02-28-2016, 09:36 AM | #200 |
Rep 40,858
You do not have a choice between them. PREMIUM Map is for CIC Head Unit, and NEXT Map is for newer NBT Head Unit.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 02-28-2016 at 11:03 AM.. |
02-28-2016, 11:04 AM | #202 |
Rep 40,858
02-28-2016, 11:15 AM | #204 | |
Rep 40,858
0x28 0x0B for Europe PREMIUM 2016-1 0xA9 0x08 for Europe NEXT 2016-1
02-28-2016, 11:44 AM | #206 |
Rep 40,858
I am not sure what you are not understanding. It is explained Step-By-Step in Post #2.
02-28-2016, 02:18 PM | #207 |
Rep 395
Hi Shawn, will Next Maps work on my 2013 Pro Nav system?
F36 440i GC with a lot of bling
Sold - 2014 F30 335d xDrive M Sport / Alpine White / MPerformance Rear Spoiler / MPerformance Black Grills / Adaptive Suspension / M Sport Breaking / Reversing Camera / Folding Auto Dipping Mirrors / Sun Protection Glass / Adaptive Headlights / 19" M 442M Alloys / Pro Nav Media Package / Sunroof / Heated Memory Dakotas / High Gloss Interior Trim / High Gloss Shadowline / Xenons / |
03-03-2016, 08:35 AM | #208 |
Rep 2
Man Im suck. I have problem to solve. Need this badly I have E-Sys 3.26.1 and I connect cabel to car F30. When I run this esys there is no such thing like F20 to connect - blind spot. Its shows that i can pick connection via VIN. So I think i need PSdzData Lite, right? So I download now those lite 3.57.4 But where it put where install to work propetly. Can someone help me with this? I have map now need this code.
03-03-2016, 08:45 AM | #209 |
Rep 8,086
Next Maps for NBT
Premium maps for CIC A 2013 will almost certainly be CIC. Do you have the big iDrive controller (that you can write on) or the small controller?
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-03-2016, 09:13 AM | #210 | |
Rep 40,858
03-04-2016, 04:41 PM | #211 |
Rep 395
Big one
03-06-2016, 01:54 PM | #212 |
Rep 1
Hi Shawn..
Wondering if you could help me? I've generated the FSC code through E-sys, I changed the batch file to 0xA9 0x08 for Europe NEXT 2016-1. Once I plugged USB into my F30 2013 Pro Nav NBT it says new update is available and asks for code. The code I am receiving from BMW_CIC_NBT_FSC Generator is wrong and now my Nav is stuck on insert correct code?? I've tried changing the batch file to 0xA9 0x09 etc but none of the codes generated work? I've also tried FSC Generator and when I enter my .fsc and choose correct map after updating LookUP I keep getting the same error that NBT.exe is missing from Tools directory? I've downloaded the FSC generator numerous times form different sources but this NBT.exe file never appears?? Thanks in Advance Chris Actually got it sorted after hours messing around with BMW FSC Code Generator.. Instead of using the programme to generate the FSC code I used the Command Line like Shawn explained earlier. I used FSC.exe xxxxxxx.fsc 0xA9 0x08 (7 DIGITS of VIN) in the command prompt tools directory and the code it gave me worked straight away.. It was so frustrating getting the wrong code each time but delighted now I'm on Europe NEXT 2016-1.. Last edited by chrismvideo; 03-06-2016 at 04:56 PM.. |
03-07-2016, 10:18 AM | #214 |
Rep 40,858
PM sent.
04-02-2016, 01:18 PM | #217 |
Rep 40,858
I see you just received a response on other thread for same thing.
04-02-2016, 01:28 PM | #218 |
Rep 2
04-02-2016, 01:29 PM | #219 |
Rep 40,858
They are not linked per se', I just saw both your posts.
04-15-2016, 05:57 PM | #220 |
Rep 1,894
Just upgraded to Europe NEXT 2016-2:
The code for the lookup.xml is: <SgbmId id="NAVD_000014B9_255_002_184" SWID_FscShort="00A90027" name="Road Map EUROPE Next 2016-2" supplier="NTQ" sop="01.04.2016" version="10_09" MapOrderNumberBMW="" MapOrderNumberMINI="" MapOrderNumberRR="" successorMapOrderNumberBMW="" successorMapOrderNumberMINI="" successorMapOrderNumberRR=""> <EcuVariant CompatibilityIdentifier="NBT-HB" Format="CIC" /> <SwUpdate SwUpdateEntry=""/> </SgbmId> I got the map data from here: http://www.bmwfsc.ca/wp-content/uplo...2016-2.torrent |
