01-28-2018, 02:20 PM | #1475 |
Rep 136
Hi guys,
Recently joined here as i am having some issues with my headlights. I did do a search online but it seems i am getting nowhere unfortunately. As we all know, the halogen f30 lights are..... not so great... so i bought the depo version from eurowagens like most of you. With some diy sites i managed to fit the lights and it looks amazing! I am using H7 halogen bulbs for now. The issue is that i am not a mechanic but it felt like the lights were aiming towards the street, no issue with the vertical aim but they were already on 0. A solution would be to pop the hood and aim them manually. I don’t want to end up blinding oncoming traffic so brought the car to a local garage. They didn’t charge me as they told me the lights have an incorrect beam pattern and will not pass MOT??? I contacted eurowagens but did not get a reply from them. The garage did put the lights a bit higher and the pros are: i can a lot better in the dark and oncoming traffic doesn’t seem to be bothered either! The cons.. my MOT is due in december so i got 12 months to sort it out. I have attached a picture of my lights aiming at a wall approx 3-4meters away from it. In my opinion apart from it looks similar to everyone else their lights, apart from the fact mine are not perfectly aimed. Or am i mistaken? Last edited by deleted_user; 01-30-2018 at 02:28 PM.. |
01-28-2018, 04:54 PM | #1477 |
Rep 136
Yeah tried that but they told me they can’t help me as the beam pattern is wrong. And don’t fancy dropping it off at BMW as they most likely charge me 2h work at a premium rate for a 5 min job.. but if that is the only option...
At this point I’m wondering if there is anything obvious wrong about the beam pattern? According to the garaga here the left side should ‘kick up’ instead of what i have? |
01-28-2018, 05:06 PM | #1478 |
Rep 1,455
Well if it's wrong according to the not tester then perhaps it is wrong ?
Try somewhere else if you doubt it, somewhere like a halfords or Kwik fit perhaps to get a second opinion But if the pattern is really wrong it's either faulty headlights or incorrect installation |
01-28-2018, 05:25 PM | #1479 |
Rep 32,881
It’s probably because their system says it’s a halogen F30 so it should have X beam pattern, but because you’ve fitted aftermarket projector headlights it now has Y beam pattern, so a computer says no situation.
Other cars that have halogen projectors from factory probably have same beam pattern as yours, worth checking them out. |
02-05-2018, 06:09 AM | #1480 |
Rep 2
Hi, I'm looking to get a set of the Depo headlight units, as I was seriously disappointed when i realised I didn't have the "Angel Eyes" on my new motor.
I note on my current halogen setup, the daytime running lights go off when the dipped beam headlights are on. Can anyone tell me with the Depo lights do the angel eyes go off, or do they stay on with the dipped beam, as the O.E zenons appear to do? |
03-17-2018, 09:44 AM | #1482 |
Rep 3
Hi all. I'm thinking of getting the depo lights and seen in the thread that some of you went with full h7 LED for full beam and dipped beam.
Can you give me some feedback on how everyone's lights running please? Did you have to adapt them or code them in anyway? Do you get any errors with the depo lights? Any issues with getting your MOT? Any advice would be much appreciated Thanks |
05-06-2018, 03:53 AM | #1484 |
Rep 51
Hello fellow enthusiasts. I finally took the plung and spent AUD1000 and got these amazing depo lights for my F30. Installe them today and look amazing. I also bought H7 LED conversion kit from Autobarn (https://www.autobarn.com.au/el27416) however I couldn't install these bulbs in the Depos. The bulb is the right fit however there is no mechanism to hold the bulb in its place. There is a metal clip that was on the low beam connector of the depo lights however can only fit standard halogen H7 in it. Not sure if the headlight I received was missing something? I would think, a metal wire like spring - have seen on few cars which push down and locks in place to hold the bulb will be perfect. Just wanted to see if your lights had any spring to secure the bulb? or if you have converted halogens to LED or Xenon HID and what trick worked? At this stage I have installed standard halogens but would love to have white light for OEM look.
EDIT: I found there is a adaptor that I need to buy to fit HID Xenons. Apparently LEDs wont work with Depos - or very hard to make them work. Last edited by maximus81; 05-07-2018 at 07:38 PM.. |
05-06-2018, 04:57 PM | #1485 |
Rep 114
i had mine mot'd in january and had no issues, i also have hid main bulbs but due to the new mot rules i will be changing them for led ones. tried running them on normal bulbs and it didn't look very good.
05-07-2018, 07:31 PM | #1486 | |
Rep 51
So basically, halogen DRL = LED angel DRL and parking light = eyebrow light. |
05-07-2018, 07:36 PM | #1487 | |
Rep 51
05-23-2018, 12:56 PM | #1488 | |
Rep 3
06-21-2018, 06:40 PM | #1489 |
Rep 1
Questions about fitting and bulbs
Hi guys, I am new to join here. I've just received the depo headlights from eurowagens. I have little experience to retrofit the lights. Could you guys please recommend a local garage to do it in Sheffield area? Also, I don't know which type of bubbles could be fitted? H7 Led? any brand? Thank you very much.
06-23-2018, 05:08 PM | #1490 | |
Rep 3
08-29-2018, 06:07 AM | #1491 |
Rep 8
09-10-2018, 03:58 AM | #1494 |
Rep 32
Hi guys, I know that it is a F30 thread but I was wondering if someone can help me to order a depo xenon look headlight for my F20. Eurowagen seems out of stock. Furthermore depo part numbers make me confused because depo also produces xenon replacement headlight which does not work with halogen headlight. Part number I have found. Not sure if it is a replacement or not. 444-1182RMLDHEM and 444-1182LMLDHEM
10-18-2018, 03:54 AM | #1496 | |
Rep 12
banging mate
real stock look to them. i only just got my f30 and this is the first upgrade im doing.. i know this is an old thread but ive read every page kudos to brenan sorting this out and persevering with eurowagons.im waiting for december stock at 499 you lads got a good price, cars all look amazing was there any final thought on best bulbs etc etc and did anybody have any issues with the lamps a year or so on??? |
