03-17-2014, 07:35 AM | #1 |
Rep 564
...and I'm still not the wiser. Help!!!!!!!
Yup, it's me again....still confused/undecided.
So, the question is this... On a F30 325D M Sport with the M Sport Plus Pack, would you rather: Option A: Professional Navigation Option B: Business Navigation Plus Full Black Panel Display Adaptive Suspension The ONLY reason Professional is still an option is for two reasons: 1. Larger screen 2. RTTI I'm not that fussed around the apps etc so could, in theory, only spec. Business Navigation and not add the Navigation Plus add-on. So the question is, how much better is RTTI over TCP? And the 8 inch screen over the 6.5? |
03-17-2014, 07:42 AM | #2 |
Rep 459
For me, active suspension was a must. I ended up with pro nav + adaptive, and blowing the budget slightly mostly because the screen really finishes the car nicely. Odd reason, but worth it to me.
03-17-2014, 07:43 AM | #3 |
Rep 949
I have the bus nav and its absolutely fine. Reports traffic jams etc and works well.
I'd go for Option C: Business Navigation Plus Visibility Pack Adaptive suspension Vis pack is only £200ish, I think the black panel is £150ish so easy swap. Adaptive/HBA lighting is much more impressive than black panel display. |
03-17-2014, 07:44 AM | #4 |
Rep 926
I don't have any of the above, but I'd guess that if you're a "keen" driver, then surely the adaptive suspension is more important? Or if you're doing longer journeys and need the better screen fro sat nav, go with the Pro Nav.
03-17-2014, 07:52 AM | #5 | |
Rep 3,445
Drives: G22 M440D
The Sport setting is noticeably more crashy, not sure it actually helps over some surfaces. D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
03-17-2014, 07:53 AM | #6 | |
Rep 564
I know this probably makes me sound like a nutter, but really not feeling the Visibility Pack as the Adaptive Lights are not something that I'm 100% sold on. Have a demo coming Friday, which hopefully has this feature so that I can experience it in the flesh.
03-17-2014, 08:20 AM | #7 |
Rep 565
I wouldn't bother with adaptive as it's not a very good system on the f30's(shared with the f20's) also quite a few people reported issues (like knocking sound) and the standard passive Msport suspension just right unless you want xdrive in that case you need it to make it a bit harder ride.
Pro nav does make the dash look great |
03-17-2014, 08:25 AM | #9 | |
Rep 3,445
Drives: G22 M440D
D.
03-17-2014, 08:33 AM | #10 |
Rep 5,021
Option B without a doubt. The Adaptive Suspension is THE essential option IMO.
Previous: Superman 330d sDrive M Sport + Toys
Present: Red Tornado Golf 7R 5 Dr, DSG + Toys |
03-17-2014, 08:37 AM | #11 |
Rep 19,982
On an sdrive car down south where the roads are busy and back road handling isn't something one does a lot, then I'd take the Pro Nav for the RTTI, which is handy round here with the busy roads.
If I was back living in Scotland still then I may go the other way, as the ability to soften or firm the suspension depending on how crap or how twisty the raods are is something I'd use more. On an xdrive car then it would definitely be the adaptive suspension.
03-17-2014, 08:57 AM | #12 |
Rep 11,291
That’s cos you are not driving your car properly. You are driving it how it was not intended (ie like a sports car). Lets not forget the F30 is a family/rep car.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
03-17-2014, 09:09 AM | #13 | |
Rep 1,322
For me the adaptive is the more compelling option overall (particularly since you are getting business nav) but regard for how/where you will use the car in reaching a decision is great advice. Black panel display is the last thing you should pay for as an option. It comes as standard with every option that uses it so, if it's not standard equipment with your spec, it's not needed. Unless you truly value the aesthetic appeal, I would recommend investing the cash in something else first. If it helps, I've had my F30 for 2 years and never once thought "that instrument cluster is rubbish, I wish I'd specced 'extended display'". Still, I'll admit it looks nicer |
03-17-2014, 09:11 AM | #14 | |
Rep 20,651
A lot depends on how long you plan to keep the car for. With the vis pack, it changes your final future value element, however monthly amount should stay same or so. I believe you can also have the function on manual, so you just get xenons working and not adaptive.. Needs checked. Bus nav comes with a lot of functions, however pro media / nav looks good. If you do not use sat nav much or worried about larger display, then go for business media / media plus. |
03-17-2014, 09:29 AM | #18 |
Rep 564
03-17-2014, 09:49 AM | #19 | |
Rep 673
As the OP is not going for an XDrive model he'll have RWD, Msport suspension, thicker ARBs and a lighter engine (vs the 6 cyl). You may not need it. |
03-17-2014, 09:53 AM | #20 |
Rep 183
What kind of driving would you do Meds? Are you the kind of guy that gets 10k out of a set of tyres? That pushes your car close to the limit on twisty roads? If so get Adaptive. If your an average driver that will just be using it on commutes, family days out etc with the occasional bit of fun then you could definitely live without it, you would find the standard suspension absolutely
fine. |
03-17-2014, 09:55 AM | #21 | |
Rep 9,709
...but as I said....if you drive like Grandad |
03-17-2014, 09:57 AM | #22 | |
Rep 9,709
.....my car is faster on my 'hoon' track without the adaptive......by a long margin. |
