BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > H&R wheel spacers getting loose
      06-02-2019, 06:19 PM   #1
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
My H&R 12mm wheel spacer lug bolts get loose 5-10ft/lbs every few days.
-Brake rotor face was wire wheeled
-The wheel hub was wire wheeled
-The hub bore in the wheel itself & the mounting face was wire wheeled
Everything is spotless
No odd vibrations or anything, but they seem to keep getting loose. Has anyone had this issue? I have them at factory spec of 104 ft/lb
All I can think it a metallurgy issue between the steel/aluminum, its had plenty of heat cycles though. Should I just up the torque to 110 ft/lbs?
      06-02-2019, 06:35 PM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
Assuming you have the appropriate length extended lug bolts, I wouldnt put more torque. I'd prolly try a dab of low strength thread locker and see how it works out.
      06-02-2019, 06:36 PM   #3
328iX
David
328iX's Avatar
Originally Posted by alohasurftoad View Post
Assuming you have the appropriate length extended lug bolts, I wouldnt put more torque. I'd prolly try a dab if low strength thread locker and see how it works out.
Threadlocker?? Haha that's not a solution imo
      06-02-2019, 06:46 PM   #4
alohasurftoad
well, put 110 torque on it, then. i just use 100, i'm on a stud kit, though. to me 100 is already a lot. either that or get new extended bolts.
      06-02-2019, 06:48 PM   #5
328iX
David
328iX's Avatar
I just put them on 110. I was just seeing if anyone had similar issue and resolved.
It's a lot of torque but also a fat bolt with bigger surface area. But I feel the same way that's it's a lot of clamping force as is.
      06-03-2019, 06:57 AM   #6
wdeerfield
A family of bimmers
Drives: '18 G01 X3M40i
do they sit flush with the rotor? is it possibly the hub lip is bigger than the spacer can accommodate?
2018 PB/Black G01 X3M40i | 699M | ZDA | ZPP | ZPX | Maxton front lip | X3M vents | 15mm Spacers | Diamond G20 style grills
      06-03-2019, 07:09 AM   #7
328iX
David
328iX's Avatar
Yes they're flush and a snug fit around the hub
