03-10-2015, 01:11 AM | #45 |
Rep 42
I changed the brake lights on my 428 and I have a warning on left and right brake lights. Lights are working but still got the message after starting my car. How can I erase it or change it? I have the horizonleds. Thanks for your help
03-10-2015, 08:13 AM | #46 | |
Rep 3,089
http://f30.bimmerpost.com/forums/sho...d.php?t=996012
03-12-2015, 04:39 AM | #47 |
BMW Fanatic
331
Rep 1,076
Hope this clarifies everything regarding LED Wattage:
"As for the wattage, you can even use the 80W LEDs, remember LEDs are a low power bulb they are designed to be energy efficient so when they say 80W or 50W for example this is the equivalent in comparison to a halogen power output. This is how LEDs are labelled even home LED bulb too. So the 25W is really only using about 4 watts from the cars wiring. So if anything its using less load on the electrics."
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
03-12-2015, 05:11 AM | #48 | |
Fool
1857
Rep 3,542
An 80W LED is an 80W LED, if it's not, then it's mis-sold. A 25W LED is a bloody bright light source and are certainly available. When you look at these car bulbs that have multiple 3W and 5W LED chips (that's their ACTUAL rated wattage), then it is very conceivable to have an ACTUAL 50W LED bulb in a small car bulb sized package. That would cause issues for wiring (and power supplies) rated for 21W. For example, I would hazard a guess that a 50W LED bulb would use 2 5W LEDs on the top and 4 x 3 x 3W LEDs around the sides. This amounts to 46W and add a current limiting resistor to the equation and you could easily get to 50W. |
03-12-2015, 06:45 AM | #49 | |
BMW Fanatic
331
Rep 1,076
03-12-2015, 09:01 AM | #50 |
Fool
1857
Rep 3,542
The purpose of the current limiting resistor is to protect the LED chips, not the car. If you put a low resistance 50W resistor across +ve and -ve of the car's electrics, you would sink 50W of current through that resistor and turn it into heat. The same 50W would flow through the wires, heating them if they're not rated to the correct level. When current flows through wires that aren't rated properly for the application, they act as big resistors and heat up.
03-12-2015, 09:05 AM | #51 |
Rep 3,089
I think what nickhelou posted only makes sense if the wattage posted is an estimate of equivalent brightness/power output to a conventional bulb. In other words, the LED can output brightness similar to a 80w bulb. So this is part of the confusion with many of the LED suppliers. There is no consistency. Sometimes they refer to the actual power consumption of the LED while other times they refer to the equivalent brightness (which by the way using watts is not the right way to compare brightness but that is another topic).
03-12-2015, 09:15 AM | #52 | |
Rep 278
03-13-2015, 10:06 AM | #53 |
BMW Fanatic
331
Rep 1,076
Installed my 25W H21's from Horizon, and I must say I am really pleased with the results, pictures and videos uploading now.
03-13-2015, 10:12 AM | #54 |
BMW Fanatic
331
Rep 1,076
And the difference is quite apparent; the reflection coming off the ground proves it.
03-13-2015, 10:18 AM | #55 |
Rep 3,089
NICE! Glad these worked for you! So you think these are brighter than the bulb? At least to me the bulb seemed a little bit brighter.
03-13-2015, 10:29 AM | #56 |
BMW Fanatic
331
Rep 1,076
They feel significantly brighter and faster, I am uploading a couple of videos of YouTube, one with only 1 LED installed, and another with both. The LED ones feel significantly faster than stock, and are like 10% brighter. Thank you for referring me to Horizon, was exactly what I wanted for 1/2 the price those offered by Bimmian. A bonus was that Horizon offered them in red, whereas Bimmian only offers them in white.
03-13-2015, 10:38 AM | #57 | |
Rep 3,089
Are you going to pick up the reverse LEDs as posted on the other thread?
03-13-2015, 10:43 AM | #58 | |
BMW Fanatic
331
Rep 1,076
03-13-2015, 10:45 AM | #59 | |
BMW Fanatic
331
Rep 1,076
03-13-2015, 10:45 AM | #60 |
Rep 3,089
Does Horizon offer lights for the reverse? If so can you please provide the part #?
EDIT: forget it..I found it. PW24W. I like how they offer it in 30,40, 50w. The ones I found on ebay are all 50w which I think maybe too much.
03-13-2015, 10:59 AM | #61 |
Rep 1,961
Its not too much. I have 50W in my backups and they're perfect. Wish they didn't flicker when you start the car though. Guess thats the check.
03-13-2015, 11:00 AM | #62 | |
Rep 3,089
As for the flicker, how come you havent coded out the check?
03-13-2015, 11:17 AM | #63 |
BMW Fanatic
331
Rep 1,076
Just took your word for that haha, just ordered 50W's for my car from Horizon alongside more H21's.
03-13-2015, 11:30 AM | #64 | |
Rep 3,089
http://www.horizonleds.co.uk/pw24w-c...w-cree-led-50w
03-13-2015, 11:33 AM | #65 | |
BMW Fanatic
331
Rep 1,076
03-13-2015, 11:37 AM | #66 |
Rep 3,089
Yeah man...I've been waiting for some reverse lights!
