02-24-2012, 01:27 PM | #23 |
Rep 10,185
BMW has extended service intervals a while after introducing new engines before.
So after inspecting the plugs being removed after each service they may extend the interval. Anyway, the N20 only uses 4 plugs, so not too much cost at around $8 each. And they are anyway covered in many countries for 4 or 5 years under BMW's maintenance plans
BMW if you are reading, I need a job, Please. |
02-24-2012, 01:35 PM | #24 |
Rep 10,185
A4 2.0 TFSI has spark plugs replaced at 35,000miles or every 3 years regardless of milage
02-24-2012, 01:47 PM | #25 |
Rep 94
02-24-2012, 01:49 PM | #26 |
Rep 10,185
2.0 TDI is a Diesel.
Diesel engines do not have spark plugs.
02-24-2012, 01:53 PM | #27 |
Rep 94
02-24-2012, 01:55 PM | #28 |
Rep 1,772
Sure I can. Both types are available so I can compare them and make an informed choice as to which I should select to get the best life cycle cost versus other benefits.
I can absolutely compare a naturally aspirated engine to a turbocharged one. And I believe its important to compare... people these days are being force-fed turbo charged engines because the fuel economy is better for a given power level and they are made to believe that there aren't other disadvantages involved. For the end user, what is the point of saving some fuel when you end up taking a bunch of extra maintenance charges? The advantage for the company is obvious... you spend the money with them rather than at the pump and, on top of that, they get to fit within the new regulations. I for one really wish that BMW made a naturally aspiriated inline 6 available in the new 3 series and other cars rather than forcing turbo-charged engines on us. |
02-24-2012, 02:10 PM | #29 | |
Rep 10,185
Anyway, the fuel, emissions and planet savings should be more than the cost of a couple $8 spark plugs.
02-24-2012, 02:49 PM | #30 | |
Rep 1,772
To your point, though, I do agree to some extent that the Legislators are to blame. |
02-24-2012, 03:04 PM | #31 | |
Rep 10,185
So we can blame them
04-04-2012, 04:29 PM | #32 |
Rep 10,185
New Update:
NGK has improved their spark plug design and Asof March 2012 production N20 engines will now only need their plugs changed every 2nd oil service and not every oil service.
04-05-2012, 07:06 PM | #33 |
BBS Fanatic
Rep 68
04-05-2012, 07:10 PM | #34 |
BBS Fanatic
Rep 68
subaru has been turboing cars for years.
get this, they require plug changes on their non turbo cars every 30k, 60k, 90k ect.. now on the turbo cars they only require to change plugs at 60k and 120k.. riddle me that?!?! |
04-06-2012, 07:42 AM | #35 | |
Rep 10,185
Just because it is turbo doesnt mean the plug must last a shorter time. We see here on the N20 also that a slight plug design change can improve its life a lot in a specific engine.
04-06-2012, 08:31 AM | #36 |
Rep 318
Not sure I see that big of a problem. Sure it's annoying but wouldn't you want the car running perfect and to last? If your leasing your under warranty, if you bought your good for 50k miles...
Since I "plan" to keep this car awhile I think I'll splurge on the plugs once a year. Think about all the people who change their oil every 3k miles, like it has been for the past 100 years |
05-26-2013, 03:20 PM | #38 | |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
What are your thoughts and info on this? I think 25k miles is far too long for a first service. My last cars have all had their first service somewhere between 12k-16k miles.
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
06-11-2014, 05:56 PM | #39 |
Rep 234
Is the spark plug replacement interval still the same or has the schedule changed or been updated again? It is still every 2nd oil change which works out to approx every 30,000 miles?
06-11-2014, 11:45 PM | #40 |
Rep 7,047
The N55 uses a Bosch platinum plug, Bosch ZR5TPP33S,
can be had for around $24 each. The non OEM Bosch ZR5TPP33 - no S at the end is about $16. Both are "double platinum". I've seen anywhere from 30K to 60K miles replacement interval. The N20 plug is now good for 30K and uses an NGK plug, NGK SILZKBR8B8S. $14 each. This appears to be an iridium plug. |
06-12-2014, 11:53 AM | #43 | |
Rep 3,307
I agree on getting the full picture though, rather than just taking the trends without knowing the other factors. Same goes for hybrids, all electric… It's easy to jump on board, not as easy to decipher all of the true advantages and disadvantages. |
06-12-2014, 08:06 PM | #44 |
Rep 208
Drives: 2018 640i GT/2017 X5 40e
I had my '13 328ix in for first scheduled oil at 13k mi. No mention of spark plug replacement by dealer.
