02-21-2018, 05:42 PM | #199 |
Rep 3,211
02-21-2018, 05:42 PM | #200 |
Rep 5,992
02-21-2018, 07:23 PM | #201 |
Rep 104
I am currently at 105K.
The oil pan gasket is starting to get a bit oily by the catalytic converter but does not leak any noticeable amount. The engine makes some clacking noise in the top end on cold mornings but stops after a minute or 2 of idling. I think this is due to the heavier oil I used last oil change. Other than that things seem to be working pretty good or wearing down at acceptable rates. The rotors are now warped and I think they are original as well as the pads, but this is based on I do not see anything in the dealer records I have printed off. |
02-21-2018, 08:13 PM | #202 | |
Rep 5,992
02-22-2018, 04:57 AM | #203 |
Rep 104
It is at 190K right now but it was not taken care of too well before me. The bore was a whole mm oversized from wear and it still ran and drive! I had to do a manual swap sine the auto was trashed. Currently I am in the middle of doing 3 things to it. Either a basic engine rebuild, or a turbo rebuild with an M54 crank and rods, or a 6.0L LS with a T56. It is going to be a full restoration. This is all on top of a $500 Cherokee I do need to depend on when the F30 needs work or it's snowing and an LS race buggy I am making in my garage. Too many projects and no money really makes things interesting.
View post on imgur.com Last edited by XCRN; 02-22-2018 at 05:03 AM.. |
jeffc83725.00 |
02-22-2018, 04:01 PM | #204 | |
Rep 247
02-22-2018, 04:44 PM | #205 |
Rep 5,457
Drives: F30
Funny you said that... I was wondering how one could tell while they are on the car? Must be a feeling in the pedal that people are referring to...
02-23-2018, 02:10 AM | #206 |
1-800-STOCKAF
157
Rep 376
Just 2 days ago I found an issue with my valvetronic servomotor. I have to either replace my Valvetronic Eccentric Shaft Actuator or the entire Shaft.
my car is 2013 F30 335i about 61,xxx miles I was told that it could happen to cars that are both low and high in mileage. First I thought it was the charge pipe, but there was no way since mine was already upgraded from stock. performance mods: ECU tune Fmic Chargepipe catless dp res delete modded oem exhaust How do you know if your car has the same issue? -Loud short buzz noise under the hood, when waking the car up/unlocking the car -Unable to rev past a certain rpm, in my case 4k (it sounds like launch control) -Unable to do pulls. It kind of feels like limp mode, but its not. When you try giving gas it just makes the same launch control type noise once it reaches 4k rpm. Before this even happened, car ran perfect and smooth without any issues.
F30 320i Stock
02-25-2018, 09:06 PM | #207 |
Rep 30
My 12’ f30 has 69K on it. Purchased it used. Only thing that has been replaced (according to Carfax) was the distributor cap. No problems so far but I think I’m about to sell it because not only has my Powertrain warranty expired, now the timing chain warranty is about to expire too. I feel the chain is a ticking bomb at this point. Might throw an extended warranty on it, but I’ve been wanting a newer model anyway.
02-27-2018, 02:26 PM | #209 | |
Rep 247
6ixSpd6014.50 |
02-27-2018, 05:43 PM | #210 | |
Rep 403
The buzzing noise under the hood was my boost selenoid that I replaced
02-28-2018, 07:28 AM | #211 |
Rep 906
At 27k had to replace thermostat and the front shocks. All under warranty but those two items failing on a three year old car was a head scratcher...
Car also rejected Dinan Shockware and had to be reflashed back to factory standard |
03-02-2018, 10:57 AM | #213 |
Rep 117
Drives: 2016 328i m sport
2016 328i. 18k miles.
Just had head unit replaced. For sos error and navigation not working. |
03-03-2018, 01:19 AM | #214 |
Rep 6
Bought 2014 328xi last Aug with 55k and out of warranty.
Have put 15k more in last 7 months and reached 70k today. Only issue is horn /steering module threw an error code a month ago and does not work. Solve it by turning the steering to a particular angle to make it work. Paddle shifters have a mind of their own. Not really worried with the shifters. Cruise control malfunction issue occurs infrequently and is solved by turning steering to a particular angle which produces a slight feedback and issue disappears.. Had check engine light come up in freezing NY Jan weather for a couple of times , but went away after restarting the car. Rest is great so far. Regular oil change every 7-8k , changed plugs , flushed brake oil , changed cabin filter @63k and regular maintenance work. Loving it so far. Due for a service tomorrow morning. Just regular oil change, tire rotations and general inspection. As I didnt get any aftermarket warranty am always checking threads to see any common problems and how to identify them earlier. |
03-03-2018, 10:00 PM | #215 | |
1-800-STOCKAF
157
Rep 376
335 models
F30 320i Stock
03-04-2018, 01:44 AM | #216 | ||
Rep 36
- replaced the whole turbo for $1100+ - remote key both needs battery replaced So far that's it and it's been running great. |
03-13-2018, 01:33 PM | #217 |
Rep 76
2014 328d M-sport package RWD. Just hit 100k miles. Bought it as a CPO with 20k. Had an issue with the driver door lock getting hung in the lock position and the A/C froze on a long trip because the fan was on low and and temp was set low also. Read both issues had a TSB already from BMW by the time it happened to me and never had an issue since. Still have 25k miles left till my CPO warranty is over and even though the dealers ask me to upgrade I plan on keeping this car for a while longer. I'm really hard on it and do autocross, yet to have a major hiccup with it with the exception of a sensor on the rear diff going bad which was because I went off the track and through the cones.
06-27-2018, 07:34 PM | #218 | |
Rep 247
06-27-2018, 10:31 PM | #219 |
Rep 1
14 320i. 91,000 miles. No issues other than replacing a right front steering knuckle after I hit a curb turning in to a parking lot.
I just rotate the tires every 5k miles and change the oil when the car tells me to! |
07-02-2018, 02:03 PM | #220 |
Rep 14
2013 328i X-drive, N26 engine, timing chain, guides, and VANOS system need replacing, but at 89000 miles so of course it is out of BMW extended warranty for timing chain issue.
