BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Should I?
      07-06-2013, 03:22 PM   #1
F30AM
F30AM's Avatar
Drives: F30 330d M Sport sDrive
Question Should I?
I am considering to get my car detailed on Monday 8th by Liquid in Knigtsbridge. They do Veryon's etc. He checked my car out today after washing it beautifully and said a clay and polish would do wonders. Is claying the paintwork a good thing? Car has no scratches or swirl marks just a few impurities in the paint due to London grime.
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys
      07-06-2013, 03:49 PM   #2
TripleD
Drives: Audi S4 Avant
Claying isn't a bad thing if done properly, then needs a decent couple of lays of wax to help protect.
If you run your fingers over the paintwork you can feel some fallout, claying helps remove this.
      07-06-2013, 03:56 PM   #3
F30AM
F30AM's Avatar
Yes, can feel that in places. Liquid said they need the car for about 6 hours. I'll do it to remove the impurities. Will this be a slippery slope of continuous claying and polishing? Never had this done to any of my cars. I'm a novice.
      07-06-2013, 04:03 PM   #4
-AndyH-
Czech_Republic
25
Drives: F31 330d X-Drive M-Sport
Even a car straight from the dealer should be clayed. On the back of a trailer, it picks up all kinds of impurities and dirt that you will miss by washing.
Claying is not something you need to do regularly, only before polishing and waxing/sealing a car. So you are probably looking at doing it every 3-6 months if your car needs a re-wax/seal. Did Liquid say they would use Gloss It or Zaino as a seal?
      07-06-2013, 04:13 PM   #5
F30AM
F30AM's Avatar
No idea. His name is Ghurcharn Sahota. He's quite famous. I've seen his work and how he transforms cars. Pretty amazing. He works from Knightsbridge and soon will have premises in Mayfair. So in my neck of the woods.
      07-06-2013, 05:36 PM   #6
rich1068
has left the building
You have nothing to be worried about. Claying/waxing/sealing will only bring out the best in your car. And the only way you'll end up on that slippery slope is if you get addicted to the results.
Here's a little tip. Find someone who smokes and slip the cellophane off their ciggie packet. Put two fingers inside the cellophane and feel your paintwork. You can't do this with just your fingers but with the cellophane large areas will feel like a Braille dictionary. Then try this trick again when your man has done his thing
      07-06-2013, 06:41 PM   #7
ZigmundUK
ZigmundUK's Avatar
Drives: I20 IX M60 Oxide Grey
So the claying will help lots of blind smokers with a fetish to touch cars up?
      07-07-2013, 12:48 AM   #8
Doc943
Doc943's Avatar
Drives: F30 320d SE
Claying is always a good thing but it takes time to do it right. The results can be quite remarkable depending on how "gritty" the surface paint is.
      07-07-2013, 03:03 AM   #9
F30AM
F30AM's Avatar
I was just a tad worried that the claying might remove the clear coat.
      07-07-2013, 03:30 AM   #10
TripleD
      07-07-2013, 05:04 PM   #11
rich1068
Yes, that's about it.
It won't.
      07-07-2013, 05:30 PM   #12
SamS
Claying can leave marks/scratches in the clearcoat.
      07-08-2013, 04:44 AM   #13
Torque of the Devil
Drives: 440i Gran Coupe
Only if you don't use enough lube and you are using quite an aggressive clay, a soft clay which is the more typical kind available used with some lube will not mar the paint, however if you are claying the chances are your next stage will be polishing which would remove any clay marks anyway
Claying a car can only be a good thing as it removes surface debris and contaminants, should be done once or twice a year depending on mileage and where you leave your car
As has been said feel your paint especially horizontal panels like bonnet, roof and boot after you've washed it with your fingers inside a thin plastic bag, if it doesn't feel glass smooth it needs claying. My brand new car needed doing put it that way, the roof felt like sandpaper so god knows where the car had been stored as it only had 7 miles on it when I collected
      07-08-2013, 05:54 AM   #14
schrickm5
schrickm5's Avatar
76
Drives: 2013 M550d xdrive touring
I've clayed a few times, check the edge of the clay after you have rubbed part of the car, if your clay is a light colour you can see the dirt starting to build up, you should fold the clay every few wipes.
Try it yourself, its not that hard.....if you have the time that is.
It cant be cheap getting someone in Knightsbridge to detail your car?
2015 M5 CP Blue
[SIGPIC]
Previous Cars:- 2015 GTR > 2014 M5 CP > 2006 M6> 2007 M5 E61 > 2014 F31 328xi >2001 E39 530i > 1995 E34 M5 > 1999 Alpina B8 > 1992 E34 M5 >
      07-08-2013, 06:41 AM   #15
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Sounds expensive. Knightsbridge.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      07-08-2013, 06:47 AM   #16
F30AM
F30AM's Avatar
Says the man who's buying an M5! ..... Pot, kettle ......
Anyway, it's only money.
Knightsbridge is expensive and Mayfair even more so, but then it's all about what one has got used to.
The Detailing will cost £150 which I think is GVFM.
I'll give it in next Monday. Got up late today and felt bloody lazy.
      07-08-2013, 06:53 AM   #17
JOHNBMWM5
JOHNBMWM5's Avatar
Good Price, go for it.
      07-08-2013, 07:55 AM   #18
Torque of the Devil
That's very cheap £250 a day is the going rate for detailers
      07-08-2013, 11:20 AM   #19
F30AM
F30AM's Avatar
Yes, pretty GVFM and he's super fussy. Mind you, £150 is only to do the paintwork + wheels and nothing else. 5-6 hour job.
      07-09-2013, 03:30 AM   #20
changed
changed's Avatar
25
Drives: F10 Msport
once you have clayed your car you will not be able to stop touching it
wait and see...
