BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - Southeast > what's causing this noise?
Studio RSR
      09-05-2021, 04:27 PM   #1
bmwhatsthatnoise
Drives: 320i
Living in North Carolina, there are no shortages of hot days. When it's hot, over 85, and I drive anywhere, when I go to leave, the car makes this high pitched squealing noise. The noise doesn't last long, and if I rev the car up it goes away pretty quick. I thought it might be the oil filter but after the last service, the noise is still present. Any suggestions or has anyone else experienced this before? Unfortunately, I cannot get the video to load to give an example.
      09-14-2021, 06:10 PM   #2
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
We need a little more info. Please try describing the sound in more detail. What you are doing when it happens. Is it reproducible? Any changes to car recently? Maybe you could try uploading video to YouTube or another site and post the link here.
      09-26-2021, 07:07 PM   #3
Ragnar The Redneck
Ragnar The Redneck's Avatar
44
Drives: 15 335i GT
High pitched squealing, then goes away when revved. Sounds like either a worn or loose belt. Check the belt tension and wear. When replacing a belt, be sure to replace the tensioner as well.
      10-04-2021, 03:48 PM   #4
clemsonf31
Drives: 2019 330i wagon
Belt tensioner/idler pulley
      01-18-2023, 04:42 PM   #5
EvenKeel
Drives: Sedan
Failed PCV valve on the valve cover
