02-28-2016, 07:37 PM | #1 |
Rep 1,342
BMWAI coding
Anyone used BMWAI?
http://cartechnology.co.uk/showthrea...826&pid=134596 I found it when searching for a way to view and reset transmission adaptations. Turns out the newer versions let you code other stuff, too. Today I successfully coded the mirrors to fold in from key fob locking, and added 2 extra blinks on the turn signals (when pressed momentarily...like when changing lanes). I also changed settings for sensitivity of auto headlights, I think. I thought it was too sensitive, headlights are on all morning...but I've seen other F30s at that time that don't have headlights on (just halo DRLs). I'll know tomorrow morning if it worked. |
02-28-2016, 09:18 PM | #2 | |
Rep 3
02-29-2016, 09:29 AM | #3 | |
Rep 1,342
I had to turn off AV and use Internet Explorer to download. Haven't had any virus problems after download and use... |
03-01-2016, 03:10 AM | #4 |
Rep 105
Direct link to DL is: http://www.bmwai.com/download/bmwaicoder4.4.zip
Alternate hoster: http://www53.zippyshare.com/v/mbwj46Jz/file.html |
05-03-2016, 02:37 AM | #6 |
Rep 63
Jason954x122.50 DirtyHarry3010.00 |
07-28-2016, 04:06 PM | #7 | |
not good, but bad
333
Rep 361
08-16-2016, 02:36 PM | #8 |
Rep 125
Just want to report that I just downloaded and used 4.6 from the above link. Windows Defender quarantined cic.exe (interestingly not nbt.exe) so may be you don't even have to un-quarantine the file if coding NBT. In any case seems to work fine, and just successfully did my first coding with it. Nevertheless still be careful.
04-07-2017, 09:23 PM | #10 |
Rep 305
Can BMWAi code FA/VO? Like changing the FA and VO stuff? I have used it successfully to code some basic stuff like remove warnings and fog light with parking lights. But I don't see any options to code stuff like Enhanced Bluetooth or get Office in iDrive.
04-08-2017, 04:40 PM | #12 |
Rep 8,364
I know it does FDL coding as well as generates FSC codes for maps. Not sure about VO coding. You can do that in E-sys.
04-08-2017, 05:12 PM | #13 |
Rep 305
E-sys seems so complicated compare to BMWAi. I have use INPA before but that was complicated as well. I guess setting up E-Sys is the hard part. I'll give it a try after I get all the right files...
04-08-2017, 06:32 PM | #14 | |
Rep 8,364
At 1:25, you can see Cheat Codes. Only difference is there is "Review" button to verify changes before you "Apply." |
04-09-2017, 09:07 PM | #17 |
Rep 305
It seems I have to download specific versions for a specific car. Then get some specific token?
Compare to BMWAi, there was virtually zero setup. Just unzip, and run. It was super easy to use as well. Steps are clearly labeled 1-5. Codes are clearly marked and even explained what it does! It nearly dummy (like me) proof! |
04-09-2017, 09:20 PM | #18 | |
Rep 8,364
I can provide you software and easy to follow setup instructions if you want. |
04-09-2017, 11:00 PM | #19 |
Rep 305
That would be great. I did search about it and found the coding thread which is 500+ pages so it was a little overwhelming. Just to make sure, I have a 2016 328i LCI. Thanks in advance.
04-10-2017, 01:09 AM | #20 | |
Rep 8,364
Fxx, Ixx, & Gxx Series Coding: Latest Software, Guides, and Tips PM Sent |
04-10-2017, 03:15 PM | #22 |
Rep 8,364
