07-25-2013, 04:02 PM | #23 | |
Rep 10,407
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
07-28-2013, 10:51 AM | #25 |
Rep 1,144
07-28-2013, 12:23 PM | #26 | |
Rep 2,940
I am not all concerned about the technology as long as the heat management is adequate.
Audi S6 * Audi S3 * Porsche Cayman GTS
--Former BMW M3 owner |
07-28-2013, 12:29 PM | #27 |
Rep 3,522
I think the F80/F82 is all about heat management. If they can cool the oil and have it last through a track day then the car should be a success.
My concern is testing on the 'ring gives plenty of opportunity for cooling whereas most tracks in NA are shorter, slower and tighter. |
07-28-2013, 12:39 PM | #28 |
Rep 7,037
My guess is that IF we get 3 turbos it will be a sequential system with two small turbos in parallel feeding one larger turbo. This would generate power at a wider rpm range than three parallel turbos and allow for a higher useful redline.
07-28-2013, 01:47 PM | #29 |
Rep 10,407
Not sure why so much speculation on the turbo configuration. If it has 3 turbos they will almost for sure to be as per BMWs patent I posted just above.
08-06-2013, 08:13 AM | #31 |
Moderator
7506
Rep 19,370
08-08-2013, 10:19 PM | #32 |
Rep 2,517
Drives: '11 335xi e92 M-Pak
Well I guess thats considered "multi-turbo"
08-13-2013, 12:38 AM | #33 | ||
Rep 360
This system would allow the usage of bigger turbos which wouldn't run out of breath at higher RPMs, (remember "near 8000 rpm") and also reduce, (possibly eliminate) turbo lag. I said it before and I'll say it again, I think we are going to see something new ! |
08-15-2013, 12:26 PM | #35 | |
Rep 2,099
08-15-2013, 12:42 PM | #36 | |||
Moderator
7506
Rep 19,370
The reason to use a turbocharger vs. a supercharger is that it does not rob power from the engine in order to spin its turbine. The reason not to simply fix this by using a purely electric supercharger is that the energy storage required to power it would be very heavy. So, you combine the ideas by using an electrically assisted turbocharger (or system of them in some combination). |
08-15-2013, 01:53 PM | #37 |
***** noob
1355
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
Confucius once told me..."Cars with 3 turbos are better than cars with none"
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
08-15-2013, 05:57 PM | #38 |
2124
Rep 5,011
BMW is always first out of the gate with ground breaking designs, whether it is aesthetics or engineering, BMW always takes the risks other manufacturers will not.
I have not been this excited in a long time about a new BMW model! |
08-15-2013, 06:04 PM | #39 |
Rep 2,099
The article referenced below states that electric superchargers use
"an electrically powered forced-air system that contains an electric motor to pressurize the intake air". What am I missing? Are these not used in production cars? http://en.wikipedia.org/wiki/Electric_supercharger |
08-15-2013, 06:35 PM | #40 | |
Moderator
7506
Rep 19,370
They are indeed not used in any production car or truck that I am aware of. They may be used in some production engine for some application; that I don't know. I seem to remember reading about their use in either air or marine applications in the past, but I don't recall details.
But there aren't many production supercharged cars today anyway. Still, even if we look at aftermarket solutions of which there are a good many, I am not aware of any with electrical assist. Perhaps they were tried out sometime over the past 100 or so years. Today, though, no. Quote:
08-16-2013, 12:43 AM | #41 |
Rep 51
According to the latest issue of "Road & Track" magazine, they are planning to use 3 "tiny turbos" that will allow a quicker response than two small turbos or one large turbo. As another poster mentioned, the goal is to keep turbo lag to a bare minimum.
