03-03-2015, 08:47 AM | #23 |
Rep 3,089
Thank you. You what would be really helpful is if you can take a pic of the leading or trailing edge of the side sill in relation to the body panel. I think to make this work the sill need to be pushed inward a bit and not follow the guide lines on the sill. This makes sense because the M4 wheel wells are wider.
03-03-2015, 04:19 PM | #25 | |
Pace Car Driver
1548
Rep 3,164
You starting to figure out what I was trying to say all along? |
03-03-2015, 04:35 PM | #26 |
Rep 3,089
Ha ha..thank you...I pieced it together looking at your pics. It took me a while because I am little dense...So the question is, if the sill has to be pushed in a little does that still look ok? I think enough of the sill shows unlike with the 3 series sill which seems to be too subtle. What do you think?
03-03-2015, 04:45 PM | #27 | |
Pace Car Driver
1548
Rep 3,164
I'm not trying to knock anyone here. This is just my experience and my thoughts. Nobody has done a DIY on these (that I've seen) for the F3x and I haven't seen any pictures of the underside......... |
03-03-2015, 05:00 PM | #28 | |
Rep 3,089
Since you have the actual sill, can you test fit? Move the sill in so that it sits where its supposed to and see where the mounting hole are. The double sided tap location is not a problem because I was planning on removing the existing one and added something stronger.
03-03-2015, 07:01 PM | #29 |
Rep 399
I had a friend help me with the install
Tboee is right about the front being pushed in pass the double sided tape Doing this yourself is a PITA !!! Last edited by betlion; 03-03-2015 at 08:26 PM.. |
03-04-2015, 05:43 AM | #32 | |
Rep 149
Drives: 435ix,GTR, Huracan Performante
03-04-2015, 04:46 PM | #35 | |
Pace Car Driver
1548
Rep 3,164
Working on my car(s) is both a money SAVER for me and it's also my mental therapy. Thanks for the pics but it's under the car that's where the discrepancy is. Sorry to sh!t in your thread betlion. |
03-05-2015, 05:58 AM | #36 |
Rep 149
03-05-2015, 08:31 AM | #37 |
Rep 3,089
03-05-2015, 11:59 AM | #38 | |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
This is what I used, holds up very well all year round; just note that there are different sizes so search around for the one you think will work... 3M Automotive Acrylic Plus Double Sided Attachment Tape: http://www.ebay.ca/itm/3M-Automotive...c3e36c&vxp=mtr As for the shape, you can use a heat gun to shape it a bit to line it up better. Just be very careful you don't use too much heat and evenly distribute the heat among the area you'd like to shape. You don't want to warp the plastic to the point where it becomes wavy :P These are only my suggestions to DIY. Last edited by DrifterX; 03-05-2015 at 12:55 PM.. Reason: My post only includes suggestions for DIY... |
03-05-2015, 12:24 PM | #39 | |
Rep 3,089
03-05-2015, 12:53 PM | #41 | |
Rep 1,055
My point was you can use 3M acrylic double sided tape which is pretty strong. My current car's side skirts don't have any bolts or fasteners holding it up, only the tape. And these side skirts are larger and heavier than these M4 blades, they've been holding well for the last 2-3 years. Regarding the heat gun suggestion, if you know what you're doing, I think it won't be difficult to form with the right amount of heat it if it doesn't line up out of the box. Again, these are just my suggestions But anyways, this is all off topic of the thread lol |
03-05-2015, 02:09 PM | #42 |
Rep 149
03-05-2015, 02:12 PM | #43 |
Rep 149
03-05-2015, 02:18 PM | #44 | |
Pace Car Driver
1548
Rep 3,164
Of course this isn't a difficult DIY. It's just plastic. But there are people on here who make it sound like these are an exact fit and no modifications are necessary. It's just not true. |
