BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N26 Muffler Delete (video included)
      02-03-2018, 07:20 PM   #45
carbon428i
carbon428i's Avatar
Drives: 2014 BMW 428i M Sport
Originally Posted by Phil2thejay View Post
Sound dope! Glad my videos helped on your decision.
Did you end up removing the secondary cats? Another member said you can give some insight into how it was done (the pipe going into the secondary cat is kind of flattened and an exhaust shop i went to said it can't be done).
2014 Black Sapphire Metallic F32 428i xDrive M Sport | Gloss Black Striped Dual Slat Kidney Grills | CF M4 Style Mirror Caps | CF M4 Style Trunk Spoiler | CF Rear Diffuser | Rohana RFX5 Gloss Gold 20" | CF Wrapped Interior | BM3 Stage 2 93 Agg Tune | VRSF Catless Downpipe | Evolution Racewerks Chargepipe | Pheonix Racing Intercooler | K&N Drop In Filter|
      02-05-2018, 09:23 AM   #46
Phil2thejay
EBII F30 N26 M-Sport
Phil2thejay's Avatar
Drives: F30 N26 M-Sport
My exhaust shop does wonders, they made it fit with the least airflow restrictions. The light gray is just anti rust coating for the welds.
Injen | H&R | VR Speed Factory| FTP Motorsports | RW Carbon | Custom Exhaust | Custom Splitter |
Custom Tune: 264WHP and 319WTQ at 20PSI | Instagram @myboiblu328
      02-08-2018, 06:13 PM   #47
Aekdbrich
Grand Poobah
Drives: 2014 328i XDrive (F30)
Still can't believe that sound. Sounds good Phil!
      02-08-2018, 06:15 PM   #48
Aekdbrich
Grand Poobah
Originally Posted by BunkerJ View Post
Surprising enough, no drone when just cruising. If I press the pedal enough to speed up quickly, you get a little, but not enough to bother you or your passengers. I think the second cat really helps out. But I could see your concerns on others besides the N26.
Same, the sound deadening material in the BMW does a real good job keeping that drone out. I hardly hear mine with the radio on at a reasonable level. If anything, the only exhaust mod will be a catted downpipe. second cat and resonator will stay in there. I couldn't be any happier with the $$ I paid for a simple mod.
How much did you spend on the delete?
2014 328i XDrive N26 (F30), bootmod3 Stage 2 AGG, VRSF Catless Downpipe, K&N Drop In Filter
      02-11-2018, 03:48 PM   #49
Phil2thejay
thanks man!
$500 total for the muffler delete, Y-pipe to dual tip, and secondary cat delete. steel piping.
      02-22-2018, 07:57 AM   #50
Phil2thejay
***UPDATED WITH NEW VIDEO*** 2.22.18
Running a custom tune now and gives the exhaust note slightly changed. Car rev's were in Comfort and Sport Modes. You can hear some cracks at 0:15-0:20. This is not a burble tune.
      02-22-2018, 10:58 PM   #51
Fr3sh
#im_2_Fr3sh
30
Drives: Bmw 428i xdrive
Very nice!
      03-20-2018, 03:25 PM   #52
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
Has anyone here with a 328 (or 330) done a muffler delete out to two single tips like a 335 (or 340)?
Im trying to think of how best to do it, logistically speaking. I have a 328i diffuser and am trying to source a carbon fiber m sport style diffuser for the two single tips. I imagine that I would have to have the diffuser there at the muffler shop, for the shop to measure where the tips should end at correctly?
1. Bring car to muffler shop
2. Remove stock diffuser
3. Shop cuts off muffler
4. I install new diffuser
5. Shop fabricates/bends pipes accordingly?
Any ideas on how to do this a more efficient way? I wouldn't be able to even test fit the diffuser if my stock exhaust system is there, in the way, correct?
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11
2013 F30 328i (12/2015 - 09/2020) SOLD!
      03-20-2018, 03:29 PM   #53
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
I'd assume if you could measure the diffuser or ask someone with a 335i to get you measurements, they could do it.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      03-24-2018, 10:09 AM   #54
Phil2thejay
or ask to borrow the 335/340 rear diffuser before going into the shop. Its essentially a direct replacement of the 320/328 diffuser.
exhaust, f30, muffler, n26, straightpipe
