12-14-2012, 07:25 AM | #23 |
Infidel
122
Rep 1,102
Try OKQ8īs mix, thatīs what Iīve been using since day 1.
Dec. 2022: Fully loaded Carbon Black G08 iX3 LCI M Sport Pro
Former: Glacier Ag. F31 328iA RWD M Sport oct. 2012, sold July 2022 | Sport Automatic | Adap. M Susp. | Pano. Moonroof | 20" ATS Racelight Grey w. Michelin PSS| M Sport brakes | Harman Kardon | Elec. Seats | PDC F&R | ACC Stop&Go | 335i MPE | Perf. Parts | |
12-14-2012, 08:34 AM | #24 |
Rep 63
Alright will do - thanks! Should be interesting as our cars should (in theory) have exactly the same parts. When was your car produced?
Melbourne Red F31 328 M sport
12-14-2012, 08:57 AM | #25 |
Infidel
122
Rep 1,102
Np, if it doesnīt work then I donīt know why I donīt have any problems (yet, perhaps ). Mine was one of the first F31īs so it was finished in the factory at september 17.
12-17-2012, 12:55 PM | #27 |
Rep 63
I ran out of fluid today, and switched to OKQ8's mix. Lo and behold, the problem has vanished. At least for now. Will be interesting to see if it stays gone when the temperature dips again.
Thanks!
12-17-2012, 02:59 PM | #28 |
Infidel
122
Rep 1,102
Well, ten minutes ago it happened to me aswell hahaha jinxed myself
12-17-2012, 03:00 PM | #29 |
Infidel
122
Rep 1,102
12-17-2012, 03:21 PM | #30 | |
Rep 63
My father's got a 328 F30 and he's not had any trouble. He uses Biltema's concentrated stuff mixed with 2/3rds of regular tap water. Will probably try that next if this doesn't work out. The headlights are busted now anyway, so the warning is the least of my troubles... :s
12-18-2012, 01:17 AM | #31 | |
Infidel
122
Rep 1,102
It was just around 0 C outside, I topped up too much and engine was shut off, ignition on, as I did it. Donīt know but if it happened again I would try different things while filling it up, engine on/off, ignition off/on combined with topping up to the edge or just less etc.. inside outside, different temps etc.. Well see what happens when I drive home from work later today And whatīs with your headlights being busted?
12-18-2012, 03:26 AM | #32 |
Rep 63
I don't think it is caused by how or when you refill, but rather the sensor appears to be extremely sensitive. It is likely not well suited to measuring the type of fluids we have up here. If the sensor is measuring conductivity to determine if there's fluid in the container or not, it is likely being spoofed by the fluid being less conductive due to the addition of anti-freeze.
Just a theory. Noticed it yesterday when it started to get dark: The control system for the Xenon level and spread is not working. It is illuminating 5-6 meters in front of the vehicle so it's totally useless on non-lit roads. I'm currently fencing with the dealer to get this sorted quickly. it's the 4th issue I have had in a month, so I am not quite happy (understatement). It's a fantastic car, but I am having bad luck and the dealership is frankly a nightmare to deal with...
12-18-2012, 03:54 AM | #33 | |
Infidel
122
Rep 1,102
U got the adaptive headlights and all that? See, that was the only reason I stayed away from too much tech gadgets when I specced my car, cause Iīm goin for a long term ownership and donīt want too much hassle during that period. Gadgets that I could live without were dissed, but I took a "risk" with the adaptive M and ACC.. and panorama the adaptive headlights felt too risky cause if they start to fail u got no light, and being designed and working the way they do it is like asking for trouble. Too delicate and too finely tuned for my taste, ON/OFF is better Donīt get me wrong, I like new tech and had I really wanted them I wouldnīt have cared but I didnīt feel the need for them as much as I did for the all the other tech I chose. Wouldnīt trade the adaptive M and ACC for anything (but a malfunctioning ACC could really end bad haha :P)
12-18-2012, 05:16 AM | #34 |
Rep 63
Yep, I got the Xenons with adaptive headlights and high beam assistance. I just had to have them after testing my fathers F30 in the dark. I think they are one of the best features of the car. Necessary? No, not really. Extremely awesome in use? Yep.
But you do definitely have a point, and I had that discussion with my father yesterday. He too is going for a longer ownership and is starting to get a bit concerned about all the tech in the car. Like he put it: "What's this car going to cost to maintain in 4-5 years, it could be a small fortune.". Which BTW was the first thing a friend of mine (who works with cars) said when I told him I got the 8 speed sport auto: "Wow, that sounds very expensive in say...4-5 years." His experience was mostly from Audi who apparently have had lots of problems with their high-end transmissions. Anyway,my car is a company car so I specced it like I wanted it, and I will likely trade it in 3 years. But despite that fact I am still concerned about the reliability as I do want the car to work as intended both for me and for any possible subsequent owners. If you sell a car with a certain function, it should perform as intended in all possible situations. I suspect mine broke when we had horrendous weather and really uneven road surfaces (sort of washboard of ice) last week. So, we'll see. It's in the shop now and I got a loaner so with some luck this is the last problem...fingers crossed. I'll keep you posted about the fluid warning too, it's been gone since I changed it, but maybe it will be back...
12-18-2012, 05:41 AM | #35 | |
Infidel
122
Rep 1,102
Good luck mate
12-19-2012, 02:53 AM | #36 | |
Rep 63
A bolt had snapped in the suspension for the level sensor. No damage had been done to it (ie. ice or snow) and it sits quite protected in the engine bay, so the theory of the service department is material failure - simply a bad bolt. On topic I haven't seen the fluid warning in two days now since switching. Does your warning still trigger..?
12-19-2012, 03:25 AM | #37 |
Infidel
122
Rep 1,102
Good to hear it was as simple as that
The fluid warning never came back so it was probably just a fluke, OKQ8-mix still rules or what do youbsay
12-19-2012, 09:13 AM | #38 | |
iX1 2022
35
Rep 333
12-19-2012, 09:46 AM | #39 | |
Rep 63
01-01-2013, 03:34 PM | #40 |
Rep 226
Got the problem today, it was -11 Celcius in the underground parking outside my work (according to the temp gauge). Have to bring the car in soon (for a poorly installed trim piece to be replaced) so I'll let the service guys know.
If anyone finds out a fix would love to hear it. Knowing whether the fluid is full or not is vital when heading onto the highway in our winter weather. |
01-02-2013, 08:25 AM | #42 |
Rep 369
01-02-2013, 09:56 AM | #44 |
Rep 4,323
I"m using OEM fluid, it was 15F this morning, had no issue. I think it's di$k if BMW is making us ONLY use their fluid!
