07-30-2020, 11:31 PM | #1 |
VRSF DP & CP, Straight Pipe, H&R Springs, AG Rims
Rep 22
N55 Pure Stage 1 PWG
Just wanted to create this thread to ask a few question see others responses. I have a 2013 335i xDrive (PWG) that has CP, and Dp. I have come across a deal with a pure stage 1 turbo being offered to me for cheap ($500). Are pure stage 1 turbos worth the money and installation price (Installation being near $1,000)? How much power have your builds gotten with the pure stage 1 turbo? I will be getting a fmic before putting the turbo on. I know pure stage 2 turbo kits are near $2k near the same installation price. Then you have to upgrade the high pressure fuel pump with that turbo. Will I need meth to push over 400-450whp with just stage 1 turbos and fbo? I know xDrive slacks on horsepower compared to Rwd. I really do not want to do meth since this is my daily driver or mess with e30 blends since there are no pumps near me (93 pump for me). Please leave your feedback with your pure stage 1 turbo and how you like it or dislike it?
07-30-2020, 11:47 PM | #2 |
Rep 769
iirc when comparing the ps1 on a pwg f30 is about a 30-40 whp gain.. also, the install price on a ps1 should be a lot cheaper than ps2.. pure stage 2 you have to remove the ENTIRE turbo/turbofold, remove and engine mount/brace the engine on a jack or other method to secure it and maneuver the turbo out.. the pure stage 1 doesn't need any of that (it's not a whole turbo), I would estimate the install cost being around $800-$1000, ps2 is closer to $1,200-$1,500.. If I could get my hands on a ps1 for $500 I would do it, you might also want to consider getting the MST inlet while ur at it. you still won't see huge gains with ps1, but it will definitley wake up the PWG F30 as a daily driver..
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
07-31-2020, 12:42 AM | #3 | |
Rep 7,620
IMO paying 1k for the install of a stage 1 is a waste. But thats my opinion. Yes, the turbo is a good deal at 500, but paying that much for labor with a marginal increase in power just doesn't seem cost effective. I think the post above is probably around the ballpark for gains. You will make around the same, maybe a little more, than a EWG with stock turbo. So you might be able to push 400whp, but you might even need a custom tune for that... If you were going to DIY the install, i would say 100% do it. |
07-31-2020, 08:47 AM | #4 | |
Rep 114
07-31-2020, 09:45 AM | #5 |
Rep 191,093
Better in terms of power?
07-31-2020, 09:46 AM | #6 |
Rep 7,620
Which dinan? Oma had a thread not too long ago on Dinan stage 2 I believe, and even with HPFP and supporting mods, his gains were not that substantial over a EWG stock turbo, even with Emix and a custom tune. Yes, more power up top, but not worth the price of turbo + install IMO.
All the stage 1 upgrades that only replace half the turbo and not the manifold are just a lot of labor for not alot of gains IMO. Personally, i would save for a full turbo upgrade like PS2 or BB, etc, and 'do it all the way or not at all'. |
07-31-2020, 10:13 AM | #7 | ||
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
07-31-2020, 11:45 AM | #8 |
Rep 1,105
Unless your doing the install yourself its waste of money IMO. as others have stated you will most likely be around 400AWHP, which is still plenty of fun for daily driving but you'd be better off saving up for a true turbo upgrade.
Just my $.02 |
07-31-2020, 12:24 PM | #9 | |
Rep 529
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
07-31-2020, 01:51 PM | #10 |
Rep 22
I ended up buying it this morning for $400. Turbo is basically brand new (1300 miles on it), from what I can tell some think its a waste some think its a good deal for the money. This is my daily driver and I still want it to be reliable and do not want to have to deal with finding e85 and buying meth. 400 whp is plenty since most can't even get near that with e30. I won't be installing it myself but I have a couple shops in mind who will give me a good deal ($700-800). I will definitely be getting the gfb diverter valve and upgraded inlet when I get the turbo installed. Custom tune will done as well. Do you think its more worth it to sell this turbo and buy a pure stage 2? and any one running similar setup, how much power are you making?
07-31-2020, 02:14 PM | #13 | |
Rep 7,620
For the DV, you should consider the turbosmart and not just the GFB. It may be isolated incidents, but there is some question/uncertainty about long term reliability of the GFB without servicing it. For the inlet, i highly recommend MST v2. Just read the aftermarket inlet on stock turbo thread. At the same time, i would do the MPPK airbox mod and get a dry drop in filter if you have not already, but keep stock intake. Oh, and probably plan on replacing the CCV (aka PCV) hose at the same time. Finally, if you can, it would be informative if you can capture a few (3) 'proper' logs (correct gear, smooth flat road, no bumps, etc) on a road that you can go back to and capture logs again under the same/similar conditions after you get the turbo install. Putting these in virtual dyno will give a nice perspective of the change in peak power and the overall shape of the curve, not to mention looking at the data in the logs themselves for comparison. |
07-31-2020, 06:43 PM | #14 | |
Rep 114
08-01-2020, 04:14 PM | #15 | |
Rep 22
08-01-2020, 06:19 PM | #16 |
Rep 1,105
08-01-2020, 08:41 PM | #17 |
Rep 22
08-01-2020, 10:00 PM | #18 | |
Rep 1,105
Stock fueling is good for about 400whp from my research on pump gas 93. But even then you are still maxing out the limitations of the HPFP only and not the LPFP. I'm in the 500whp realm with PS2 and custom E30 tune. This was only possible with upgraded HPFP alone. With pump 93 im possibly around 430whp on stock fueling. I'm arranging a dyno run later this month and will post logs and my numbers. |
08-03-2020, 10:02 AM | #19 |
Moto Lover
187
Rep 591
08-03-2020, 10:15 AM | #20 | |
Rep 17
2015 335i Xdrive - VRSF DP, CP, intercooler, ER TIC, BM3 Stage 2H+ E30, PS2 w/high flow inlet, DV, Dorch Stage 1 HPFP
08-03-2020, 11:32 AM | #21 | |
Rep 7,620
I doubt you will even need a HPFP unless you are planning to run ethanol. You can probably max or nearly max the stage 1 turbo with stock HPFP, and if you dont want to run ethanol in the first place, meth might be the better choice for octane and supplemental fueling if you wanted to push higher power with more timing on a custom tune. |
08-03-2020, 11:33 AM | #22 |
Rep 7,620
You're leaving alot of power on the table with PS2 and stock HPFP + OTS tune. If you have access to ethanol, a HPFP, custom tune, and maybe a little higher E mix would net you alot of power.
Tags |
335i ewg, f30 335i, f30 335i turbo, n55 335i, pure stage 1 |
