02-15-2018, 01:11 AM | #1 |
Rep 40
on JB4 AMP Connector....
Hello all,
I have an inquire with a few question. I know there are two wiring as per the install guide. -. What is the High Can signal on pin 2 and pin 15? (e.g, Look at the green 2 wire from the AMP connector. Where should this line connect to the car's OBDII connector pins?) -. What is being happened when it is not connected properly between JB4's OBDII and Car's OBDII? Thank you in advance. Last edited by Justin Gang; 02-15-2018 at 01:21 AM.. |
02-15-2018, 12:53 PM | #2 |
Rep 115,980
You pic is not working?
The OBD connection has 2 wires. If they are not connected properly then you will not have CAN access with the JB4 and the JB4 will turn itself off and default to map1 (stage1 equivalent) Mike |
02-17-2018, 08:04 AM | #3 | |
Rep 40
Yes. It does not draw in the application's Map 1/2/5. Is there a way to check if the OBDII connector is OK? According to my memory, the brown wiring was connected to the OBDII pin 6 of the vehicle and the green wire was connected to the OBDII pin 14 of the car. What is the problem? Thank you in advance Last edited by Justin Gang; 02-17-2018 at 08:47 AM.. |
02-17-2018, 10:59 AM | #4 | |
Rep 115,980
If you plug into the JB4 app or Connect Kit and you see engine parameters then OBD is working.. Mike |
