01-09-2013, 02:42 PM | #67 | |
Rep 4,323
01-09-2013, 07:53 PM | #68 |
Rep 7
Does anyone have any suggestion for curing a rattling glove box door. It seems only to rattle when the car is cold. After 20 minutes it goes away, but it is really annoying that a car with 50 miles rattles.
01-10-2013, 11:33 AM | #69 | |
Rep 4,323
I'd get some foam tape and nicely lay it around the perimeter where the glove box door meets the physical closure.
01-24-2013, 08:46 AM | #70 |
Rep 95
i've had some rattling when it's really cold out and i'm accelerating over ~3000 rpm.
anyone else have this issue? seems liek once the engine is warmed up it is fine or if the car has been in a garage |
01-24-2013, 08:54 AM | #71 |
Rep 4,323
is there an SIB or whatever for this issue?
01-31-2013, 06:44 PM | #72 |
Rep 497
talking about rattles brings me back to issues i had in my HONDA.
rattles is what brought me to a BMW and now i'm having rattle issues on my steering wheel cover and wind noise when my sunroof is tilted up.. fwak
F85 (17) - DG/AB
F87 6MT (20) - Comp - BSM F80 DCT (18) - Comp - AW F30 6MT 335i - EBII |
02-13-2013, 09:15 AM | #73 |
Rep 4,323
So the squeak has somehow subsided substantially on its own, but a subtle low grade buzz-rattle has replaced it in the same area...I suspect there is a little piece of plastic that was rubbing, and driving to and from NJ this past weekend over the horrible expansion joints on the Tappan Zee probably freed the piece...
Unsure what others have done with this issue at the dealer, but keeping the thread uptodate in case others are having this problem. I'm taking it on Friday for them to look at it...
02-19-2013, 11:55 AM | #74 |
Rep 4,323
UPDATE: BMW couldn't find a SIB, but found that there was a lot of squeaking when the unit was taken out to diagnose the issue. Felt lining was liberally applied, squeaking is finally GONE.
There is a very light rattle over bumps, but I suspect that'll quiet down over time now that things will jostle in to place. I hope. Just wanted to let you guys know what to tell them to do...and bring a video of it in to you SA so they can diagnose easier than driving around and hoping it'll do it.
02-19-2013, 04:43 PM | #75 | |
In top form...
24
Rep 145
02-19-2013, 10:18 PM | #76 |
Rep 4,323
It came back. FML.
Comes from the dash area...I give up.
02-20-2013, 02:04 AM | #77 |
Rep 250
Drives: E82 N52 6MT A51
02-20-2013, 07:08 PM | #78 |
Rep 1,285
My dealer finally tacked down a rattle/squeak which was apparent at roughly 2,500 RPM under load. It was the heater box. A bother to get to and does require taking a good deal of the interior apart.
03-23-2013, 08:08 AM | #79 |
Rep 4,323
they replaced my Nav screen...and it still squeaks over bumps.
the heater box is an interesting solution...
03-23-2013, 09:22 AM | #80 | |
Rep 4,323
happens when the cabin warms up....
03-24-2013, 10:03 PM | #81 | |
Rep 4,323
03-24-2013, 10:42 PM | #82 |
That's life in...
Rep 46
Ultimately, I used a black piece of door/window weather stripping tape from Home Depot. In the photo (to highlight the problem area), I wedged a piece of felt padding (the kind you stick to the bottom of furniture to protect wood floors) in between the top of footrest and the plastic panel. You just need something (anything) to separate the OBD panel from rattling against the top of the footrest.
One full day of driving and the rattle is officially gone. This fixed my issue, but this solution obviously may not solve rattles that others have encountered. Good place to start though.
2013 335i xDrive, M Sport, Auto, 18" Wheel w/ All Season Tires, Black Sapphire, Leather Dakota Black, Burl Wood Trim w/ Pearl Gloss Chrome Highlight, Premium Package, Technology Package, Cold Weather Package, Dynamic Handling Package, HK Surround Sound.
03-25-2013, 12:37 PM | #83 | |
Rep 821
I give up as well. |
03-25-2013, 01:58 PM | #86 |
Rep 4,323
WTF?? After 20k it's STILL under warranty? My SA has been good to me, taking it back in...it's unacceptable for such an $$ car to have these minor issues/noises.
03-25-2013, 05:47 PM | #87 |
That's life in...
Rep 46
Done. Now posted in DIY under "Simple Rattle Fix"
Tags |
2012 3 series, squeaky noise |
