06-02-2019, 01:01 PM | #1 |
Rep 8
F30 20”s fitting
So I have a 328i 2013 xdrive and was looking at some 20’s but I’m not too sure how to calculate whether these would fit correctly or not.
The wheels are 20x8.5 front and 20x10 rear With the tires being 245/35/20 FRONT & 275/30/20 REAR Would there be any rubbing with stock suspension? And would it work with the xdrive? |
06-02-2019, 01:27 PM | #2 |
Rep 231
Will totally depend on the offset. I have 20” 405m’s on my car which were a dealer option. If you can get the offset people here will be able to let know if they’ll fit.
2015 F30 335i EBII MSport
M Perf Exhaust | M Perf Brakes | M Perf LSD | CTS CP | CTS Catless DP | FMIC | BM3 Stage 2 93oct | 20" 405m | 10/15mm Spacers | KW V3’s | Vorshlag Camber Plates |
06-02-2019, 01:32 PM | #3 | |
Rep 4,330
next, if the front offset is too low the 26.8" tall front tire may rub the fenderwell liner during full lock turn. what is the front offset? What are front and rear offsets? Last edited by alohasurftoad; 06-02-2019 at 01:44 PM.. |
06-02-2019, 04:11 PM | #4 | |
Rep 8
06-02-2019, 04:18 PM | #5 |
Rep 4,330
what wheels a they? if they are oem bmw and we get the style number we can find the specs. if they are aftermarket we can sometimes make a reasonable guess, if we know the oem offsets of the car it's on and if there are different offsets offered for the same wheel width or widths, if staggered.
06-02-2019, 04:52 PM | #6 | |
Rep 8
06-02-2019, 06:14 PM | #7 |
Rep 4,330
437m reps in 20"? If the reps are made for an f3/4 the rear shouldn't rub on stock suspension. The front offset could rub the fenderwell liner while turning if the offset is less than +32, or rub the spring perch or strut if greater than +38, with 26.8" tall tire.
Tags |
tires, wheels |
