11-28-2017, 10:23 AM | #1 |
Rep 13
Powerflex camber adjustable polybush
Has anybody tried these? LINK
Just had my alignment done on a Hunter system and the offside front has +0.06 camber compared to the nearside front (-0.32). Wonder if these would do the trick and actually allow me to get the camber adjusted as I'm aware they are fixed on the F30's. Last edited by parsco; 11-28-2017 at 10:51 AM.. |
11-28-2017, 11:27 AM | #2 | |
Rep 1,291
What changes did you make to the car so far? I?m considering superpro rather than powerflex because they?re one piece and that seems more resistant than the 2 piece powerflex bushings to me interested too in feedback on noise/vibrations increase if any?
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
11-28-2017, 01:14 PM | #4 |
Rep 38
I would first ask the alignment shop to shift the front crossmember to equalize the camber settings left to right.
Also, check the ride height of the front corners. If one side is sitting lower, it'll have slightly more negative camber. My car sat slightly lower on the passenger side, and I was able to reposition the strut in the steering knuckle to raise that corner of the car, equalizing the camber. |
11-28-2017, 09:35 PM | #5 | |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
11-30-2017, 09:03 AM | #6 |
Rep 13
It also appears that these will not fit the xDrive models. I'm leaning towards the Super Pro ones but apparently they won't fit mine either.
Anybody know if these bushes are different across the 2WD and 4WD F30's? |
11-30-2017, 10:28 AM | #7 |
299
Rep 531
The OE part number is 31106786959 and interchanges with pretty much all F-series, RWD or AWD. This part would presumably do the same, since it's meant to replace it.
11-30-2017, 11:03 AM | #8 |
Rep 1,291
Powerflex has an xdrive section https://www.powerflex.co.uk/road-ser...ve-3301/1.html so presumably they would list the same parts if they were compatible
11-30-2017, 01:28 PM | #9 |
Rep 1,291
Superpro list their products for both AWD and RWD
https://www.superproeurope.com/part....renceid=127008
12-02-2017, 04:54 AM | #10 |
Rep 8,493
I have SuperPro caster adjustable bushes in my F31 330D - they fit fine and have noticeably improved the steering feel. The BMW OEM compliance bushes are very soft, presumably to mask the NVH of the runflats (I've been running Michelin Pilot Super Sports since I got the car a couple of years ago) and lead to very imprecise steering in my experience, especially as speed increases.
Lancelot567.50 |
12-02-2017, 06:41 AM | #11 |
Rep 1,291
Are you running them at max caster setting?
How’s the NVH with these? I’m on pilot super sport too (or pilot alpin 4 in winter). Any noticeable change?
12-02-2017, 08:24 AM | #12 |
299
Rep 531
Caster and camber are two different things, of course. But increased caster is a nice thing to have, too. It results in better steering self-centering and will increase dynamic camber as well.
12-02-2017, 02:37 PM | #13 |
Rep 8,493
Caster is currently 6.3 degrees, as part of a complete suspension geometry and corner-weighting set-up. I wouldn't describe the feel of the car as having more NHV - yes, aspects of the ride are firmer, but the payoff in terms of steering feel (linear; responsiveness; consistency) is what I still notice and appreciate.
12-02-2017, 02:54 PM | #14 | |
Rep 1,291
12-15-2017, 08:11 AM | #15 |
299
Rep 531
Let us know what you think of them after you purchase and fit them, please.
02-18-2018, 01:42 AM | #16 |
Rep 1,291
So i just fitted the camber and caster bushings, for now we've been able to adjust camber left/right to match at -0,5deg, and caster to 7.5deg giving more steering feel (i believe stock is about 6.5)
Noise/vibrations : nothing to report in that area i think it's virtually unchanged. Ride is a little more harsh, perhaps compounded by my KW coilovers that are stiff, but also well matched to these harder bushings. To make it clear I don't dislike this, it's just noticeable. Steering feel seems much more precise, as expected and that's *really* nice. Less compliant bushings also mean they don't tolerate steering imprecision from the driver, let's say you push hard out or a corner, they won't absorb anything for you and the front end may lose grip quicker - perhaps just my feeling, we'll see if i confirm that in coming days, it's cold out there and surface could be slippery too.
IK6SPEED4488.00 hardparker299.00 |
02-18-2018, 03:36 PM | #17 | |
Rep 1,291
If you're hesitant to pull the trigger, don't be
IK6SPEED4488.00 |
02-19-2018, 06:36 PM | #18 |
Rep 1,584
The stiffer bushing on a car like this will prevent the alignment angles from changing during cornering so it doesn't surprise me that you feel more confident and will probably notice that you have a bit more grip over uneven pavement. The soft factory bushings allow the wheel to move around in different directions when you go over bumps while aggressively cornering, no good for confidence or grip.
02-20-2018, 12:22 AM | #19 | |
Rep 1,291
02-20-2018, 09:44 AM | #20 |
Rep 1,348
I'm hoping they have this with an entire bushing kit. Going to call them now.
2k15 335i Msport xdrive 6spd
02-20-2018, 10:00 AM | #21 |
Rep 1,348
Had to email them for some reason my calls can't get through don;t know if its a country code issue or what.
