BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Spacers recommendation
      06-07-2019, 08:33 AM   #1
leopard2lx
Drives: 2016 BMW 435i GC xDrive
My 435 XDrive has the stock wheel setup 225/R18/45 front and rear. I am looking at spacers in improve the look by pushing the wheels out a bit but unsure what to get or even if it’s a good idea on a stock setup.
I think I would be okay with the minimum of 10mm that I’ve seen.
Would that work?
Would I do the same size for both front and rear?
Do I need extended bolts?
https://www.amazon.com/dp/B01NCU629K..._cxM-CbERMVNPA
2016 | BMW 435i GranCoupe | Alpine White | XDrive | M-Sport | BM3
      06-07-2019, 09:04 AM   #2
scostu
scostu's Avatar
Drives: 2016 F25
Would that work?
https://www.turnermotorsport.com/t-wheel-spacers
      06-07-2019, 11:01 AM   #3
leopard2lx
I measured 10mm gap for both front and rear but it looks like they recommend measuring the hub as well on all F30s which means I have to take it to a shop.
      06-08-2019, 07:56 PM   #4
bmw22915
Drives: 440xi GC
I have 10mm and 15mm spacers for cheap if you want em. Pulled off my 440xi gran coupe. Good condition. I have no use for them since I got new wheels.
      06-12-2019, 02:58 PM   #5
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
ECS tuning shows 10mm front and 15mm rear which gets the stock wheels close to flush with the fender.
I got these spacers AND extended bolts for less than $90 (I got the 12mm and 15mm). These guys were super helpful and answered emails pretty quick if you have questions. I drive pretty aggressively and was anal about the torque setting for a solid week (check the torque everyday). These are decent units for the price.
https://www.amazon.com/dp/B00AFNH5LY...d-bd618b452f0a
10MM
15MM
      06-13-2019, 04:24 PM   #6
psyki
E36fiend
Drives: 2014 435i xDrive
2014 435i xDrive  [0.00]
2014 X5  [0.00]
Here is my 435i xdrive with 20mm spacers in the rear and 15mm in the front at stock ride height. Not the greatest pictures, I took it for a different reason.
      06-13-2019, 07:31 PM   #7
Troy27
Drives: Bmw f30
I just installed 12mm all around on an msport with staggered tires and I think it looks perfect. Sits flush with the wheel well and absolutely no rubbing when going over bumps or turning hard. In my opinion 12 all around is perfect
Yes you need extended bolts. The stock bolt is 27/28mm so add the spacer width to that and that's what you'll need for a bolt. 28mm stock bolt + 12 mm spacer and you'll need a 40mm bolt. BTW the correct bolt size is 14x1.25
