05-31-2015, 01:17 PM | #1 |
Rep 919
JBL MS8 enough to power BSW Stage1 and SWS8 underseat subs?
I have the stock HiFi system and I will be installing the JBL MS8 along with the BSW Stage 1 speakers. I am sure the BSW speakers will be fine but would adding 2 underseat SWS8 woofers be too much for the JBL MS8 power wise?
05-31-2015, 01:57 PM | #2 | |
Rep 12,996
You will have much better results by keeping the OEM woofers with the MS-8. You may be even impressed. |
Thesharperb1.50 |
05-31-2015, 05:23 PM | #3 | |
Rep 919
Suggested setup: - skip input setup - Sub = 2, subsonic at 50Hz at 18dB slope, low pass at 200Hz at 12dB slope - Front = 1-way - Center = 1-way, 160Hz at 18dB - Sides = 1-way, 160Hz at 18dB Calibration volume = -25dB Main volume after calibration = -6dB Adjust to taste. There will be no sound until MS-8 is completely setup. |
05-31-2015, 05:27 PM | #4 | |
Rep 12,996
Yes... those are my default settings verbatim.
