Extreme Power House
      02-05-2016, 05:00 PM   #9945
maexx
Drives: F20
It is possible in F20 that REM is for PDC then. Front Sensor then may be in FEM_BODY. I would VO Code CIC/NBT, REM, and FEM_BODY then.
Yes I believe so but do you know anything about these errors? I unearthened a threat from 2013 where it says it is an issue with the psdz-data version but I'm not sure if that is still current.
PS: Did successfully code FEM_Body but front PDC is still not working.
      02-05-2016, 05:02 PM   #9946
shawnsheridan
shawnsheridan's Avatar
Drives: 2011 535i M-Sport
Take 508 back out of FA, and see if you can VO Code REM, just to see if it is causing the error.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
      02-05-2016, 05:24 PM   #9947
maexx
Drives: F20
okay I got it working perfectly fine now, you gave me the correct hint! My mistake was that I actually ADDED 508 to VO instead of REPLACING 507 with 508 ... Thank you very much for the great help!
      02-05-2016, 05:31 PM   #9948
shawnsheridan
      02-06-2016, 12:46 AM   #9949
pmatibag
Drives: 2014///BMW/// 328i///DINAN SPR
Hi shawnsheridan
Can I also have the latest software of E-Sys and the PZdz token? I am currently running 3.26.1
Thank you very much.
      02-06-2016, 12:58 AM   #9950
shawnsheridan
Originally Posted by pmatibag View Post
Hi shawnsheridan
PM sent.
      02-07-2016, 04:27 PM   #9951
denryrodriguez
Drives: F30 335i M-Tech
Thanks in advance
Hi shawnsheridan
      02-07-2016, 04:38 PM   #9952
shawnsheridan
Originally Posted by denryrodriguez View Post
Hi shawnsheridan
PM sent.
      02-08-2016, 04:00 PM   #9953
mutters
Drives: f31 330d m sport
PM sent.
Thanks again! (And for the clear & easy to follow loading instruction pdf)
      02-09-2016, 03:20 PM   #9954
imincontrol
Drives: BMW 435Xi
Thank you!
Hi shawnsheridan
      02-09-2016, 03:21 PM   #9955
shawnsheridan
Originally Posted by imincontrol View Post
Hi shawnsheridan
You cannot send or receive PM's yet. Send me one when you can.
      02-09-2016, 03:47 PM   #9956
101x
Drives: E60 LCI
Can I have the newest desktop version of ETK? Thanks in advance!
      02-09-2016, 03:50 PM   #9957
shawnsheridan
PM sent.
      02-09-2016, 06:53 PM   #9958
E90Boy
E90Boy's Avatar
Drives: 14 F33
Can you send the Latest Esys and PZData Files with token? Thanks.
      02-09-2016, 07:05 PM   #9959
pikuko
Drives: 128I
Is there a possible way to code the rain sensor to close windows and sunroof when detecting rain?
      02-09-2016, 07:19 PM   #9960
shawnsheridan
PM sent.
      02-09-2016, 07:21 PM   #9961
shawnsheridan
Not really. There is HU_NBT => REGEN_SCHLIESSEN = aktiv, which is for Sunroof only, but I do not think it works, or it works only when car is operating.
      02-10-2016, 12:03 AM   #9962
Ace8
Drives: 2015 328i M Sport
May I also get the latest Esys and PZData Files with token? Thanks you!
      02-10-2016, 02:04 AM   #9963
shawnsheridan
PM sent.
      02-11-2016, 01:55 AM   #9964
bmwzrrrr
Drives: bmw z4 3.0 and 325it
PM sent.
Shawn, Can you please also PM me the files?
      02-11-2016, 05:23 AM   #9965
shawnsheridan
PM sent.
      02-11-2016, 06:37 AM   #9966
Vogit
Drives: X1 xDrive 20D xLine
Hi Shawn - please could you send the links for latest version of E-SYS and PZData.
Thanks!
Forum Jump
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
