05-23-2019, 02:43 PM | #1 |
Rep 266
275/35/19 on a 9.5" rim?
I'm currently running 235/40/19 and 265/35/19 MPSS on my 8.5" and 9.5" wheels, and need to get new tires soon. I'm hoping to gain some traction and was thinking about moving to the Michelin PS4S. Should I stick with the same tire sizes or go bigger to 245/40/19 and 275/35/19? Or would those bigger tires look dumb on my size wheels?
2013 F30 335i
BM3, MPE, VRSF DP, VRSF Street HD FMIC, VRSF Chargepipe, AFE drop-in filter, Bilstein B14 PSS Coilovers |
05-24-2019, 12:37 AM | #2 |
Rep 4,330
is the type of traction you're seeking for straight line or turns?
since you are not x-drive i suggest 245/35/19, 265/35/19 Continental Sport Contact 6 |
05-24-2019, 07:56 PM | #4 | |
BMW Convert
108
Rep 201
The setup you currently have is the perfect setup for the f30 IMO. Upsizes from 26.0" to 26.3" all around. When my rear tires wear out, i will put on 265/40s instead in order to have the same height all around. |
05-25-2019, 08:59 AM | #5 |
BMW CCA 69606
86
Rep 227
Are these on wheels w/stock offsets....ET34 & ET47?
05-25-2019, 12:26 PM | #6 | |
Rep 1,523
05-25-2019, 02:16 PM | #7 | |
BMW Convert
108
Rep 201
My wheels are ET31 all around. |
05-25-2019, 04:20 PM | #8 | |
Rep 1,523
275 on a ET31 9.5 wide wheels is gonna rub without going massive negative offset. Unless you're on SUV ride height. |
05-28-2019, 04:06 PM | #9 |
Rep 266
Sorry should have clarified... 8.5" et35 and 9.5" et40, lowered on bilstein coilovers
2013 F30 335i
05-29-2019, 07:30 PM | #10 |
Rep 1,523
If its my car, I would stick to what you're running now. 275 rear with et40 is really close to rubbing unless you're willing to run more negative camber in the back.
05-30-2019, 12:49 PM | #11 |
Rep 266
sweet I'll stick to the 265/35 and 235/40. Are the PS4S a significant upgrade vs the PSS?
2013 F30 335i
05-30-2019, 01:01 PM | #12 | |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
https://f87.bimmerpost.com/forums/sh....php?t=1450467
deepghosh32.50 |
05-30-2019, 03:37 PM | #13 | |
Rep 1,523
Right now on my 328d touring I am running 19x8.5 ET30 and 19x9.5 ET42 with 235/40/19 and 265/35/19 Michelin 4s. The rears are very close to rubbing with 1.3 degree of negative camber. The fronts I have more clearance because I installed the camber knuckles that gives an extra half degree of camber than the factory spec. |
deepghosh32.50 |
