BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 2013 F30 BMW 3-Series Major Differences to E90
VIBE Motorsports
      03-14-2010, 08:07 PM   #1
AltecBX
AltecBX's Avatar
Drives: BMW 335xi Sedan
Post 2013 F30 BMW 3-Series Major Differences to E90
The 2013 BMW 3-Series will be longer and wider, but will use many components from the current model. The 2009 BMW 3-Series is shown here.
The 2013 BMW 3-Series should reprise most current-model features, starting with standard front-side airbags and, convertibles excepted, head-protecting tubular side airbags covering both seating rows. Convertibles should retain head/torso front airbags, plus rollover bars designed to deploy from the rear headrests if sensors detect an impending tip. They should also continue with a power-fold hardtop instead of a fabric roof. Returning option lists should again include a luxury-focused Premium Package, a driver-oriented Sport Package with upgraded suspension and unique trim, a navigation system with BMW's iDrive infotainment controller (doubtless revised once more for easier use), steering-linked bi-xenon headlamps, keyless entry and starting, music-player plug-in, and the BMW Assist service with wireless cell-phone link.
In all, the 2013 BMW 3-Series seems to be another of those tricky redesigns that has to be "the same yet different," much like the E90 versus the prior E46 generation. And you really can't blame BMW for being cautious with a line that accounts for over 40 percent of its yearly sales and which still defines the brand in most people's minds. Besides, why risk losing sales when the market is already so tough? All of which suggests that if you like today's 3-Series, you should like the F30 at least as much. You can bet BMW is counting on it.
A Notable Feature of the 2013 BMW 3-Series
It was in 2005 that BMW began promoting "Efficient Dynamics," technical features intended to boost fuel economy through improved powertrain and aerodynamic performance. Early examples included direct fuel injection and the Valvetronic variable valve-timing system with "by-wire" electronic control instead of a mechanical throttle. Sources expect European versions of the 2013 BMW 3-Series to add several new Efficient Dynamics technologies, but it's unclear which ones might appear on U.S. models or what they would cost.
Perhaps the most likely prospect is an engine stop-and-start system like that on many gasoline/electric hybrid vehicles. Reportedly available only with automatic transmission, it uses an integrated starter/generator powered by a lithium-ion storage cell that charges as needed when the brakes are applied. A smaller, lighter service battery helps compensate for the added weight of these components. There's also talk of an oil pre-heating circuit for the engine, transmission, and differential. The idea is to reduce gas-wasting hydraulic friction in these components through faster fluid warmup after a cold start. Some BMWs already boast a so-called Intelligent Alternator Control that engages the alternator only when coasting and braking, this to eliminate another drain on engine efficiency. The new 3-Series may have "on-demand" oil and water pumps as well. Then there's "Active Aero," a series of inner-body flaps that adjust to smooth airflow through the body as well as around it as a way to trim gas-eating wind resistance. Serving the same end is a possible "active suspension" that slightly lowers the vehicle at highway speeds--not a new idea, but a plus in an age of concern about air quality, global warming, and dwindling oil supplies.
Speaking of hybrids, BMW was a development partner in the so-called Two-Mode transmission that General Motors now offers in several large hybrid SUVs and pickups; the same basic system is due as a 2010-model option for the big Dodge Ram pickup. BMW, however, favors clean-diesel power for vehicles like the 3-Series as a faster and cheaper route to better fuel efficiency and reduced emissions. As a result, sources think the company's hybrid offerings will be limited to the X6 premium-midsize SUV and to the 7-Series premium-large sedan. And it's unclear when even those might appear, as BMW is now slashing expenses wherever it can to offset sales and revenue losses from the economic downturn.
http://consumerguideauto.howstuffwor...-3-series3.htm
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps)
†Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec
AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS
      03-14-2010, 09:12 PM   #2
Tiago@VRSF
Tiago@VRSF's Avatar
Drives: E92 335i, F30 328i, F82 M4, i8
Send a message via AIM to Tiago@VRSF
Is this your own report or is it from a credible source?
      03-15-2010, 01:00 AM   #3
AltecBX
AltecBX's Avatar
Link
      03-16-2010, 06:05 PM   #4
bmwaddict
Drives: '11 AW 335is E92
longer and wider? of course...M.B. and Audi have a wide body
      03-16-2010, 06:11 PM   #5
SpencerM3
Sauce
SpencerM3's Avatar
Drives: 2009 SSII E90 M3
Looks a lot longer, but good. I would think this is pretty acurate.
2009 E90 M3 | Silverstone II | Black Novillo | HRE P40's | Akrapovic Exhaust | Eibach Pro Kit | Jet Black Kidney Grilles | SSII Side Reflectors | SSII Side Gills | LUX H8 Angel Eyes | Macht Schnell Filter | Tecnocraft Envy Charge Pipe
"M3 drivers have no friends." - Jeremy Clarkson
      03-16-2010, 06:30 PM   #6
zuggerat89
Still waiting...
zuggerat89's Avatar
Drives: OGV
ugh wtf, more heft?
