06-02-2019, 06:19 PM | #1 |
David
786
Rep 2,009
H&R wheel spacers getting loose
My H&R 12mm wheel spacer lug bolts get loose 5-10ft/lbs every few days.
-Brake rotor face was wire wheeled -The wheel hub was wire wheeled -The hub bore in the wheel itself & the mounting face was wire wheeled Everything is spotless No odd vibrations or anything, but they seem to keep getting loose. Has anyone had this issue? I have them at factory spec of 104 ft/lb All I can think it a metallurgy issue between the steel/aluminum, its had plenty of heat cycles though. Should I just up the torque to 110 ft/lbs? |
06-02-2019, 06:35 PM | #2 |
Rep 4,333
Assuming you have the appropriate length extended lug bolts, I wouldnt put more torque. I'd prolly try a dab of low strength thread locker and see how it works out.
06-02-2019, 06:36 PM | #3 |
David
786
Rep 2,009
Threadlocker?? Haha that's not a solution imo
06-02-2019, 06:46 PM | #4 |
Rep 4,333
06-02-2019, 06:48 PM | #5 | |
David
786
Rep 2,009
It's a lot of torque but also a fat bolt with bigger surface area. But I feel the same way that's it's a lot of clamping force as is.
06-03-2019, 06:57 AM | #6 |
A family of bimmers
2747
Rep 7,742
do they sit flush with the rotor? is it possibly the hub lip is bigger than the spacer can accommodate?
06-03-2019, 07:09 AM | #7 |
David
786
Rep 2,009
Yes they're flush and a snug fit around the hub
