BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > Kevin_Trxn Build Thread (Stella)
      07-16-2022, 12:56 PM   #111
BFitty8
BFitty8's Avatar
Drives: BMW 340i MSport
2018 BMW 340i   [0.00]
Im really curious to see how well the e85 goes with the B58. I want to go full e85 but on the fence.
      07-16-2022, 03:29 PM   #112
Kevin_Trxn
Drives: '17 340i
You need to upgrade
HPFP
LPFP
and get a custom tune
But at E50 on an OTS map from BM3 you make 500hp
After 500hp
You'll need to upgrade cooling
Things like heat exchanger and such.
500hp is kinda that sweet spot before you have to go deep into upgrades.
Last thing you want is to fry piston rings
Or so I've been told
I'm running flex fuel rn with only HPFP upgrade and bm3 ots tune
But I'm Only planning to be at 500hp
      07-17-2022, 11:30 PM   #113
BFitty8
BFitty8's Avatar
You need to upgrade
HPFP
LPFP
After 500hp
So far I have BM3 Stage 2, catless dp, and xHP trans tune. Off the shelf it's probably around 400hp? It's plenty of power, and in WA state there's not a lot of places to utilize the power. However I do still want to try out some e85 or a e50 mix.
      10-03-2022, 12:43 PM   #114
Kevin_Trxn
Drives: '17 340i
New setup specs
Te37 Saga SL (Coil-overs)
Pressed Graphite
18x9.5 + 38
255/40/18
6mm spacer front
3mm spacer rear
KOWTOWN310.00
