06-16-2018, 06:41 AM | #1 |
Rep 2,653
Intermittent Startup Issue
Hi everyone. I'm having occasional startup weirdness with my 14 335. Sometimes when I start the car it will crank longer than usual and it revs to around 2K RPM for 5-10 seconds and will idle back down to normal. Happened to me yesterday. It doesn't happen all the time and I don't have a CEL or stored faults. Anyone experience this?
06-16-2018, 07:19 AM | #2 |
Rep 5,457
Drives: F30
Somedays my 328 takes longer to crank over than others. Was wondering the same as you... no rhyme/reason or predictable pattern to it. No codes or errors either.
Also a 2014. |
06-16-2018, 10:12 AM | #3 |
¯\_(ツ)_/¯
537
Rep 1,000
Your battery is on its way out
06-16-2018, 10:50 AM | #4 |
Rep 2,653
if it' just the battery then I'm cool with it. I'm hoping it isn't a fuel injector or a fuel pump issue. I have an appointment this coming Friday so we'll see what they say. If it WAS a battery issue, wouldn't I receive some type of notification from the computer?
06-16-2018, 11:03 AM | #5 | |
Rep 5,457
Drives: F30
Im not too worried about it (like you) but definitely interested to hear what dealer says. |
06-16-2018, 11:37 AM | #6 | |
¯\_(ツ)_/¯
537
Rep 1,000
06-16-2018, 11:37 AM | #7 | |
Rep 1,560
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
06-16-2018, 12:03 PM | #8 |
Rep 15,858
Before we can even suggest this is possibly a battery issue... is the cranking speed slow or normal?
Slower cranking speed is more the sign of a battery issue. Normal speed, I'd be looking deeper. The mention of higher revs than normal start up, is also a sign something is not quite right. Fuelling or ignition. |
06-16-2018, 03:57 PM | #9 | |
Rep 1,560
06-16-2018, 09:36 PM | #10 |
Rep 1,487
Drives: 2108 X3 xDrive30i
That is a pretty common issue not just with BMW's. Most cars will take a longer time to crank over when their battery has dropped in voltage. As COKen above mentioned...very easy to test.
06-16-2018, 11:42 PM | #11 |
Rep 1,502
I had two of the long-crank starts several months back. It cranked for what seemed like a good 6-10s, and about the time I started thinking I’d have to call a tow truck the car started.
It hasn’t happened again for a good 6 months, so I’m skeptical that the problem is battery-related. Regardless, I’m on the original battery and it’s past due for a preventative replacement (it’s coming up on 5 years old, about as long as you get in Phoenix) so I’ll be swapping it out soon. |
06-17-2018, 05:36 PM | #12 |
Rep 65
I had similar problem with my old e92 n/a direct inj petrol. I was driving the car too gentle for a long time. After some hard pulls on country road the problem was gone. Make sure to go full throttle, when engine at operating temp, at least once monthly.
06-17-2018, 06:38 PM | #13 |
Rep 2,653
This is something I do regularly
07-04-2022, 01:44 PM | #15 |
Rep 35