      03-16-2010, 06:44 PM   #7
Project1
Bimmer Love
Project1's Avatar
Drives: You will figure it out...
Stop making it bigger! That's what the 5-series is for! SMALLER! LIGHTER! That's the way to good gas mileage...AND FUN!!!!
      03-16-2010, 06:59 PM   #8
numba1guju
numba1guju's Avatar
Drives: 2015 VW Jetta
that being said lets anticipate a new 1 series...it will probably be longer making a lot more people fans?!? maybe?
SOLD: 2013 328i Mineral Gray ZMM/ZLP/Heated Seats
SOLD: 2002 325i Jet Black ZPP
      03-16-2010, 08:46 PM   #9
Project1
Bimmer Love
Project1's Avatar
I would be happier with shorter, and NO back seats...I want another option than the z4 as a 2 seater...kind of like the hardcore porsches...a 1er with just 2 seats and CSL options would be a BUY IT NOW thing...now they are going to add a ton of power to the M3, only to be countered by more weight.
      03-16-2010, 09:29 PM   #10
Oulixes
Oulixes's Avatar
19
Drives: 330xi, 335i
The report makes sense. The 3-series shall be as conservative as we are used to, but bigger and heavier - it is inevitable, considering the average buyer. The idea of preheating oil in the differential is interesting. Those who favor manual transmission should just pray and keep faith.
      03-16-2010, 09:31 PM   #11
italy430
italy430's Avatar
Drives: E46 2000 328i
....that's what the 1 series is for!!! I trust BMW's judgement.
      03-16-2010, 10:08 PM   #12
Alex@Alpine
Drives: E90 M3
Send a message via AIM to Alex@Alpine
Cant wait
E & F Series Coding. Remote Coding available around the world.
Whatsapp + iMessage 310-560-0808
International +13105600808
Email: Alex@Alpinemss.com
      03-17-2010, 12:33 AM   #13
akhter
akhter's Avatar
101
Drives: F15 X5 x3d Mineral White
didn't you get the memo?
that is what the 1 series is for
get with the program...
      03-17-2010, 09:40 AM   #14
kinan_sleiman2006
kinan_sleiman2006's Avatar
Syria
30
Drives: BMW X3
Design
It will be too safe in design
      03-17-2010, 09:41 AM   #15
kinan_sleiman2006
Syria
30
Drives: BMW X3
Much more powerfull in engines..
      03-17-2010, 09:42 AM   #16
kinan_sleiman2006
Syria
30
Drives: BMW X3
Cleaner in co2 emissions and friendly to the enviroment
      03-17-2010, 11:29 AM   #17
Uli_HH
Uli_HH's Avatar
Drives: AW M3 E90)/ 523i Touring
Longer and wider ... 4,70 should be the number like Audi A4 and MB C-Class ... too big for me!
Uli_HH
      03-17-2010, 05:22 PM   #18
fatjoez
student
fatjoez's Avatar
Drives: e90
really don't get it. you keep making a car longer,wider. Then what. 2013 you get 3 series equivelant of a 1995 5 series.
Like is it me or is the worlds population getting fatter.
      03-17-2010, 07:05 PM   #19
Ironring Racing
N54 FTW!
Ironring Racing's Avatar
Drives: BMW 335i 6MT
2013? I thought it was a 2012 model coming out in fall of 2011? Is it delayed a year?
      03-17-2010, 10:31 PM   #20
noro
noro's Avatar
Armenia
67
Drives: '91 M3, '04 E46 ZHP, '72 2002
That is only normal. It is the best way to keep customers engages over a long period of time. As you get older and wanna roomier car you could still keep getting the same model that you initially fell in love with.
zhpregistry.net - ZHP stats and free classifieds.
      03-17-2010, 11:55 PM   #21
emac08
got em' son
emac08's Avatar
Drives: 08 135i sold / 08 E90 M3 sold
Send a message via AIM to emac08
when my gf bought her 1 series, i was able to speak to the sales manager. he had told me that the way BMW is moving is in the direction of the 1 series taking over the "small" market of the 3.. then everything is is bumped up. 3 will kinda be what the current 5 is, the 5 will have the 7 series front and the 7 will be redesigned....
      03-18-2010, 05:01 AM   #22
vladberca
vladberca's Avatar
Romania
312
Drives: '17 jetta tdi 6mt
a better Cx will help a lot to achieve a good fuell consumption!
2012 3 series, 2012 3-series, 2013 3 series, 2013 3-series, 2013 bmw 3 series, 2013 bmw 3-series, 2013 bmw m3, 2013 m3, 2014 bmw m3, 2014 m3, bmw f30, bmw f32, f30, f30 3 series, f30 3-series, f30 3-series forum, f30 forum, f30 m3, f30 sedan, f32, f32 3 series, f32 3-series, f32 3-series forum, f32 forum, f32 m3
