BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 435i M Sport, F32, 1st gear shifts at 6500rpm
proTUNING Freaks
      04-08-2014, 06:24 AM   #23
rhaddad
rhaddad's Avatar
22
Drives: M4
Originally Posted by Steve33 View Post
Wait, so when you manually shift to second gear, it says in first gear until you get to 6500rpm? That makes no sense.
If not, if you're doing this at WOT, that's normal.
Of course at WOT, just find it weird that first gear shifts at 6500rpm, my Z4 35i used to shift at normal 7000 redline every gear (at WOT, of course)
      04-08-2014, 09:11 AM   #24
335BOY
Drives: 2017 SQ5
Originally Posted by Gio72 View Post
Sorry guys, that's sounds strange to me, because N55 it's really "alive" at high revs, quite different from my old N54 (tuned...)! It gives the best in 5000/7000 rpm for me, expecially with MPPK: as a matter of fact, the manifacturer claims 335hp costant in the range 5.800-6.500rpm
Its the torque that matters and I think he was suggesting that tapers off earlier so accel times actually fall with later shifts.
      04-08-2014, 09:13 AM   #25
335BOY
Drives: 2017 SQ5
Originally Posted by Alpine435i View Post
LOL.
Pat yourself on the back. Manufacturer's break-in guidelines are as meaningless as it gets.
Best of luck with your engine. There is a reason EVERY engine manuf in the world suggests some sort of break in period.
      04-08-2014, 04:36 PM   #26
Gio72
Drives: G80 M3 Competition
No, sorry, but that's not the point: in 1st (and 2nd gear) torque and power are limited by the manifacturer and that's the reason why if you are in D or S and floor the accelerator the step will pass to 2nd gear at 6.500, to 3d gear approximately at 6.700 and the following change will be at 7.000 with NO drop in the progression (as I wrote before, N55 has a fantastic breath at high revs).
If you are in M and you keep the 1st gear to rev-limiter you will feel an evident drop on push after 6.500
I will check out on the Sports Display to see if it shows these limitations in power and torque on 1st and 2nd gear
      04-08-2014, 08:55 PM   #27
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Really?
Terry's BMS 435 N55 test mule
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      10-09-2015, 08:44 AM   #28
stvding
stvding's Avatar
Drives: G20 M340ix
U sure you are not in manual mode and forget to shift?
      10-10-2015, 09:20 AM   #29
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
1st gear is there just to get the car rolling. BMW's aren't designed for drag racing so I don't know why we would expect it to perform like one.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
435i, f32, gears, redline, shifting
