06-22-2018, 01:05 AM | #1 |
Rep 193
Which petrol stations work properly for filling air to large tmps sterns?
Hi there, having just bought a new car and trying to check air pressure at both shell and sainsbury's, neither could push down deep enough to make a sealed connection, instead letting air out.
Helpful formers on here have said the protrusion is the tpms valve.. Pictured here https://photos.app.goo.gl/319Y3oEmHF4MZsSo7 I'm not sure what to do, as adding air worked perfectly fine at the tyre changing centre where I've just swapped from budget tyres to mps4s Could I manually trim down the metal with a carving knife. I'm guessing they're not oem standard bmw parts if I'm the only one experiencing this problem? Thanks in advance EDIT: RESOLVED: Simply turning the petrol station pump the other way using the backwards vent works like normal. I always wondered why there is two om when the do the same thing. It's a little fiddley feeding it through the alloy against the brake pad, but works straight away. Phew Thanks everyone for their help Last edited by madlad2000; 06-22-2018 at 05:44 AM.. |
06-22-2018, 01:22 AM | #2 | |
Rep 168
06-22-2018, 01:31 AM | #3 |
Rep 3,966
Get yourself a Michelin Analogue Double Barrel Footpump and keep it in the boot. Sturdy and reliable. Screw down valve fit works fine with TPMS valves. I don't trust forecourt airlines. They never get calibrated and give inconsistent readings
Owned: 440i GC LCI with MPPSK, F31 330D M Sport with MPPK, F11 530D SE, F11 520D SE, E61 530D M Sport, E36 325i plus many MB's, Audi's & Volvo's
06-22-2018, 01:34 AM | #4 | |
Rep 2,274
I use one of these https://www.amazon.co.uk/Michelin-Ra...R0E4M45V3JAGPW
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
06-22-2018, 02:13 AM | #6 |
Rep 193
06-22-2018, 02:14 AM | #7 |
Rep 193
Thanks, that's cheap really, so basically as long as there's enough thread to connect, then it should be fine. Does it look to be so from the pic I posted
06-22-2018, 02:33 AM | #9 | |
Rep 3,966
