05-27-2019, 12:30 AM | #1 |
Rep 501
Drives: 2015 M4
Advice on 19" wheels on 340iX
I picked up a 340 X-Drive - I have a set of 788M's from my M2 after I upgraded the M2 to 763M's.
So, I want to install the 19" 788M's on my 340 - any advice on this setup with H&R Sport springs? Any potential issues to the X-drive? TiA
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily) 2021 Alfa Stelvio - Red/Black 2013 135is - LeMans Blue/Gray 2003 M5 (56k miles) - CB/Black |
05-27-2019, 01:16 AM | #2 |
Rep 4,333
https://f30.bimmerpost.com/forums/sh...&postcount=136
any potential issues for x-drive transfer case is be caused by the difference in front and rear tire diameters and not the wheels themselves. ideally you want the front and rear tire diameter to be equal as possible up to a difference limit of around 1%. for the 788, 235/40/19(26.4"), 265/35/19(26.3"), 0.4% difference, like Haddock! on 437m(same specs as 788), in the post above. sorry, his is F36, let me find a lowered f30 w/437m and 235/40, 265/35. Last edited by alohasurftoad; 05-27-2019 at 02:01 AM.. |
05-27-2019, 09:45 AM | #3 | ||
Rep 501
Drives: 2015 M4
05-27-2019, 10:26 AM | #4 |
Rep 4,333
I use www.tiresize.com and it suffices for the most part, however TR lists the exact tire specs for brand/model/size on a given rim width for higher accuracy. nominally same sized tires usually differ slightly.
05-27-2019, 11:27 AM | #5 | |
Rep 501
Drives: 2015 M4
alohasurftoad3081.50 |
05-27-2019, 06:06 PM | #6 | |
Rep 501
Drives: 2015 M4
So, I physically checked the 788's - 245/35/19 and 265/35/19 so, this will not work...
05-27-2019, 08:14 PM | #7 |
Rep 4,333
06-06-2019, 11:20 PM | #8 |
Rep 501
Drives: 2015 M4
So, I can get hold of 2 new MPS 255/35 for front and keep the 265/35 at the rear - the diff is 1.14% - do you think it would be an issue?
06-07-2019, 12:21 AM | #9 | |
Rep 4,333
my own personal thought is...255/35/19(26.03"=661.1mm) sits squarely on 9" front wheel, while 265/35/19(26.30"=668.1mm) is a very mild stretch on the 10" wide rear. as you stretch a tire its overall diameter will reduce as more stretch is applied. since 265/35/19 is a very mild stretch on 10", lets say the overall tire diameter reduces 2mm(1mm radius) with the mild stretch, making the total diameter 666.1mm=26.22". the new difference between front and rear would be 0.75%, making it a much more suitable number for x-drive. the question is, is the mild stretch reducing the diameter how i think it is, or not... disclaimer...same sized tires of different brands and models vary greatly. the numbers i'm using is straight mathematical calcs. results will vary greatly in the real world. would you "take one for the team" and give it a try? Last edited by alohasurftoad; 06-07-2019 at 03:21 AM.. |
06-07-2019, 09:59 AM | #10 | |
Rep 501
Drives: 2015 M4
Once again, thanks for the knowledge share...
06-07-2019, 10:11 AM | #11 |
Rep 4,333
Nice. Yup, the 8k mile rear will help your cause.
IF(big if) you have time to measure the front and rear tire circumference, we can get accurate actual tire diameters. I know how things go and usually end up getting things installed as quick as possible and regret not weighing or measuring stuff for comparison, afterwards. |
