS (Sat Radio) Tuner is built-in to the Head Unit. If the car also comes equipped with S693A Preparation BMW satellite radio, then the antenna is already run from the Head Unit to the Shark Fin, and all that is needed to make it work is a 6F Sat Radio FSC Code imported and activated in the Head Unit, and then change the coding from S693A Preparation BMW satellite radio to S655A Satellite Tuner.
However, as I understood it, Sat Radio was unavailable in Europe, and I do not think the Head Units have the built-in SDARS Tuner rather instead they have DAB Tuners.
As for Office, BMW Live, and Internet, I think you need only option S6NSA Comfort telephony w/ enhanced Smartphone.
      12-31-2013, 10:00 AM   #17
Bimmer_80
Drives: 2014 328i
Hi, just got my 2014 328i, need info on how to activate the satellite radio option. Thanks
      12-31-2013, 10:04 AM   #18
shawnsheridan
That depends. Which Option did you car come with?
655_SATELLITE_TUNER
      12-31-2013, 10:17 AM   #19
Bimmer_80
Drives: 2014 328i
      12-31-2013, 11:05 AM   #20
shawnsheridan
Originally Posted by Bimmer_80 View Post
693
So, you need to buy a 6F SDARS FSC Code, Import and Activate it in the Head Unit, change VO from 693 to 655 and VO Code Head Unit.
      12-31-2013, 11:27 AM   #21
Bimmer_80
Drives: 2014 328i
I am a bit of a newbie at this. Where can I can buy this FSC and how do I do this change? Any guidance would be appreciated. Thanks
      12-31-2013, 11:40 AM   #22
shawnsheridan
I have PM'd you an inexpensive source to buy FSC Code from.
Here is my post detailing how to Import and Activate it:
When you got your SAT Radio FSC Code, you should have received 3 files:
e.g. xxxxxxx_006F0001.xml
e.g. xxxxxxx_006F0001.der (FSC Code Certificate)
e.g. xxxxxxx_006F0001.fsc (FSC Code)
E-Sys => Options => Settings => FSC Tab => Certificate Field:
Load FSC Code Certificate (e.g. xxxxxxx_006F0001.der)
E-Sys => Comfort Mode => FSC => FSC Field:
Load FSC Code (e.g. xxxxxxx_006F0001.fsc. The FSC Code file must first be Base 64 Decoded or else E-Sys can not read it. (Use B64Dec for Decoding - http://4mhz.de/b64dec.html).
FA Field: Select "Read FA" to use cars current VO.
Parameter Fields: (Example for Sat Radio FSC Code and CIC):
Diagnostic Address (hex) = 63 (99 in Decimal for HU_CIC; I think the same for HU_NBT)
Application Number (dec) = 111 (6F in Hexidecimal - In FSC File Name, e.g xxxxxxx_006F0001.fsc)
Base Variant = HU_CIC (CIC module name, e.g. HU_CIC, HU_NBT, etc.)
Upgrade Index = 1 (In FSC File Name, e.g xxxxxxx_006F0001.fsc))
Select "Upgrade FSC" to Import and Activate FSC Code.
Select "Check FSC Status", and you should see:
AppID 111
UpgradeIndex 1
SWTType SWTclassic full
FSCStatus accepted
FSCCertStatus accepted
With your E-Sys Package, you should have received "E-Sys - How to change FA in F-series car.pdf" which will explain how to modify your VO.
Lastly, to VO Code Head Unit, simply right-click on it and select CODE.
